ATI Catalyst 4.5
  • 275 views sinds 30-01-2008
Topic op T.net: Driver updates / ATi Catalyst 4.5 final
Release notes
Changelog
Download: * click *
(Display Driver,Control Panel,WDM Capture driver)
* click * (Display driver only)
Fixed in this driver:
Display corruption is no longer seen when applying rotation mode to a secondary monitor
Playing the game Desert Rats vs. Afirka Korps with the game resolution set to 1600x1200 and the desktop display set to 1024x768 32bpp along with Anti-Aliasing set to 4x no longer results in flashing and or corrupt shadows
The game Prince of Persia: Sands of Time no longer fails to play under Windows XP with an ATI RADEON 9100 or 8500 series product installed
Setting the graphics quality to anything higher than Fastest in the game Virtual Skipper 3 no longer results in the operating system failing to respond when the game menu loads
Playing the game Nascar 2003 with the display resolution set to 1280x1024 32bpp no longer results in display corruption being seen
Texture corruption is no longer seen when playing the game Second Life under Windows XP with an ATI RADEON 9800 or 9700 series card installed
Textures are no longer missing when moving the mouse around to change the camera angle in the game Joan of Arc
Intermittent display corruption noticed on the players image with in the game Madden NFL 2004 is now resolved
Playing the game Homeworld 2 under Windows XP with an ATI RADEON 9500 series, 9600 XT, or 9700 series no longer results in the game failing to respond when the shadow option within the game is selected
Missing polygons on the satellite within the main menu is now resolved in the game Hegemonia
A performance decrease is no longer noticed when setting the game option to Perfect in the game IL-2 Sturmovik: Forgotten Battles
Voor de trotse bezitters van bijvoorbeeld van Radeon 9500 zijn er de softmodded drivers.
The softmod enables the four disabled rendering pipelines in the GPU core of Radeon 9500 Non-Pro/9800 SE cards. Patched drivers for Catalyst 3.10 and later also enable overclocking for all Radeon 9000/9200/9600 based cards.
De drivers zijn hier te vinden.
Wie heeft deze drivers al gebenched?
[ Voor 11% gewijzigd door Verwijderd op 13-05-2004 10:49 ]
  • Remco20
  • Laatst online: 11:58
iemand die het al getest heeft met knights of the old republic ? 4.4 had daar nogal wat probleempjes mee...
edit: lees net op rage3d dat ie er nog steeds is :( beste is om van 4.2 atioglxx.dll te kopieren en de nieuwe daarmee te overschrijven
[ Voor 40% gewijzigd door Remco20 op 13-05-2004 11:46 ]
  • TiMMieJ
  • Laatst online: 13:58
TiMMieJ
PSN: Orixez
Hopen dat nu mijn radeon 9600XT niet meer vastloopt met farcry.
Telkens als ik level 3 ga laden springt mijn monitor op standby en dit heb ik alleen met farcry.
Ik post mijn bevindingen vanmiddag wel als ik weer thuis ben.
performantie blijft nagenoeg dezelfde met de 4.5
ik draai nog steeds zelfde score in aquamark. msschien íets meer, maar het scheelt slechts enkele puntjes
  • Convoy
  • Laatst online: 14:38
Convoy
g44p
ik ben er 400 punten op vooruit gegaan, niet echt schokkend dus ;)
  • Energy99
  • Laatst online: 30-04-2023
Energy99
NRG <3
Ik haal nu met cat4.5 (eerst cat4.4) bijna 10fps gemiddeld meer met FarCry :)
[ Voor 4% gewijzigd door Energy99 op 13-05-2004 14:02 ]
\O/ weeeee =[specs]=
  • Sonic
  • Laatst online: 01-09 13:45
Draait super goed hier! Ben nog geen problemen tegen gekomen.
Games die ik er mee heb gespeeld:
- Battlefield 1942
- Call of Duty
- Colin McRae Rally 04
- Far Cry
- MotoGP2
- Painkiller
- PlanetSide
- Unreal Tournament 2004
Welke drivers gebruik ik best voor een ati radeon mobility 9700?
  • Dax
  • Laatst online: 15:41
Dax
Verwijderd schreef op 13 mei 2004 @ 14:54:
Ik denk de laatste omega's, die hebben ondersteuning voor de mobile gpu's.
http://www.omegacorner.com
  • jelle.
