ik weet wel dat in autocad mechanical desktop deze functie er wel inzit... of die bij 2004 erbij zit..... ik zal eens gaan zoeken..
maar ik ben bang van niet
//edit het kan dus wel:
een quote uit de help:
You can extract attribute information from a drawing and create a separate text file for use with database software. This feature is useful for creating parts lists with information already entered in the drawing database. Extracting attribute information does not affect the drawing.
To create a parts list :
- Create and edit an attribute definition
- Enter values for the attributes as you insert the blocks
- Create a template file and then extract attribute information to a text file
To extract attribute information, you first create an attribute template file using any text processor, then generate the attribute extraction file using AutoCAD, and, finally, open the attribute extraction file in a database application. If you plan to extract the attribute information to a DXF (drawing interchange format) file, it is not necessary to first create an attribute template file.
Note Make sure that the attribute extraction file does not have the same name as the attribute template file.
ik heb bij ask gezocht op excel en het topic heet:
extract block attribute data(advanced)
heb het niet helemaal doorgelezen... succes
Voor 80% gewijzigd door
hobbeldebobbel op 11-05-2004 19:54
