[DPAD] hitparade van 26 mei Vorige deel Overzicht Volgende deel Laatste deel
  • 168 views sinds 30-01-2008
  • Pim.
  • Registratie: Mei 2001
  • Laatst online: 13-11 02:01
Pim.
Aut viam inveniam, aut faciam
Er zijn weer stats, al moet je natuurlijk niet te veel op de pijltjes letten ;)
5 flushers vandaag die voor een 7de plek daily zorgen, dit kan toch wel beter lui ???????
DPAD hitparade van 26 mei 2004
Top 30
1.(+)15.222TeamNWW21.946.787(1)
2.(+)6.339Supersymmetry4.587.411(10)
3.(+)1.280ZeRoC00L1.057.408(18)
4.(+)441Xanathorn2.226.590(14)
5.(+)57McPhisto2.184.995(15)
Overall top 30
1.(=)21.946.787TeamNWW15.222(1)
2.(=)13.211.356HekjeLindon0
3.(=)12.568.312NEC0
4.(=)11.340.329BurnHard0
5.(=)10.843.454DemerZel0
6.(=)7.253.389Alphen0
7.(=)6.691.798Team WAU0
8.(=)4.681.231Noon0
9.(=)4.657.093Decs0
10.(=)4.587.411Supersymmetry6.339(2)
11.(=)4.015.541White Panther0
12.(=)3.758.136Jiriki0
13.(=)2.872.540mSW0
14.(=)2.226.590Xanathorn441(4)
15.(=)2.184.995McPhisto57(5)
16.(=)1.484.936fenrir0
17.(=)1.389.894xillius0
18.(=)1.057.408ZeRoC00L1.280(3)
19.(=)859.128Speedy J0
20.(=)827.914Team ColdFusion0
21.(=)824.963Mito0
22.(=)581.442HAL90000
23.(=)533.122Squirtle0
24.(=)525.420Kr3Kr0
25.(=)519.663Kippie0
26.(=)513.088CubicQ0
27.(=)450.271Meloentje0
28.(=)418.672knutselsmurf0
29.(=)412.581NGS~Tube0
30.(=)402.991Nightmare0
Top 15 teams
1.(+)921.225Team Anandtech255.998.751(1)
2.(+)299.556US-Distributed144.184.853(2)
3.(+)228.334SETI.Germany137.551.332(3)
4.(+)92.362Overclockers Australia65.413.579(6)
5.(+)41.292Team China3.186.928(13)
6.(+)26.381Team Ninja32.131.940(7)
7.(+)23.341Dutch Power Cows126.943.450(4)
8.(+)14.268Romulus223.651.249(8)
9.(+)8.087ARS Technica - Team Atomic Milkshake18.354.341(9)
10.(+)2.992VGD.ORG9.787.971(11)
11.(+)1.471www.2CPU.com3.069.270(15)
Overall top 15 teams
1.(=)255.998.751Team Anandtech921.225(1)
2.(=)144.184.853US-Distributed299.556(2)
3.(=)137.551.332SETI.Germany228.334(3)
4.(=)126.943.450Dutch Power Cows23.341(7)
5.(=)66.518.683[AVE]0
6.(=)65.413.579Overclockers Australia92.362(4)
7.(=)32.131.940Team Ninja26.381(6)
8.(=)23.651.249Romulus214.268(8)
9.(=)18.354.341ARS Technica - Team Atomic Milkshake8.087(9)
10.(=)10.402.674Terrene Bell0
11.(=)9.787.971VGD.ORG2.992(10)
12.(=)4.249.766AMD Users0
13.(=)3.186.928Team China41.292(5)
14.(=)3.105.561Team-TNT0
15.(=)3.069.270www.2CPU.com1.471(11)
Leden
Aantal leden61
Verschil met vorige dag0
Nieuwe leden0
Retirements0
Huh?? Niemand joinde gisteren DPC!!! Boehoehoehoeeeee.... :'(
"The trouble with quotes from the Internet is that you can never know if they are genuine." - Elvis Presley | Niet met me eens ? DM ME
  • Meloentje
Meloentje
Switcher
Ik heb sinds de vorige dpch ook nog wat geflushed. :?
Het zal waarschijnlijk wel eergisteren zijn geweest dat ik dat heb gedaan. 8)7
Programmeren is net als spelen met Lego, alleen maak ik mijn eigen Lego stenen.
Ik heb een probleem hier, ik heb 2 pentium 4 pc's die staan te crunchen, in een middagje had ik 6000 punten bij elkaar gecruncht, nu 2 dagen later heb ik nog steeds 6000, er is geen enkele muon erbij gekomen, terwijl muon gewoon staat te crunchen zoals altijd, ik heb de clients ook al gerestart maar dat heeft ook niet geholpen, weet iemand mischien wat er aan de hand kan zijn? ik gebruik de v434 client.