  • Laatst online: 30-08 16:31
3D Mark 2001 SE
Catalyst 4.4 10288
Catalyst 4.5 10619 :9
GA-8STXCFS
Intel P4 @ 2412 Mhz
2 x 256 MB RAM PC2100
Club3D Radeon 9600Pro
WinXP Home Edition [SP 1]
Het is in elk geval een vooruitgang ;)
  • UltimateB
UltimateB
Pomdiedom
TuRk schreef op 13 mei 2004 @ 13:21:
Hmm, ik heb hier geen enkele last van. Ik gebruik omega drivers op het moment (weet niet of ik die gebruikte toen ik met farcry begon).
"True skill is when luck becomes a habit"
SWIS
  • kNarf_
  • Laatst online: 04-09-2024
Overscan werkt nu niet meer goed met m'n tv-out.. en daar baal ik van :(
Ik ben van 6300 naar 6660 punten gegaan, flinke boost dus.
  • MasterFreak
  • Laatst online: 10:15
MasterFreak
Zeker weten!
Verwijderd schreef op 13 mei 2004 @ 21:26:
- Met welke kaart?
- 3Dmark 2001 of 2003
  • Brammel
  • Laatst online: 03:10
Bij mij geen verschil, van 4200 naar 4200 :P
amd 2600, a7n8x, radeon 9700, 512 mb
  • UTM
  • Laatst online: 13:26
UTM
MasterFreak schreef op 13 mei 2004 @ 21:49:
- Met welke kaart?
Te zien aan zijn specs onder zijn naam 3d mark 2003 :)
  • kNarf_
Bij mij ook geen verschil, 3dmark score is volgens mij zelfs lager dan met 4.4 (xp2400, 9800pro)
Maar ik ga ze sowieso niet gebruiken als m'n tv-out niet eens fatsoenlijk werkt.
  • Palomar
hebben jullie ook vaak (bij alle catalyst versies, ene keer wel andere keer niet) dat na de install van de nieuwe driver windows heel traag wordt? (langzaam startmenu, vensters bewegen schokkerig etc.). Driver opnieuw installeren of uit device manager gooien helpt meestal wel, maar het is toch irritant..... (desktop pictogrammen door elkaar door lame 640x480 resolutie enzo)
Iemand een idee hoe ik dit in het vervolg kan voorkomen?
  • Boogieman82
  • Laatst online: 12-11-2025
AMD3000+ @ 2480mhz,1Gb DDR en Hercules 9800xt. Blijf met 4.4 en 4.5 rond de 6600 punten hangen in 3dmark03
specs
  • Palomar
kNarf schreef op 13 mei 2004 @ 21:59:
h eja bij mij krijg ik ook zwarte balkjes boven en onder... overscan werkt niet :(
  • cruger
ja Palomar, heb ik ook last van.
De Omega versies van de drivers hebben dat weer niet.
Na rommelen in al de tabladen en een paar keer rebooten is het over.
Meer dxdiag zul je ook zien dat d3d enz niet geactiveerd is.
Het echte probleem komt er ook niet echt uit, bij het uitproberen van de drivers.
Tweak!
  • Imperium
gewoon ff 10 min wachten.. tot het beeld flikkert.. geduld is moeilijk he? :/
  • Palomar
Imperium schreef op 13 mei 2004 @ 23:54:
als dat de oplossing is, dan heb ik wel ff geduld hoor. Maar hoe moet ik nou weten dat je 10 minuten moet wachten.... :? Zal er de volgende keer ff op letten :)
  • TheLemon
  • Laatst online: 01-07 13:56
TheLemon
daddy cool, crazy like a fool
Van 5250 naar 5300 in 3Dmark2003 en met de Hercules 3D tweaker van 1500 naar 1750!! fps (het voorbeeld-draaidingetje)
Met overgeklokte 9700 np.
In de release notes staat dat je FSAA kan forceren vanaf deze driverversie, maar ik zie er geen extra optie voor in het control panel. Als ik gewoon FSAA hard op 6x zet (dus niet toepassingsgebonden) blijft hij toch uit staan in Far Cry.
Iemand een idee hoe dat in zijn werk gaat?
Ja, ik weet dat dat in Farcry zelf aankan, maar als ik dat doe krijg ik altijd een critical error :( , dus ik had gehoopt dat deze 'forcering' zou helpen
[ Voor 10% gewijzigd door TheLemon op 14-05-2004 00:18 ]
  • MetroidPrime
  • Laatst online: 01-09 00:33
MetroidPrime
Turn it up loud, captain!
Palomar schreef op 13 mei 2004 @ 23:57:
Ik heb het ook, maar het knipperen van het beeld gebeurd net nadat er herkend wordt dat er ViVo-ondersteuning op mijn kaart zit en de drivers daarvoor geinstalleerd worden. Als ik daarna reboot is Windows bij het opstarten weer wel snel.
