[W2K3 Server] Langzaam opstarten
Mensen,
Het duurt inmens lang bij het opstarten (5 a 6 minuten), de applying policies, network connections scherm. daarna komt ie met deze error waarna ik verder kan inloggen.
Error:
(At least one service or driver failed during system startup. Use Event viewer to examine the event log for details.)
Als ik kijk bij de event viewer kijk zie ik deze errors:
Error 1
The Net Logon service hung on starting.
Error 2
The DNS Server service hung on starting.
Error 3
The Windows Time service hung on starting.
Error 4
The DNS server has encountered a critical error from the Active Directory. Check that the Active Directory is functioning properly. The extended error debug information (which may be empty) is "". The event data contains the error.
Error 5
The DNS server was unable to complete directory service enumeration of zone _msdcs.solid-00001.runeblade.demon.nl. This DNS server is configured to use information obtained from Active Directory for this zone and is unable to load the zone without it. Check that the Active Directory is functioning properly and repeat enumeration of the zone. The extended error debug information (which may be empty) is "". The event data contains the error.
Error 6
The DNS server was unable to complete directory service enumeration of zone solid-00001.runeblade.demon.nl. This DNS server is configured to use information obtained from Active Directory for this zone and is unable to load the zone without it. Check that the Active Directory is functioning properly and repeat enumeration of the zone. The extended error debug information (which may be empty) is "". The event data contains the error.
Error 7
The DNS server was unable to initialize Active Directory security interfaces. Check that the Active Directory is functioning properly and restart the DNS server. The event data contains the error.
In principe kan ik dan gewoon alles doen, users aanmaken etc.
Ik heb her en der gezocht op het forum maar geen enkele topic kwam met de oplossing, tot nu toe. Ik heb wel gelezen dat het dns gerelateerd zou kunnen zijn, dus heb ik daar ook weer een paar screenie's van:
DNS Screenie 1
Bij forwarders heb ik de dns servers van m'n providers gezet.
DNS Screenie 2
Ik kan deze wel proberen te uitleggen maar dat gaat me niet lukken.
En ik heb mezelf ook als dns server gezet onder de tcp/ip properties
Bij tcp/ip properties van m'n netwerk kaart staat de (mijn) server als enige in de lijst voor dns servers.
Hier is een hardware list van m'n computer
AMD 64 3200+
20gb western digital
120gb seagate
GeForce 4 Ti 4200
Pioneer DVD-ROM DVD-106
Pioneer DVD-RW DVR-106D
1394 Firewire onboard
Realtek RTL8139 10/100 mbit NIC
Realtek RTL8169/8110 Gigabit NIC
verder weinig andere dingen echt van belang, anders zie screenshot.
Als jullie kunnen helpen, graag,
Greets,
Rune
P.s. zo heb 't zo gecorrigeerd dat mensen 't later ook terug kunnen vinden mocht ik de plaatjes ooit weghalen.
[ Voor 43% gewijzigd door Verwijderd op 31-05-2004 17:49 ]
  • mutsje
  • Laatst online: 26-08 10:05
mutsje
Certified Prutser
Verwijst de DC waar DNS opdraait naar zich zelf in jou TCP/IP properties. Anders loopt je server eerst het netwerk af te pollen opzoek naar zichzelf namelijk. Ook heb je er al aangedacht om dns diag enzo te draaien.
  • F_J_K
F_J_K
Moderator CSA/PB/AI
Front verplichte underscores
En terwijl je dat doorzoekt: zou je de errors even kunnen uitschrijven cq. copypasten ipv ze zo te linken ajb? Je hebt ze toch al in google ingetypt, zijn ze makkelijk hier te zetten zodat een volgende user dit topc in de search vind en er nog wat aan heeft als je de pics van je site verwijderd hebt :*
Heel erg offtopic: en je site is wel erg IE-only... :X
  • alt-92
alt-92
ye olde farte
mutsje schreef op 31 mei 2004 @ 17:18:
Heeft-ie idd, staat alleen in screenshot (helaas).
F_J_K schreef op 31 mei 2004 @ 17:32:
Hey, dit is WOS.
Wat had je anders verwacht? :P
zo heb de eerste post beetje aangepast....
ja de meeste dingen verwijzen naar windows 2000 server en helpen me niet echt :'( dus...
overigens moet ik er wel bij vertellen, w2003 server is pas zo langzaam geworden nadat ik 'm naar een pdc heb gepromote, stand-alone zegmaar is ie perfect en snel.. maarja da's niet echt de bedoeling van een server, niet?
heb dns diag gedaan maar er gebeurde niks....
[ Voor 9% gewijzigd door Verwijderd op 31-05-2004 17:54 ]
nog een beetje geneuzeld op google en de microsoft site.
die linkte me uiteindelijk naar dcdiag.exe en naar netdiag.exe.
heb ze allebij uitgevoerd en ze kwamen allebij zonder foutmeldingen terug.
verder nog iemand ideeën?
  • Razwer
  • Laatst online: 24-08 08:31
je probleem is dat je naar een internet DNS verwijst met je domein en je DC DNS server het probeert te beheren terwijl demon dit domein beheert. uninstall AD en reinstall AD met bijvoorbeeld runeblade.local als domein. Dan heb je geen problemen meer.
Newton's 3rd law of motion. Amateur moraalridder.
