Catalyst Beta 1 voor Windows XP 64 bit voor AMD64
  • 224 views sinds 30-01-2008
  • edward2
  • Laatst online: 31-01 01:56
edward2
Schieten op de beesten
Niet op voorraad.
Dit is een review ervan op amdzone
http://www.amdzone.com/modules.php?...artid=26&page=1
  • edward2
edward2
Niet op voorraad.
  • SpankmasterC
  • Laatst online: 11:07
Hier zijn wat scores van het Rage3D forum (NIET met een mobility radeon gedaan)
'AMD 64 3000+, 9800Pro
WinXP32 - Catalyst 4.5
WinXP64 - Beta1
3DMark2003
WinXP32 - 5.835 Pkt
WinXP64 - 5.967 Pkt
3DMark2001
WinXP32 - 17.724 Pkt
WinXP64 - 18.230 Pkt
some scores from someone...'
http://www.rage3d.com/boa....php?s=&threadid=33759836
dit ziet er veelbelovend uit!
  • T.T.
  • Laatst online: 22-01 14:13
T.T.
Sowieso
De "Known Issues" vallen ook erg mee (tenzij je een Mobility 9600/9700 chip hebt):
Note: Users may encounter D3D and OGL performance issues which may be due to lack of 64 bit AGP drivers within the beta version of the operating system. Users should verify whether their system has 64 bit AGP drivers installed. If you require AGP drivers, you should contact the AGP chipset vendors or motherboard manufacturers.
• Running 3DLabs sample X29.exe under XP 64 AMD with an ATI FireGL X2 board installed results in the sample using Microsoft software OpenGL
• Direct 3D performance issues are noticed when running applications such as; 3DMark2001SE, 3DMark2003, Serious Sam 2, and AquaMark. under XP 64 AMD with an ATI MOBILITY RADEON 9600/9700 series installed
• OpenGL performance issues are noticed when running applications such as; Serious Sam 2, and Quake 3. under XP 64 AMD with an ATI MOBILITY RADEON 9600/9700 series installed
• Having the option Link Time Code Generation enabled results in an error message indicating that there is Insufficient Destination Size for Storage
• Entering the display properties and unchecking the option to Use DDC Information results in a dialog box being displayed indication Run a DLL as an App has encountered a problem and needs to close
• Entering S3 or S4 power state under a Windows XP64 system results in a machine check error message being displayed
• Installing the ATI software driver under Windows XP64 AMD results in the TV option tab not being displayed