"Some girl on the street outside the bar just asked me if I was saved yet." "Yeah? What did you say?" "I told her 'I saved at the checkpoint a couple of minutes back and I can reload from there if I die.'
  • Robin
Ik ben echt teruggegaan in het aantal 3DMark2001's: van in de 1800 punten naar de 1300 punten. In 3DMark03 is de pc ook achteruit gegaan, namelijk van in de 70 naar de 50. Het kan aan mij liggen, maar ik ga eens de verschillende soorten Catalyst-drivers aan de tand voelen, want dit is niks.
  • bop
  • Laatst online: 19-08-2024
bop
VisualWeb
Robin Vreuls schreef op 14 mei 2004 @ 00:11:
niet zo heel raar.. ze optimalise voor de 'nieuwere' kaarten.. waarom zouden ze zo een kaar tgaan optimalise (kan je beter oudere drivers gebruiken naar mijn inziens)
doe niet aan signatures.. uhhh, arghhh
  • gwxkil
  • Laatst online: 22-02 21:51
gwxkil
Gelukkig is die vervelende "switch tussen beeldscherm" (alt-F5) -bevestiging (binnen 10 seconden) er weer uitgesloopt, die er sinds Cat 4.2 inzat! Wat was dat vervelend! 8)7
Verder geen performance verschil gemeten.
Specs
  • cruger
ah , met andere woorden na het instaleren van de driver , wachten todat alle "services" goed zijn gestart.
Dat is een nieuw uitgangspunt om te kijken waarom Omega dat anders doet.
Tweak!
  • Madrox
  • Laatst online: 14-08 11:10
Madrox
Oh, Pharaoh!
draaien goed hierzo. Kijken of je 3Dmark scores hoger zijn is aardig maar nutteloos. Die updates zijn zeker ook bedoelt om conflicten met spellen op te lossen; draai je die spellen en! heb je die problemen is een nieuwe driver die dat oplost een verademing, ook al zou je 3Dmark score lager uitvallen. Wat speel je liever, 3Dmark of je spel :?
Voor upgrade, complete zelfbouw, herstellen van windows/software klik hier!
  • Astennu
  • Laatst online: 19-08 17:53
K heb 600 punten meer in 3dmark 2001 met 2x AA en 8x AF aan.
  • n00bs
  • Laatst online: 15:45
n00bs
Het is weer Zomer!
Test het nou met games ipv je blind te staren op 3Dmark ;) en zeker 2001se is nou niet echt de bench om nieuwe kaarten met nieuwe drivers te testen, probeer eens far cry oid
  • TiMMieJ
TiMMieJ
PSN: Orixez
mmm Farcry hangt bij mij nog steeds op het 3e level :(
  • Boogieman82
n00bs schreef op 14 mei 2004 @ 08:52:
Farcry 52fps (alles op het hoogst)
BF-V 100+fps (idem)
[ Voor 5% gewijzigd door Boogieman82 op 14-05-2004 19:58 ]
specs
alles werkt hier goed, nergens last van en farcry loopt
perfect.
  • jelle.
Sinds Catalyst 4.5 is Battlefield Vietnam 2 keer zonder error gecrashed naar de desktop. Dit gebeurt na ongeveer een half uur in-game. Vóór 4.5 had ik nooit problemen met crashes in BFV :/
Nog meer mensen hier last van :?
  • Eindhoven657
  • Laatst online: 11-05-2025
jelleeee schreef op 14 mei 2004 @ 20:41:
Nee juist niet. Met cat4.4 wilde me dat nog wel eens gebeuren maar met 4.5 is BFV bij mij niet meer gecrashed
  • Maverick
  • Laatst online: 15:37
heb na reboot nu de 4.5 drivers, maar ik dacht dat er een nieuwe layout en alles wat? Of is dat een driver doorgeschoven :?
PSN: DutchTrickle PVoutput
  • SideSwipe
  • Laatst online: 13:03
SideSwipe
ZijZweep / SaaitSwiep !
Ik heb tot nu toe nog helemaal geen problemen gehad met 4.5... top :)
Trotse vader x 2!| Profiel volspammen mag hier: Klik
  • Sunrise
  • Laatst online: 27-08 07:42
Werkt bij mij iig goed.
  • jelle.
FunkySmell schreef op 15 mei 2004 @ 21:22:
Hmm, vandaag twee verschillende keren zeker 2 uur gespeeld, zonder crashes :+
