Probleem met ZENworks4
Ik zit met het volgende probleem, ik wil namelijk gaan zenimagen. Maar ik krijg de volgende foutmelding:
*****(1)***** 07-06-04 09:35:26
WSREG-v3.0 This log file is reporting activity on a WM_SERVICE_START_EVENT event.
WSREG-v3.0 While contacting the Work Station Import Service, an error -1 was encountered, and error description <Winsock gethostbyname() failed.> was reported.
WSREG-v3.0 Registration will not occur for this event.
WSREG-v3.0 The program finished running.
*****(2)***** 07-06-04 09:36:45
WSREG-v3.0 This log file is reporting activity on a WM_USER_LOGIN_EVENT event.
*****(3)***** 07-06-04 09:37:46
WSREG-v3.0 This log file is reporting activity on a WM_USER_LOGOUT_EVENT event.
*****(4)***** 07-06-04 09:38:39
Dit staat in de wsreg.log file.
Wat heb ik gedaan...
1) nieuwe kabel gepakt (leek me al onwaarschijnlijk, en dat was het dus ook)
2) Internet gezocht, novell en google kon niets vinden :(
Hoop dat iemand van jullie weet was ik hier aan kan doen, of mogelijk een paar goede tips voor mij heeft.
This error is indicative of WSREG32 not being able to find the import server. It is important that you are using the correct client. If you are running zfd3.2Sp1 you need Client 4.83Sp1. Also, I have found that the most definite way to get your workstations registered and imported, is to add a key to the registry:
HKLM\Software\Novell\Workstation Manager\Import Server and for the value, input the IP of ther import server. You can send this key out via NALExpld. This has proven to be foolproof and very accurate. If, for example you don't want a particular workstation or group of workstations or workstations in a particular container to be imported, make sure they don't get the key. Also, with this key you don't need to use the host file or DNS for workstation registration.
I actually have resolved this issue by specifying the importserver ip in the users script for example:
#wsreg32.exe -s=10.100.10.5
this runs the wsreg32,exe -s= (wsreg server =) then the IP or DNS of the server.
I prefe this solution. You can centerally administer the ip if necessary and you don't have to touch each machine individually.
http://support.novell.com...archtid.cgi?/10065224.htm
[ Voor 3% gewijzigd door Verwijderd op 15-08-2004 15:34 ]
Het ligt iig niet aan de clientversie, heb 4.9 met sp1a.
Ik ben vervolgens naar het register gegaan zie plaatje..
http://members.lycos.nl/mistahbacardi/regedit.JPG
ik zie hier niet de map import server staan, of hoeft die er ook niet testaan maar is dat dan de register key die ik moet aanmaken.
En als ik deze moet aanmaken wat voor soort sleutel moet het worden dan'?
*sleutel
*tekenreedswaarde
*binaire waarde
*DWORD-waarde
*waarde met meerdere tekenreeksen
*waarde met uitbreidbare tekenreeksen
Overigens ik kan zenwsimport wel pingen!!
  • Jaymz
  • Laatst online: 23:13
Jaymz
Keep on moving !
Draait daar wel de Workstation Import Service ? :)
Je kan proberen het Loglevel op verbose te zetten: HKLM/Software/Novell/ZENworks/zenwsreg: LogLevel (Dword)=2
Workstation Import Service die draait wel jah ;)
Maar oke ik zou eens even proberen op verbose te zetten
