[ASP]Geeft foutmelding bij aanroep van tweede tabel
  • 41 views sinds 30-01-2008
  • amiga1260
  • Laatst online: 22-10 22:22
Ik krijg deze foutmelding:
ADODB.Recordset (0x800A0CC1)
Item cannot be found in the collection corresponding to the requested name or ordinal.
/Default.asp, line 44
Verder heb ik op allerlei forums gekeken, maar kan geen oplossing voor vinden.
Ik heb twee tabellen:
Studenten
Hobby
In het tabel Hobby heeft als vreemde sleutel Student_ID
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
<html>
<title>CodeAve.com(Create XML from Access)</title>
<body bgcolor="#FFFFFF">
' Name of the access db being queried
accessdb="Studenten"
' Connection string to the access db
cn="DRIVER={Microsoft Access Driver (*.mdb)};"
cn=cn & "DBQ=" & server.mappath(accessdb)
' Create a server recordset object
Set rs = Server.CreateObject("ADODB.Recordset")
Set rs2 = Server.CreateObject("ADODB.Recordset")
' Query the states table from the state_info db
sql = "select * from student"
' Execute the sql
rs.Open sql, cn
' Move to the first record
rs.MoveFirst
' Name for the ouput document
file_being_created= "student.xml"
' create a file system object
set fso = createobject("scripting.filesystemobject")
' create the text file - true will overwrite any previous files
' Writes the db output to a .xml file in the same directory
Set act = fso.CreateTextFile(server.mappath(file_being_created), true)
' All non repetitive xml on top goes here
act.WriteLine("<?xml version=""1.0""?>")
act.WriteLine("<Studenten>")
'Loop to output all the query results to the xml document
do while not rs.eof
' counter to give each record a sequential listing
counter=counter+1
Studnr=RS(Student_ID)
act.WriteLine("<Student>")
act.WriteLine("<Voornaam>" & rs("Voornaam") & "</Voornaam>" )
act.WriteLine("<Achternaam>" & rs("Achternaam") & "</Achternaam>" )
act.WriteLine("<Geboortedatum>" & rs("Geboortedatum") & "</Geboortedatum>")
sql2 = "select Hobbynaam from Hobby where [Student_ID]="&Studnr
' Execute the sql
rs2.Open sql2, cn
act.WriteLine("<Hobby's>")
act.WriteLine("<Hobby>" & rs2("Hobbynaam") & "</Hobby>" )
rs2.movenext
loop
act.WriteLine("</Hobby's>")
do while not rs2.eof
act.WriteLine("</Student>")
' move to the next record
rs.movenext
loop
' All non repetitive xml on bottom goes here
act.WriteLine("</Studenten>")
' close the object (xml)
act.close
rs2.close
rs.close
' Writes a link to the newly created xml document in the browser
response.write "<a href='Student.xml'>student</a> (.xml) has been created <br>"
response.write "on " & now() & "<br>"
</body>
</html>
Het sript moet het volgende doen:
De gegevens uit het Tabel Studenten, voornaam, achternaam en geboortedatum ophalen.
Uit het Tabel Hobby, de hobby's van de studenten halen.
Deze gegevens moeten dan in een XML bestand worden weggeschreven.
  • Jaspertje
  • Laatst online: 13-10 14:53
Jaspertje
Max & Milo.. lief
rs("studentID")
Haakjes, toch wel erg makkelijk hoor..... Deze fout betekend altijd dat je iets aanroept wat niet in je SQL statement staat
Zoek ff met google anders:
http://www.google.nl/sear...requested+name+or+ordinal
[ Voor 122% gewijzigd door Jaspertje op 11-06-2004 15:36 ]
  • gorgi_19
  • Laatst online: 23-10 16:43
gorgi_19
Kruimeltjes zijn weer op :9
Sterker nog, ik heb destijds een ASP-FAQ geschreven waar dit probleem netjes in beschreven staat. Zie klik
Zie voor je volgende topics ook P&W FAQ - De "quickstart" ; 82 regels code zijn niet allemaal relevant; hetprobleem is terug te brengen naar 5 regels.
[ Voor 34% gewijzigd door gorgi_19 op 11-06-2004 15:37 ]
Digitaal onderwijsmateriaal, leermateriaal voor hbo