  • Pyrus
  • Laatst online: 16-11 20:32
Pyrus
Hardknock life
Om de hoeveel dingetjes (wu's? muons? of hoe heten die dingen hier? :X) flushtie automagisch?
Enne, hij roept iets dat latticelist.txt ouder dan 12 uur is en gaat vervolgens proberen een nieuwe te downloaden wat niet lukt. Is gewoon met kladblok openen en opslaan daar een goede oplossing voor of moet ik dan toch wat anders doen? :P
LinkedIn
Probeer eens de laatste versie.. we zijn intussen bij 4.41.. de 4.41 doet een aantal nieuwe dingen t.o.v de ouwe 4.34.. in de 4.4 zat helaas een bug (in de lattice files.. dus Stephen Brooks heeft het nu dus zo geregeld dat er 'B' versie lattice files gedownload worden.. en die doen het niet op 4.34 en 4.4)
TIP:
Donder ALLES weg van je oude versie (behalve eventueel de user.txt) en laat em lekker opnieuw beginnen..
[ Voor 18% gewijzigd door Verwijderd op 27-05-2004 15:44 ]
Meloentje schreef op 27 mei 2004 @ 14:17:
Ik heb hetzelfde probleem... Ik denk/hoop dat de stats morgen wel goed zijn. Zelf heb ik de afgelopen dagen ook wat geflushed. Misschien dat Onno alleen punten in de stats heeft verwerkt die zijn geflushed nadat de statsfile weer werd geupdated.
Verwijderd schreef op 27 mei 2004 @ 15:04:
Dit is een vreemd probleem. Welke client gebruik je? Als je de commandline client gebruikt en je ziet em nog 'tellen' , dan lijkt me dat je precies 6000Mpts na het flushen van results.txt weer kijkt. Kan dat? (Het zou heel toevallig zijn, maar ik heb geen andere verklaring.)
Pyrus schreef op 27 mei 2004 @ 15:25:
Ik heb hetzelfde probleem. Ik heb het zelf nog niet geprobeerd (ga ik vanmiddag doen), maar zet download-lattices optie in config.txt uit. Het lijkt me dat je dan van het probleem af bent.
Edit: Wat Huub zegt is ook een oplossing. Zelf heb ik de laatste versie nog niet geprobeerd (d8 dat er nog wat bugjes in zaten, maar zal het vanmiddag eens proberen.)
[ Voor 5% gewijzigd door Verwijderd op 27-05-2004 15:45 ]
  • Meloentje
Meloentje
Switcher
Muon1 flushed meen ik wanneer de results.txt 100kB groot is.
Tenzij je in je config.txt hebt staan:
Auto-send results ([Y]es, [N]o): N
Daarmee geef je aan dat je handmatig wil flushen, wat je weer doet door manualsend.bat uittevoeren.
Het ophalen van die latticelist.txt kun je uitschakelen met deze regel in config.txt:
Update lattice files from web every N hours (0=don't): 0
Hier kun je zelf een lattice file ophalen www.stephenbrooks.org/muon1/lattices
Verwijderd schreef op 27 mei 2004 @ 15:41:
TIP:
Ok zal ik doen, ik krijg de results van 4.34 niet eens geflusht.
Klopt(e).. die zijn er intussen uit.. (ging dus over lattice files die bug.. vandaar alle ellende nu denk ik)
Ik moet trouwens zeggen dat ik blij verrast was deze hitparade tegen te komen.. ik zie hem toevallig in de active topics staan.. Ik dacht dat ze niet meer gepost werden!
[ Voor 23% gewijzigd door Verwijderd op 27-05-2004 15:53 ]
  • Meloentje
Meloentje
Switcher
Het is niet nodig om resultaten van oudere versies wegtegooien.
Versie 4.34 en eerder hadden alleen SolenoidsTo15cm.
De resultaten hiervan moeten gewoon geflushed kunnen worden.
Meloentje schreef op 27 mei 2004 @ 16:23:
Dat KAN wel.. maar dan moet je zorgen dat je de lattice files van desbetreffende versies hebt staan.. updaten van de lattice files in de config uit zetten.. en dan moet het (dacht ik) wel lukken..
TIP (nummer 2 van vandaag):
ALTIJD flushen voor je van versie veranderd..
Ik heb nu overal 4.41 client draaien, nu krijg ik wel weer results, hoop alleen dat hij het blijft doen, want 4.34 deed het in het begin ook goed.
