pptpd zegt: No free connection slots or IPs
Hoi,
Ik probeer een VPN server op te zetten alleen een echt groot succes is het niet aangezien pptpd steeds meldt dat hij geen vrije slots of IP`s heeft. Ik niet vinden wat ik hier aan moet doen. iemand hier een idee ?
stukje log als ik verbinding probeer te maken.
Jun 11 14:25:51 phyton pptpd[22443]: MGR: No free connection slots or IPs - no more clients can connect!
Jun 11 14:25:51 phyton pptpd[23427]: CTRL: Client 82.*.*.* control connection started
Jun 11 14:25:51 phyton pptpd[23427]: CTRL: Starting call (launching pppd, opening GRE)
Jun 11 14:25:51 phyton pppd[23428]: pppd 2.4.1 started by root, uid 0
Jun 11 14:25:51 phyton pppd[23428]: Using interface ppp0
Jun 11 14:25:51 phyton pppd[23428]: Connect: ppp0 <--> /dev/pts/7
Jun 11 14:25:51 phyton pppd[23428]: No CHAP secret found for authenticating DopeY
Jun 11 14:25:51 phyton pppd[23428]: CHAP peer authentication failed for remote host DopeY
Jun 11 14:25:51 phyton pptpd[23427]: CTRL: Ignored a SET LINK INFO packet with real ACCMs!
Jun 11 14:25:51 phyton pppd[23428]: Connection terminated.
Jun 11 14:25:51 phyton pppd[23428]: tcflush failed: Input/output error
Jun 11 14:25:51 phyton pppd[23428]: Exit.
Jun 11 14:25:51 phyton pptpd[23427]: GRE: read error: Bad file descriptor
Jun 11 14:25:51 phyton pptpd[23427]: CTRL: PTY read or GRE write failed (pty,gre)=(-1,-1)
Jun 11 14:25:51 phyton pptpd[23427]: CTRL: Client 82.*.*.* control connection finished
Wat staat er in je pptpd.conf ?
voorbeeld:
# TAG: localip
# TAG: remoteip
#       Specifies the local and remote IP address ranges.
#       You can specify single IP addresses seperated by commas or you can
#       specify ranges, or both. For example:
#               192.168.0.234,192.168.0.245-249,192.168.0.254
#       IMPORTANT RESTRICTIONS:
#       1. No spaces are permitted between commas or within addresses.
#       2. If you give more IP addresses than MAX_CONNECTIONS, it will
#          start at the beginning of the list and go until it gets
#          MAX_CONNECTIONS IPs. Others will be ignored.
#       3. No shortcuts in ranges! ie. 234-8 does not mean 234 to 238,
#          you must type 234-238 if you mean this.
#       4. If you give a single localIP, that's ok - all local IPs will
#          be set to the given one. You MUST still give at least one remote
#          IP for each simultaneous client.
localip 192.168.1.100
remoteip 192.168.1.110-115
Ik neem aan dat je doelt op wat er bij localip en remoteip
remoteip 62.*.*.*
Ik kan moeilijk meer remote IPs neer zetten als ik maar 1 IP heb gekregen ?
Ik wil namelijk die VPN gewoon op een bak draaien met een ADSL touwtje...
Maar ik lees ook dat je meerdere IP`s bij remoteip zou neer moeten zetten dan zou dat probleem zijn opgelost.... Maar dat woprdt een beetje lastig
[ Voor 57% gewijzigd door Verwijderd op 11-06-2004 14:39 ]
  • Seth4Chaos
Seth4Chaos
that's me...
Hier moet je (volgens mij) de ip addressen zetten die je van je lokale netwerk wilt gebruiken voor de externe machines (dus die inbellen)
dus iets als:
Mistakes are proof that you are trying...
  • Jaap-Jan
  • Laatst online: 22-08 13:24
Verwijderd schreef op 11 juni 2004 @ 14:37:
remoteip 62.*.*.*
Ik denk dat je niet helemaal door hebt wat er met remoteip en localip bedoeld wordt. 'localip' is het IP dat je aan de server wilt geven waar pptpd op draait, remoteip is het ip voor de clients die connecten met de VPN server.
| Last.fm | "Mr Bent liked counting. You could trust numbers, except perhaps for pi, but he was working on that in his spare time and it was bound to give in sooner or later." -Terry Pratchett
remoteip 62.*.*.*
je moet het anders zien denk ik, het werkt ongeveer net zo als een dhcp pool.
localip word het ipaddress van de ppp0 adapter, en de remoteip worden de ip adressen van de clients die connecten. zoals jij het opgeeft in je conf is denk niet goed.
mijn linux eth0 heeft ip adres 192.168.1.3 dus geef ik voor de ppp0 adapter maar 192.168.1.100 mee (gewoon om dat het mooi rond vrij ip adres is :)) en een pooltje voor de clients van 192.168.1.110-115 dus er kunnen 5 clients tegelijk op.
ik hoop dat het een beetje duidelijker is zo.
Japie_17 schreef op 11 juni 2004 @ 14:43:
Ik denk dat je niet helemaal door hebt wat er met remoteip en localip bedoeld wordt. 'localip' is het IP dat je aan de server wilt geven waar pptpd op draait, remoteip is het ip voor de clients die connecten met de VPN clients.
Ik weet zeker dat ik het verkeerd begreep wat er mee bedoelt werd....
Ieder geval bedankt voor het uitleggen! _/-\o_
[ Voor 3% gewijzigd door Verwijderd op 11-06-2004 14:51 ]
