[Debian SID] make menuconfig / xconfig errors
  • 81 views sinds 30-01-2008
ik wil graag een nieuwe kernel compilen omdat de nvidia drivers niet werken met de 2.6 kernels die je kan apt-getten , nu heb ik kernel-source-2.6.6 gedownload, link gemaakt naar de linux directory , echter bij make menuconfig krijg ik deze error.
phex:/usr/src/linux# make menuconfig
HOSTCC scripts/basic/fixdep
scripts/basic/fixdep.c:97:23: sys/types.h: No such file or directory
scripts/basic/fixdep.c:98:22: sys/stat.h: No such file or directory
scripts/basic/fixdep.c:99:22: sys/mman.h: No such file or directory
scripts/basic/fixdep.c:100:20: unistd.h: No such file or directory
scripts/basic/fixdep.c:101:19: fcntl.h: No such file or directory
scripts/basic/fixdep.c:102:20: string.h: No such file or directory
scripts/basic/fixdep.c:103:20: stdlib.h: No such file or directory
scripts/basic/fixdep.c:104:19: stdio.h: No such file or directory
In file included from /usr/lib/gcc-lib/i486-linux/3.3.3/include/syslimits.h:7,
from /usr/lib/gcc-lib/i486-linux/3.3.3/include/limits.h:11,
from scripts/basic/fixdep.c:105:
/usr/lib/gcc-lib/i486-linux/3.3.3/include/limits.h:122:75: limits.h: No such file or directory
scripts/basic/fixdep.c:106:19: ctype.h: No such file or directory
scripts/basic/fixdep.c:107:24: netinet/in.h: No such file or directory
scripts/basic/fixdep.c: In function `usage':
scripts/basic/fixdep.c:121: warning: implicit declaration of function `fprintf'
scripts/basic/fixdep.c:121: error: `stderr' undeclared (first use in this function)
scripts/basic/fixdep.c:121: error: (Each undeclared identifier is reported only once
scripts/basic/fixdep.c:121: error: for each function it appears in.)
scripts/basic/fixdep.c:122: warning: implicit declaration of function `exit'
scripts/basic/fixdep.c: In function `print_cmdline':
scripts/basic/fixdep.c:127: warning: implicit declaration of function `printf'
scripts/basic/fixdep.c: At top level:
scripts/basic/fixdep.c:130: error: `NULL' undeclared here (not in a function)
scripts/basic/fixdep.c: In function `grow_config':
scripts/basic/fixdep.c:143: warning: implicit declaration of function `realloc'
scripts/basic/fixdep.c:143: warning: assignment makes pointer from integer without a cast
scripts/basic/fixdep.c:144: error: `NULL' undeclared (first use in this function)
scripts/basic/fixdep.c:145: warning: implicit declaration of function `perror'
scripts/basic/fixdep.c: In function `is_defined_config':
scripts/basic/fixdep.c:161: warning: implicit declaration of function `memcmp'
scripts/basic/fixdep.c: In function `define_config':
scripts/basic/fixdep.c:174: warning: implicit declaration of function `memcpy'
scripts/basic/fixdep.c: In function `use_config':
scripts/basic/fixdep.c:193: error: `PATH_MAX' undeclared (first use in this function)
scripts/basic/fixdep.c:207: warning: implicit declaration of function `tolower'
scripts/basic/fixdep.c:193: warning: unused variable `s'
scripts/basic/fixdep.c:212: error: parse error before "size_t"
scripts/basic/fixdep.c:213: warning: function declaration isn't a prototype
scripts/basic/fixdep.c: In function `parse_config_file':
scripts/basic/fixdep.c:214: error: `map' undeclared (first use in this function)
scripts/basic/fixdep.c:214: error: `len' undeclared (first use in this function)
scripts/basic/fixdep.c:220: warning: implicit declaration of function `ntohl'
scripts/basic/fixdep.c:231: warning: implicit declaration of function `isalnum'
scripts/basic/fixdep.c: In function `strrcmp':
scripts/basic/fixdep.c:244: warning: implicit declaration of function `strlen'
scripts/basic/fixdep.c: In function `do_config_file':
scripts/basic/fixdep.c:255: error: storage size of `st' isn't known
