[asp] no records found
  • 36 views sinds 30-01-2008
check onderstaand script ::
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
Dim strURL
Dim cnnSearch
Dim rstSearch
Dim strDBPath
Dim strSQL
Dim strSearch
strURL = Request.ServerVariables("URL")
strSearch = Request.QueryString("search")
<font face="Verdana" size="1"><br><b>Zoek op achternaam:</b></font><br>
<form action="<%= strURL %>" method="get">
Achternaam:<br><br>
<input name="search" value="<%= strSearch %>" />
<br><br>
<input type="submit" name="Submit" value="Zoeken" class="borderbutton">
<input type="reset" name="Reset" value="Wissen" class="borderbutton">
</form>
If strSearch <> "" Then
    strDBPath = Server.MapPath("db\database.mdb")
    Set cnnSearch = Server.CreateObject("ADODB.Connection")
    cnnSearch.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & strDBPath & ";"
    strSQL = "SELECT *, dbo_functie.functienaam, dbo_sector.sectornaam, dbo_afdeling.afdelingnaam " _
        & "FROM dbo_sector INNER JOIN (dbo_functie INNER JOIN (dbo_afdeling INNER JOIN dbo_medewerker ON dbo_afdeling.afdelingId = dbo_medewerker.afdelingId) ON dbo_functie.functieId = dbo_medewerker.functieId) ON dbo_sector.sectorId = dbo_medewerker.sectorId " _
                & "WHERE achternaam LIKE '%" & Replace(strSearch, "'", "''") & "%' " _
                & "OR roepnaam LIKE '%" & Replace(strSearch, "'", "''") & "%' " _
        & "ORDER BY achternaam;"
    Set rstSearch = cnnSearch.Execute(strSQL)
If Request.QueryString("search") = "" Then
Response.Write("<b>Sorry, er zijn geen records gevonden.</b>")
Else
Zoekresultaten voor: "<%= strSearch %>"
Do While Not rstSearch.EOF
<table cellspacing=0 cellpadding=0>
<tr>
<td style="height:2" bgcolor="#000000" cellspacing=0 cellpadding=0 width=100%/>
</tr>
</table>
<table border="0" cellspacing="0" cellpadding="0">
  <tr>
    <td><b><font face="Verdana" size="2"><%= rstSearch.Fields("aanhef").Value %>&nbsp<%= rstSearch.Fields("titel").Value %>&nbsp<%= rstSearch.Fields("tussenvoegsel").Value %>&nbsp<%= rstSearch.Fields("achternaam").Value %>,&nbsp<%= rstSearch.Fields("voorletters").Value %></font></b><br>[img]"<%=[/img]" align="left" border="1" bordercolor="#000000"></td>
  </tr>
  <tr>
    <td><table border="0" cellspacing="0" cellpadding="0">
      <tr>
        <td width="100"><font face="Verdana" size="1"><b>Roepnaam:</b></font></td>
        <td width="100"><font face="Verdana" size="1"><%= rstSearch.Fields("roepnaam").Value %></font></td>
      </tr>
      <tr>
        <td width="100"><font face="Verdana" size="1"><b>Functie:</b></font></td>
        <td width="100"><font face="Verdana" size="1"><%= rstSearch.Fields("functienaam").Value %></font></td>
      </tr>
      <tr>
        <td width="100"><font face="Verdana" size="1"><b>Sector/Onderdeel:</b></font></td>
        <td width="100"><font face="Verdana" size="1"><%= rstSearch.Fields("sectornaam").Value %></font></td>
      </tr>
      <tr>
        <td width="100"><font face="Verdana" size="1"><b>Afdeling:</b></font></td>
        <td width="100"><font face="Verdana" size="1"><%= rstSearch.Fields("afdelingnaam").Value %></font></td>
      </tr>
      <tr>
        <td width="100"><font face="Verdana" size="1"><b>Kamernummer:</b></font></td>
        <td width="100"><font face="Verdana" size="1"><%= rstSearch.Fields("kamernummer").Value %></font></td>
      </tr>
      <tr>
        <td width="100"><font face="Verdana" size="1"><b>Telefoon:</b></font></td>
        <td width="100"><font face="Verdana" size="1"><%= rstSearch.Fields("telefoonnummer1").Value %></font></td>
      </tr>
      <tr>
        <td width="100"><font face="Verdana" size="1"><b>E-mail:</b></font></td>
        <td width="100"><font face="Verdana" size="1"><%= rstSearch.Fields("emailadres1").Value %></font></td>
      </tr>
    </table></td>
  </tr><br><br>
        rstSearch.MoveNext
    Loop
    </table>
    rstSearch.Close
    Set rstSearch = Nothing
    cnnSearch.Close
    Set cnnSearch = Nothing
End If
het werkt prima behalve de message "er zijn geen records gevonden" als ik
geen invoer geef. ziet iemand wat ik over het hoofd zie?
  • André
  • Laatst online: 23-10 11:42
André
Analytics dude
Maak van:
dit:
If StrSearch = "" Then
  • gorgi_19
  • Laatst online: 23-10 16:43
gorgi_19
Kruimeltjes zijn weer op :9
Sowieso denk ik dat het logischer is om te testen of rstSearch.EOF waar is of niet / de RecordCount 0 is of niet.
[ Voor 16% gewijzigd door gorgi_19 op 10-05-2004 10:56 ]
Digitaal onderwijsmateriaal, leermateriaal voor hbo
als ik dit toepast volgens andre:
If strSearch = "" Then
Else
krijg ik deze melding als ik een term intyp die echt geen "hit" zal hebben:
If strSearch = "" Then Response.Write("Sorry, er zijn geen records gevonden.") Else Zoekresultaten voor: "sdgsdhhfdhf"
dit zie ik als zoekresultaat...
  • gorgi_19
gorgi_19
Erhm.. :? Gok je dat in Request.QueryString("search") je resultaten van je query gaan staan? :?
  • André
André
Analytics dude
Aha, je wilt die melding alleen als de recordset leeg is ipv de querystring. Dan zul je gorgi_19's oplossing moeten gebruiken:
if rstSearch.EOF then
zoiets?
If rstSearch.RecordCount = 0 Then
Response.Write("No records found")
Else
enzovoorts...
If rstSearch.EOF = 0 Then
Else
enzovoorts...
  • gorgi_19
gorgi_19
Mja, we komen nu een beetje op uit de basis. Het enige wat ik kan zeggen is: "Probeer het zelf eens uit?" Je hebt iig nu de middelen aangereikt gekregen om je probleem op te lossen.
Sowieso:
Wat is de returnwaarde van EOF? Een boolean. Het lijkt me dan ook vrij nutteloos om te gaan vergelijken met een integerwaarde.
Verder begint dit wel heel erg een "neem mij aan het handje" topic te worden, dus deze gaat dicht. :) Sowieso een tip om eens een aantal tutorials door te nemen, want ik betwijfel of je echt precies weet wat je doet :)
[ Voor 19% gewijzigd door gorgi_19 op 10-05-2004 11:08 ]
