[fed2] gcc gezeur
  • 126 views sinds 30-01-2008
  • simon
  • Laatst online: 12:12
Beste luitjes,
ja ik kom weer zeiken :P M'n gcc doet 't niet, elke keer als ik wil compilen krijg ik deze error:
checking how to run the C preprocessor... /lib/cpp
configure: error: C preprocessor "/lib/cpp" fails sanity check
See `config.log' for more details.
make: *** [configure-gcc] Fout 1
met als config.log:
29
30
31
32
33
34
35
36
37
38
39
40
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
configure:581: checking host system type
configure:602: checking target system type
configure:620: checking build system type
configure:675: checking for a BSD compatible install
configure:2844: checking for i686-pc-linux-gnulibc1-ar
configure:2877: checking for ar
configure:2916: checking for i686-pc-linux-gnulibc1-as
configure:2949: checking for as
configure:2988: checking for i686-pc-linux-gnulibc1-dlltool
configure:3021: checking for dlltool
configure:3060: checking for i686-pc-linux-gnulibc1-ld
configure:3093: checking for ld
configure:3132: checking for i686-pc-linux-gnulibc1-nm
configure:3165: checking for nm
configure:3204: checking for i686-pc-linux-gnulibc1-ranlib
configure:3237: checking for ranlib
configure:3276: checking for i686-pc-linux-gnulibc1-windres
configure:3309: checking for windres
configure:3348: checking for i686-pc-linux-gnulibc1-objcopy
configure:3381: checking for objcopy
configure:3420: checking for i686-pc-linux-gnulibc1-objdump
configure:3453: checking for objdump
configure:3502: checking for i686-pc-linux-gnulibc1-ar
configure:3535: checking for ar
configure:3574: checking for i686-pc-linux-gnulibc1-as
configure:3607: checking for as
configure:3646: checking for i686-pc-linux-gnulibc1-dlltool
configure:3679: checking for dlltool
configure:3718: checking for i686-pc-linux-gnulibc1-ld
configure:3751: checking for ld
configure:3790: checking for i686-pc-linux-gnulibc1-nm
configure:3823: checking for nm
configure:3862: checking for i686-pc-linux-gnulibc1-ranlib
configure:3895: checking for ranlib
configure:3934: checking for i686-pc-linux-gnulibc1-windres
configure:3967: checking for windres
configure:4034: checking whether to enable maintainer-specific portions of Makefiles
Ik heb een rpm van cpp gedownload, maar die wou niet installen.
Iemand raad?
  • XTerm
  • Laatst online: 10-06-2025
Je hebt een RPM gedownload van cpp maar die wou niet installen en TOCH *hoop* je dattie er wel is ?
Begin bij het begin en probeer niet te vliegen voor je kan wandelen :)
  • MadCow*
  • Laatst online: 05-08-2025
MadCow*
<= icon space for rent
Oh deze vage melding ..
Deze heb ik ook eens gehad, had cpp geinstalleerd maar kreeg nog steeds die gekke melding.
Ik geloof dat ik het opgelost heb door g++ te installeren.
Veni, Vidi, Et je n'en crois pas mes yeux! (ik kwam, ik zag, en ik geloofde mijn ogen niet!) - J. Caesar (Asterix en de gladiatoren) | Nu vernieuwd met toegevoegde lazyness.
  • DAzN
MadCow schreef op 07 juni 2004 @ 13:55:
LOL :)
@ts waarin gebruik je geen yum?
$ yum install cpp
[ Voor 5% gewijzigd door DAzN op 07-06-2004 19:12 ]
  • simon
checking for gcc option to accept ANSI C... none needed
na wat spelen met yum, nog neits verder :P
Verder heeft g++ geen zin... Btw, dat yum is een erg leuke tool :P
  • simon
* kick *
rpm's installen mag dan wel leuk zijn, maar ik wil ook kunnen compilen :P
  • Wilke
  • Laatst online: 11:03
Ik kan me niet voorstellen dat dit de hele inhoud van config.log is, dit zijn lijkt me alleen de eerste regels. Het gaat juist om de laatste 50 ofzo.
De sanity check test of de compiler waarmee je je programma compileert de zelfde versie is als die waarmee je kernel gecompileerd is. Je hebt dus ofwel een custom kernel geïnstalleerd, ofwel je gcc gedowngraded naar een oude versie, ofwel geen kernel headers geïnstalleerd (dat laatste is het meest waarschijnlijk).
  • active2
  • Laatst online: 26-10-2024
active2
Google is your friend
DAzN schreef op 07 juni 2004 @ 19:11:
LOL :)
$ yum install cpp
ik denk niet dat onze FreeBSD goeroe yum gaat gebruiken ;)
Google, Het mirakel van de 21e eeuw!!!!
  • MadCow*
MadCow*
active2 schreef op 09 juni 2004 @ 19:15:
*proest*
Even voor de goede orde.
Ik kwam die melding tegen toen ik op mijn sparc64 bak met debian aan het knoeien was O-).
  • simon
Wilke schreef op 09 juni 2004 @ 17:22:
Dat verbaasde me dus ook, geen logs van errors ofzo :?
Maar die headers, hoe installeer ik die? Staan ze ook op rpm-find? Ik kan namelijk niet echt compilen nu :P
[ Voor 16% gewijzigd door simon op 09-06-2004 21:03 ]
Simon schreef op 09 juni 2004 @ 20:59:
Die file heet glibc-kernheaders-<cijfertjes>.i386.rpm en staat op je fedora cds/dvd. Ik weet niet precies welke cijfertjes want ik draai geen Core 2.