scripts/basic/fixdep.c:259: warning: implicit declaration of function `open'
scripts/basic/fixdep.c:259: error: `O_RDONLY' undeclared (first use in this function)
scripts/basic/fixdep.c:261: error: `stderr' undeclared (first use in this function)
scripts/basic/fixdep.c:265: warning: implicit declaration of function `fstat'
scripts/basic/fixdep.c:267: warning: implicit declaration of function `close'
scripts/basic/fixdep.c:270: warning: implicit declaration of function `mmap'
scripts/basic/fixdep.c:270: error: `NULL' undeclared (first use in this function)
scripts/basic/fixdep.c:270: error: `PROT_READ' undeclared (first use in this function)
scripts/basic/fixdep.c:270: error: `MAP_PRIVATE' undeclared (first use in this function)
scripts/basic/fixdep.c:270: warning: assignment makes pointer from integer without a cast
scripts/basic/fixdep.c:279: warning: implicit declaration of function `munmap'
scripts/basic/fixdep.c:255: warning: unused variable `st'
scripts/basic/fixdep.c:284: error: parse error before "size_t"
scripts/basic/fixdep.c:285: warning: function declaration isn't a prototype
scripts/basic/fixdep.c: In function `parse_dep_file':
scripts/basic/fixdep.c:286: error: `map' undeclared (first use in this function)
scripts/basic/fixdep.c:287: error: `len' undeclared (first use in this function)
scripts/basic/fixdep.c:289: error: `PATH_MAX' undeclared (first use in this function)
scripts/basic/fixdep.c:291: warning: implicit declaration of function `strchr'
scripts/basic/fixdep.c:293: error: `stderr' undeclared (first use in this function)
scripts/basic/fixdep.c:289: warning: unused variable `s'
scripts/basic/fixdep.c: In function `print_deps':
scripts/basic/fixdep.c:325: error: storage size of `st' isn't known
scripts/basic/fixdep.c:329: error: `O_RDONLY' undeclared (first use in this function)
scripts/basic/fixdep.c:331: error: `stderr' undeclared (first use in this function)
scripts/basic/fixdep.c:341: error: `NULL' undeclared (first use in this function)
scripts/basic/fixdep.c:341: error: `PROT_READ' undeclared (first use in this function)
scripts/basic/fixdep.c:341: error: `MAP_PRIVATE' undeclared (first use in this function)
scripts/basic/fixdep.c:341: warning: assignment makes pointer from integer without a cast
scripts/basic/fixdep.c:325: warning: unused variable `st'
scripts/basic/fixdep.c: In function `traps':
scripts/basic/fixdep.c:360: error: `stderr' undeclared (first use in this function)
make[1]: *** [scripts/basic/fixdep] Error 1
make: *** [scripts_basic] Error 2
ik heb in het verleden regelmatig kernels compiled, maar deze waslijst aan errors ben ik nog nooit tegen gekomen :(
  • PowerSp00n
  • Laatst online: 06-09 05:43
PowerSp00n
There is no spoon
Zoeken, zowel op GoT (waar ik het vaker heb langs zien komen) als met Google.
  • M-ThijZ
  • Laatst online: 22:29
M-ThijZ
Riding on Rails
Je hebt je GCC libs niet compleet, dus hij kan geen C compilen. Die errors zijn van gedeeltes die hij niet kan vinden/uitvoeren.
zowiets had ik tenminste in gedachten
  • Zwerver
Dit vind ik nou jammer, van iemand met zoveel posts had ik wel verwacht dat ie weet dat ie eerst even moet zoeken... De reactie hier boven mij kreeg ik zo uit google... Dus dit had je zelf wel kunnen vinden.
@powerspoon: Dat soort reacties doe je maar met een TR. En als je wil weten waarom, neem dan even Policy mbt replies in 'slechte' topics door
Lees voordat je een nieuw topic opent ook even de NOS policy - updated 01/04/03 en de FAQ Non-Windows Operating Systems - update: 08/04/2004 door.
Woonachtig Down Under. Ik negeer je insults niet, maar tegen de tijd dat ik ze lees zijn ze meestal niet relevant meer
