[MSN Messenger] - Loopt vast na inloggen
  • Killkees
  • Laatst online: 29-05-2025
Killkees
bloemetjes en bijtjes enzo
Sinds vandaag loopt msn messenger plotseling vast na het inloggen. Heb inmiddels al van alles geprobeerd.
- Opnieuw installeren
- Alle registry verwijderingen verwijderd
- Gecheckt op virussen
- Gezocht op GOT
- Gezocht op microsoft.com (KB & Fora)
Ik weet het niet meer.... :'(
O ja, ik zit op een netwerk met drie pc's. Twee ervan hebben dit probleem, de derde doet het wel gewoon. :?
Iemand?
Wat heb ik onder meer geprobeerd:
You must be logged on as an Administrator
> > In Control Panel, double-click Networking and Internet
> > Connections, and then click Network Connections
> > Right-click on the internet connection you would like to
> > enable ICF to, and then click Properties.
> > On the Advanced tab, click the box to select the option to
> > Protect my computer or network
> > Click OK
> > then make sure u update and run ur anti-virus scanner. u
> > probably have the MSBLAST worm cuz when u reinstall XP it
> > deleted all ur updates. So ur antivirus program should
> > find it and delete it. (if it can't delete it u need to
> > DISABLE system restore then run antivirus scanner).
> > THen go here:
> > http://windowsupdate.microsoft.com
> > If a security certificate pops up then click "YES"
> > Click on "SCAN NOW" then choose your operating System
> > Download all the "CRITICAL UPDATES AND SERVICE PACKS"
> > Now do this:
> > 1.Exit MSN Messenger Program completely
> > 2.Click on Start, then Run, type: "regedit" (Without
> > Quotes)
> > 3.Navigate to
> > MyComputer\HKEY_CURRENT_USER\Software\Microsoft\MSNMessenge
> > r
> > 4.Click the MSN Messenger Key (Click Once). Go to the Edit
> > menu and select Delete
> > 5.Delete the MSN Messenger folder from c:\Program Files
> > (Replace C: with your system disk if it is something other
> > than C)
> > 6.Install MSN MESSENGER
> > after doing all of these things MSN MESSENGER will work
> > again. Don't SKIP any of these steps. it's crucial u do
> > all of them in order.(top to bottom)
[ Voor 69% gewijzigd door Killkees op 01-06-2004 20:40 . Reden: extra info ]
  • Max|Burn
  • Laatst online: 22-09 11:51
Max|Burn
Dat MSN echt compleet vastloopt zie ik niet vaak...
wat hebben de 2 pc's gemeen dat ze er allebij tegelijk dezelfde problemen krijgen?
ma ma ma ma ma macron one
  • Reptile209
  • Laatst online: 22:57
Reptile209
- gers -
Wat is je OS? Loopt Messenger vast, of stopt het inloggen gewoon? Kloppen datum en tijd op beide PC's? Kan je op beide PC's wel op bijvoorbeeld hotmail inloggen met hetzelfde passport? Welke MSN-Messenger-versies gebruik je?
Zo scherp als een voetbal!
  • Killkees
Killkees
Zijn allebei Compaq's ;)
Draaien allebei Windows XP Home (de derde waarschijnlijk XP Prof).
De een is een laptop en de ander een (oude) desktop. Dus niet echt heel overeenkomsten verder...
Beide pc's draaien MSN 6.2
De datum en tijd kloppen.
Op de laptop was het niet mogelijk om bij hotmail in te loggen, inmiddels wel.
Bij de desktop is het wel prima mogelijk om in te loggen bij hotmail
De desktop heeft als bijkomend probleem dat Outlook (XP) ook niet meer werkt...
Hij logt dus wel gewoon in op de messenger service, maar meteen daarna loopt het programma vast.
ps. Windows Messenger werkt wel gewoon.
[ Voor 57% gewijzigd door Killkees op 01-06-2004 21:07 ]
Ik heb vandaag het zelfde gehad. en nu nog steeds. Woon nu sinds twee dagen in frankrijk. Vanochtend perfect kunnen msne met versie 6.2 maar nu na de middag kan ik niet meer inlogge.... Zijn de servers down of ligt het bij mij?
  • Killkees
Killkees
Even ter afronding; het werkt weer naar behoren. Na een aantal keer zowel de router als modem te hebben gereset kreeg ik alles zowaar weer aan de praat.
