SOHO fur Fusion
Ik ben sinds kort de bezitter van deze barebone
Fur Fusion H845E 'SOHO'
Barebones Specification
Fur Fusion H845E
Spec Description
Design ATX Form Factor (17.5x24)
Chipset Intel 845GE Graphics Memory Controller Hub (GMCH)
Intel 82801DB I/O Controller Hub (ICH4) Chipset
CPU Socket Support Intel P4 478 Pin package (Flip-Chip)
Pin Grid Array (FC-PGA2) package
Support 400 & 533 FSB
Support 1.5-3.06G Processors with Hyperthreading
Memory Socket 184-pin DDR SDRAM module socket x 2
Support DDR266/DDR 333 DDR SDRAM
Expandable to 2.0 gig
Expansion headers and Slots AGP slot x1 for AGP 1.5V standard only, support AGP 2.0 & 4X mode.
32-bit PCI x1
Intergrated IDE Two PCI IDE Controllers support PCI Bus Mastering, ATA PIO/DMA and the ULTRA DMA 33/66/100 functions that deliver the data transfer up to 100 MB/s.
1394 Port VIA VT6307S 1394 Controller chip provided two 1394 device ports support 100/200/400mb bandwidth.
Compliant with IEEE 1294A-2000 standard.
LAN On Board Realtek RTL8101L PCI LAN Controller Chip.
Supports 10/100mb/sec data transfer.
Intergrated VGA Intergrated High Performance and High Quality 3D Accelerator
Support Ultra-AGPII with 2GB/s Bandwidth
Built in 24-bit RAMDAC
Frame buffer size between 8mb and 64 mb
Audio Realtek ALC 650 6-channel AC97' Codec intergrated.
SPDIF-In/ SPDIF-Out Optical support.
Audio driver and utility included
BIOS Award 2MB Flash ROM
Multi I/O PS/2 keyboard and PS/2 Mouse connectors
Floppy drive connector x1
Parallel x1, Serial port headers x 2
USB 2.0 x 4
Audio Connector Line in, Line Out, MIC (all x 2).
review: http://www.walibe.com/reviews-17.html
Ik zelf heb deze (voorlopig) uitgerust met:
PiV 2.53
1 gb ram
2 x hardisk
TI4200 128mb
1 x combi cd-rom re-writer
1 x pci add on 2 x com
- fan voeding vervangen door stille papst
- case fan toegevoegd ook stille papst
Alles draait als een zonnetje Moet nu nog een stille vga koeler vinden die zeer weinig plaats inneemt ...
Iemand enige ervaringen met dit systeem ?
oja gekocht bij conrad opruiming voor 159 euro. Zeer kompleet ding zeker voor de prijs!
Niemand ? Hmm ik geef het (indien dat toegestan word..) 1 shopje.. en anders blijk ik de bezitter van een heel zeldzame barebone 8)
Laatste poging... Iemand ? :X
