Lotus Domino 6.5.1 en Debian
  • 595 views sinds 30-01-2008
  • Beat691
  • Laatst online: 07-08-2022
Ik probeer lotus domino op me debian server te installeren, dit heb ik gedaan:
root: adduser notes
root: passwd notes
root: /root/software/domino/linux/install
Dan kies ik gewoon voor de standaard directorys/enterprice server/remote setup
dan gaat hij installeeren, als hij voltooid is dan wilt hij de remote setup service op port 8585 gaan starten, maar dan krijg ik het volgende:
./java -ss512k -Xoss5M -cp jhall.jar:cfgdomserver.jar:Notes.jar lotus.domino.setup.WizardManagerDomino -data /local/notesdata -listen
*Warning all runtime debug info will be logged to /local/notesdata/setuplog.txt
dus dan bekijk ik /local/notesdata/setuplog.txt daar staat in:
Startup arguments = -data /local/notesdata -listen
Creating new WizardData instance
argument 0 -data
Processing -data parameter
argument 2 -listen
About to wait on run
About to wait on DominoAPIThread.callAPI()
Woke up from wait on run
dominoAPI.run.init
About to notify api caller
Woke in DominoAPIThread.callAPI()
detected jsetdom JNI interface
launch path= /local/notesdata
Set writable helpdir /local/notesdata
dominoAPI.run.initNotes
DominoAPI - initializing notes
Thread= Thread[Thread-1,5,main]
*Error - can't initialize notes Notes.jar not detected
java.lang.UnsatisfiedLinkError: /opt/lotus/notes/65010/linux/liblsxbe.so: libstdc++-libc6.1-1.so.2: cannot open shared object file: No such file or directory
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1843)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1729)
at java.lang.Runtime.loadLibrary0(Runtime.java:780)
at java.lang.System.loadLibrary(System.java:865)
at lotus.domino.NotesThread.load(NotesThread.java:306)
at lotus.domino.NotesThread.checkLoaded(NotesThread.java:327)
at lotus.domino.NotesThread.sinitThread(NotesThread.java:181)
at lotus.domino.setup.DominoAPI.initNotes(DominoAPI.java:75)
at lotus.domino.setup.DominoAPIThread.run(DominoAPIThread.java:135)
You must install the Domino Server in order to run the setup program.
endWizard
DominoConstants.getWritableDirectory()
writable directory = /tmp
Ik heb de remote setup ook handmatig geprobeerd te starten maar dat gaf de zelfde fouten..
notes@mrorange:/local/notesdata$ /opt/lotus/bin/server -listen
Heeft iemand enig idee wat ik mis of wat ik fout doe...
Ik heb deze handleiding gebruikt, maar komt neer op het hier bovengenoemde..
http://bilykspride.serveh...ES/DNP-Domino6onLinux.pdf
hij heeft het ook over Notes.jar notdetected in de setuplog....
notes@mrorange:/local/notesdata$ locate Notes.jar
/opt/lotus/notes/65010/linux/Notes.jar
[ Voor 6% gewijzigd door Beat691 op 11-06-2004 09:51 ]
Honda viertakt, often imitated, never duplicated!
Lijkt me een JNI probleem.
Kijk is naar de output van ldconfig -p
En doe is een ldd op /opt/lotus/notes/65010/linux/liblsxbe.so
Je mist waarschijnlijk libstdc++-libc6.1-1.so.2
Als je gevaarlijk wilt doen kan je dit proberen:
cd /usr/lib
ln -s libstdc++-3-libc6.2-2-2.10.0.so libstdc++-libc6.1-1.so.2 && ldconfig && echo "PASS" || echo "FAIL"
[ Voor 55% gewijzigd door Verwijderd op 11-06-2004 10:01 ]
  • Beat691
Verwijderd schreef op 11 juni 2004 @ 09:51:
cd /usr/lib
Ik heb dit gedaan, en dat is de oplossing :)
cp /usr/lib/libstdc++-libc6.2-2.so.3 /usr/lib/libstdc++-libc6.1-1.so.2
  • pienk
  • Laatst online: 05-12-2024
Ik heb een tijdje geleden ook Domino op debian geprobeerd, en had toen een specifice versie van IBM java nodig. Ik weet niet meer welke, probeer google.
