Ik wilde me dit ding gaan kopen, omdat er hij overal in de prijslijsten staat als switch. Echter op de duitse site van Longshine hebben ze het zelf over een switching hub, maar als ik lees wat ie doet lijkt het meer op een echte switch. Hij kost slechts 157DM!!! Kent iemand dit apparaat en is het wat? maar belangrijker, is dit nu wel een echte switch????
Meer info zie:
http://www.longshine.de/produkt/switches/sw500m1.htm
Hier volgt de info van dit internet adres:
Longshine Fast Ethernet Solutions
Longshines 10/100m Mbps Desktop Fast Ethernet Switch LCS-883R-SW500M+
The Longshine LCS-883R-SW500M Ethernet switch is a powerful, high-performance Fast Ethernet switching Hub, with all 5 ports capable of 10 or 100Mbps auto-negotiation operation (N-Way) which means the switch could automatically negotiate with the connected partners on the network speed and duplex mode. It is ideal for micro-segmenting large networks into smaller, connected subnets for improved performance, enabling the bandwidth demanding multimedia and imaging applications. Moreover, the 10/100 Mbps auto-sensing ability provides an easy way to migrate 10Mbps to 100Mbps network with no pain. Compared to the shared 10Mbps or 100Mbps networks, the switching hub delivers a dedicated 10/100mbps connection to every attached client with no bandwidth congestion issue.
Store-and-forward switching mode promises the low latency plus eliminates all the network errors, including runt and CRC error packets. To work under full-duplex mode, transmission and reception of the frames can occur simultaneously without causing collisions as well as double the network bandwidth.
The switching hub is plug-n-play without any software to configure and also fully compliant with all kinds of network protocols. Moreover, the rich diagnostic LEDs on the front-panel for providing the operating status of individual port and whole system.
Key Features
Complies with IEEE 802.3 and IEEE 802.3u standards
Eight 100Base-TX/10Base-T dual speed RJ-45 ports for Fast Ethernet and Ethernet connectivity
Supports Nway protocol for speed (10/100Mbps) and duplex mode (Half/Full) auto-detection
One uplink port for cascading switch to switch or switch to hub with no cross-over cable
Desktop Black Metall case
Supports full duplex or half duplex operation on all ports
Wire-speed packet filtering and forwarding rate
Store-and-forward architecture filters fragment & CRC error packets
Supports 1K MAC address entries in whole system
1Mbytes buffer memory
Supports extensive LED indicators for network diagnostics
Provides external power supply for 100-240 VAC, 5V 2A
FCC, CE, VCCI, UL, CSA and TÜV certification
PRODUCT SPECIFICATION
Standard
Interface
RJ-45 x 5 Nway switching ports, One uplink port (an alternative to port 1)
Cable Connections
RJ-45 (10Base-T): UTP Category 3,4,5
RJ-45 (100Base-TX): UTP Category 5
Network Data Rate
Auto-negotiation (10Mbps, 100Mbps)
Transmission Mode
Auto-negotiation (Full-Duplex, Half-Duplex)
Sytem Buffer Memory
1MByte
MAC address Table
1K entries
Filtering/Forwarding Rate
10Mbps: 14.880pps/14.880pps
100Mbps: 148.800pps/148.800pps
LED indicators
Power, Link/Activity, Full duplex/Collision, Speed
Emission/Safety
FCC, CE, VCCI, UL, CSA, TÜV
Operating Temperature
0° C - 55° C
Operating Humidity
10% - 90% (non-condensing)
Dimensions
146 x 116 x 30 mm
Meer info zie:
Key Features
Standard
Interface
Cable Connections
Network Data Rate
Transmission Mode
Sytem Buffer Memory
1MByte
MAC address Table
1K entries
LED indicators
Emission/Safety
0° C - 55° C
Operating Humidity
Dimensions
146 x 116 x 30 mm
