Hoe zet ik in windows 2003 server poort 49001 open?
Ik heb het opgezocht in de windows help file, die zegt het volgende:
Als het goed is ben ik ingelogd als admin, maar hij doet het inloggen wel automatisch.
Maar bij advanced TCP/IP settings staan alleen de kopjes "general", "DNS" & "WINS", hoewel de help verwijst naar "properties".To configure TCP/IP to use TCP/IP filtering
Open Network Connections.
Right-click the network connection you want to configure, and then click Properties.
On the General tab (for a local area connection) or the Networking tab (for all other connections), click Internet Protocol (TCP/IP), and then click Properties.
Click Advanced.
Click Options, click TCP/IP filtering, and then click Properties.
Do one of the following:
To enable TCP/IP filtering for all adapters, select the Enable TCP/IP Filtering (All adapters) check box.
To disable TCP/IP filtering for all adapters, clear the Enable TCP/IP Filtering (All adapters) check box.
Based on your requirements for TCP/IP filtering, configure TCP ports, UDP ports, or IP protocols for the allowed traffic.
Notes
To perform this procedure, you must be a member of the Administrators group or the Network Configuration Operators group on the local computer.
To open Network Connections, click Start, point to Settings, click Control Panel, and then double-click Network Connections.
Related Topics