Success
edit
te laat
edit
[ Voor 8% gewijzigd door pienk op 11-06-2004 10:23 ]
energy powers future motion
  • Beat691
Na het probleem opgelost te hebben crashte de server als ik hem wou starten..
nu heb ik dit ook opgelost...
ik zal ff neer zetten hoe ik het dus geinstalleerd heb voor de mensen die dit topic vinden met het zelfde probleem :)
1. Installeer libstdc++2.9-glibc2.1 (oplossing voor die server crash, met andere versie kan de server dus crashen bij het opstarten) en gawk (is voor nsd -kill)
2. cp /usr/lib/libstdc++-libc6.2-2.so.3 /usr/lib/libstdc++-libc6.1-1.so.2 (oplossing voor het probleem van server -listen)
3. adduser notes
passwd notes
4. ./install als root
5. cd /local/notesdate
/opt/lotus/bin/server -listen (remote setup port 8585)
stap 5. is voor eventuele remote setup...
6. login als user notes
7. cd /local/notesdata
start na een eventuele crash /opt/lotus/bin/nsd -kill in de directory /local/notesdata
dit killt volgens mij alle domino services en schoont wat files op...
[ Voor 4% gewijzigd door Beat691 op 11-06-2004 14:16 ]
  • Beat691
Nu de volgende fout :(
06/11/2004 14:59:38 HTTP Server: DSAPI Domino Off-Line Services HTTP extension Loaded successfully
06/11/2004 15:00:18 HTTP JVM: *** panic: JVMXE104: allocGuard mprotect
Stack base = 0xbf5ffc4c, Stack size = 1524 bytes
Fatal Error signal = 0x0000000b PID/TID = 2985/2051
Fatal Error signal = 0x0000000b PID/TID = 2789/2051
segmentation fault
Weet iemand hier een oplossing voor ?
  • Beat691
Ik zit nog steeds met deze fout... iemand ?
Ik heb geprobeerd:
http://www.dominoforum.de...php?topic_id=2002&forum=7
en http://www.icconsulting.c...gies.jsp/DominoLinux.html
met de volgende versies
jre1.3.1_12 en j2sdk1.4.2_03 en met jdk1.1_1.1.8v1-3_i386.deb maar alle drie geven ze deze fout:
06/15/2004 14:08:48 HTTP Server: Using Web Configuration View
06/15/2004 14:08:56 JVM: The JVM runtime library could not be found.
06/15/2004 14:08:56 JVM: Java Virtual Machine failed to start
06/15/2004 14:08:56 HTTP Server: Error Loading Java Virtual Machine
06/15/2004 14:08:56 HTTP Server: JVM: Missing entrypoint in JVM runtime librar
y.
06/15/2004 14:09:05 HTTP Server: Shutdown
Dit allemaal hielp dus niet, dus weer terug gezet naar de normale versie bij domino zit... krijg nu dus weer die Sementation Fault.... zo als in het vorige bericht beschreven
[ Voor 3% gewijzigd door Beat691 op 15-06-2004 16:39 ]
Ik heb behoorlijk wat ervaring met Domino op Linux.
Ik kan je maar 1 ding adviseren. Gebruik Redhat.
Redhat 7.2 wordt officieel ondersteund door Lotus.
Wij hebben het voor elkaar gekregen om Domino te runnen op Redhat 9.0, maar ook hiervoor zijn behoorlijk wat kunstgrepen voor nodig.
Dit alles heeft te maken met libstdc++. (Of liever gezegd de juiste versies hiervan). Voor Redhat 9 bestaan er packages om compatibel te geraken met 7.2 (Dat is de reden waarom het werkt). Waarschijnlijk heeft Debian te nieuwe versies van libstc++ voor Domino.
Misschien krijg je het werkend op Debian, maar hoe stabiel het dan wordt???
Mijn ervaring is dat Redhat 7.2 nog de meest stabiele oplossing is.
Misschien kun je lobby'en bij IBM om domino op meerdere platformen te ondersteunen.
Suc6
  • pienk
Beat schreef op 15 juni 2004 @ 16:38:
Ik heb geprobeerd:
y.
bekijk deze howto eens:
How do you install Domino 6 on a Debian-based Linux?
ik heb dit zel ook geprobeerd en kreeg het werkend
  • pienk
P.S.
de IBM java is moeilijk te krijgen als je hem wil hebben moet je maar even mailen pienk@planet.nl
  • _JGC_
IBM JVM is niet moeilijk te krijgen. Je gaat naar http://www.freshports.org, je zoekt op linux-ibm en vervolgens pak je de 1.4 JDK van IBM eruit. Staat een download URL bij, daar ga je heen, ff registreren bij IBM (je krijgt geen spam van IBM, dus gewoon normaal email adres opgeven is veilig), inloggen, downloaden, klaar.
  • Beat691
Ik ben op zoel naar IBM JRE-1.3.1, weet iemand waar ik die kan downloaden.. is niet te vinden op google :(
  • Beat691
Gevonden....
maar ook dit haalt weer niets uit :(
ik geef het op!!! laat maar lekker zitten dat domino, ik installeer wel echte software :)
