[Debian + Samba 3] Gebruiker kan wachtwoord niet wijzigen
  • Tomaat
  • Laatst online: 13-05 13:50
Ik heb sinds kort Samba 3 draaien (vanuit de Backports ge-apt-get). Draaide hiervoor 2.2.8a.
De migratie is verder goed verlopen. Heb hier en daar kleine wijzigingen aan moeten brengen in m'n config.. Deze staat hieronder:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
spisvr02:/etc/samba# cat smb.conf
[global]
    netbios name = spisvr02
    server string = "Spisvr02 - Primary Domain Controller"
    workgroup = spindent
    log file = /var/log/samba/%m.log
    max log size = 1024
    socket options = TCP_NODELAY SO_RCVBUF=8192 SO_SNDBUF=8192
    name resolve order = wins lmhosts bcast
    os level = 255
    security = user
# Functions
#   preferred master = yes
    domain master = yes
    local master = yes
    domain logons = yes
    wins support = yes
    time server = yes
    encrypt passwords = yes
# Password
    passwd program = /usr/bin/passwd %u
    passwd chat = *New*UNIX*password* %n\n *ReType*new*UNIX*password* %n\n *passwd:*all*authentication*tokens*updated*successfully*
    passwd chat debug = yes
    unix password sync = yes
#    min passwd length = 4
# Logon
    logon path = "c:\Documents and Settings\%u.spindent"
    logon drive = H:
    logon home = \\spisvr02\%u
    logon script = logon1.bat
# Printer
    printer admin = @administrators, root
    printcap name = /etc/printcap
# Other
    root = Administrator pieter
    hide files = /Thumbs.db/.DS_Store/
[netlogon]
    path = /netlogon
    comment = Netlogon
    read only = yes
    create mask = 0666
    directory mask = 0777
    write list = @administrators, root
[homes]
    comment = User home directories
    create mask = 0600
    directory mask = 0700
    writable = yes
    hide dot files = yes
[shared]
    path = /shared
    comment = Shared software
    create mask = 0666
    read only = yes
    guest ok = yes
[printers]
    path = /var/spool/samba
    comment = All Shared Printers
    create mask = 0700
    browseable = no
    printable = yes
[backup$]
    path = /backup
    comment = Hidden Backup Temporary Directory
    create mask = 0666
    read only = no
    force user = backup
    force group = spindent_users
[administration$]
    path = /administration
    comment = Administration Files
    read only = yes
    create mask = 0666
[algemeen$]
    path = /algemeen
    comment = Algemene Gedeelde Directory
    read only = no
    create mask = 0644
    directory mask = 0755
    guest ok = yes
[ghost$]
    path = /ghost
    comment = Ghost Directory
    read only = no
    create mask = 0644
    guest ok = yes
    force user = ghost
Wat nu niet meer werkt, is als een een gebruiker in Windows (2000/XP) CTRL + ALT + DEL drukt en dan Wijzig wachtwoord kiest.
Ik krijg dan de volgende melding:
Kan het wachtwoord voor deze account niet wijzigen vanwege de volgende fout:
1728: RPC-protocolfout.
Neem contact op met de systeembeheer.
In syslog verschijnt dan deze melding"
[...snap...]
May  8 14:14:19 spisvr02 smbd[510]: [2004/05/08 14:14:19, 0] lib/util_sock.c:get_peer_addr(952)
May  8 14:14:19 spisvr02 smbd[510]:   getpeername failed. Error was Transport endpoint is not connected
May  8 14:14:19 spisvr02 smbd[510]: [2004/05/08 14:14:19, 0] lib/util_sock.c:read_socket_data(342)
May  8 14:14:19 spisvr02 smbd[510]:   read_socket_data: recv failure for 4. Error = Connection reset by peer
May  8 14:14:19 spisvr02 smbd[512]: [2004/05/08 14:14:19, 0] lib/util_sock.c:get_peer_addr(952)
May  8 14:14:19 spisvr02 smbd[512]:   getpeername failed. Error was Transport endpoint is not connected
May  8 14:14:19 spisvr02 smbd[512]: [2004/05/08 14:14:19, 0] lib/util_sock.c:read_socket_data(342)
May  8 14:14:19 spisvr02 smbd[512]:   read_socket_data: recv failure for 4. Error = Connection reset by peer
Ik begrijp nu niet zo goed wat er mis gaat.. Hij kan de peername niet vinden? Word hiermee de DNS of Netbios naam bedoelt?
Als ik een ping naar desbetreffende machine stuur op DNS word deze netjes omgezet in het IP van die machine en krijg ik een reply..
Help :)
  • Jelmer
  • Laatst online: 23:54
probleem: name resolve order = wins lmhosts bcast
Er wordt geen gebruik gemaakt van DNS (lees /etc/nsswitch.conf)
maak daar eens
name resolve order = lmhosts host wins bcast
van en probeer dan nog eens.
  • Tomaat
Hmm...ik ben nu wel de 'getpeername' error kwijt..maar krijg nu de volgende
May  9 20:15:51 spisvr02 smbd[2058]: [2004/05/09 20:15:51, 0] lib/util_sock.c:read_socket_with_timeout(279)
May  9 20:15:52 spisvr02 smbd[2058]:   read_socket_with_timeout: timeout read. read error = Input/output error.
May  9 20:15:52 spisvr02 smbd[2058]: [2004/05/09 20:15:52, 0] lib/util_sock.c:read_socket_with_timeout(279)
May  9 20:15:53 spisvr02 smbd[2058]: [2004/05/09 20:15:53, 0] lib/util_sock.c:read_socket_with_timeout(279)
May  9 20:15:53 spisvr02 smbd[2058]:   read_socket_with_timeout: timeout read. read error = Input/output error.
May  9 20:15:54 spisvr02 smbd[2058]: [2004/05/09 20:15:54, 0] lib/util_sock.c:read_socket_with_timeout(279)
May  9 20:15:54 spisvr02 smbd[2058]:   read_socket_with_timeout: timeout read. read error = Input/output error.
May  9 20:15:55 spisvr02 smbd[2065]: [2004/05/09 20:15:55, 0] lib/util_sock.c:read_socket_with_timeout(279)
May  9 20:15:55 spisvr02 smbd[2065]:   read_socket_with_timeout: timeout read. read error = Input/output error.
May  9 20:15:56 spisvr02 smbd[2065]: [2004/05/09 20:15:56, 0] lib/util_sock.c:read_socket_with_timeout(279)
May  9 20:15:56 spisvr02 smbd[2065]:   read_socket_with_timeout: timeout read. read error = Input/output error.
Krijg overigens ook nog steeds de 1728 RPC error in Windows :/
Misschien hiermee te maken?
There have been several issues fixed since the 3.0.3 release, the most visible of
which is the problem with user password changes after applying the Microsoft security hotfix described in KB828741 to Windows NT 4.0/200x/XP clients.
Please refer to the Release Notes for descriptions of the exact changes and new
features.
meuktracker: Samba 3.0.4 en 2.2.9
[ Voor 4% gewijzigd door Verwijderd op 09-05-2004 22:24 ]
Yupz, dat is het MS04-11 update probleem en dat betreft zowel samba 2.2.X als samba 3.0.X. Het heeft dus niets te maken met je samba versie ;)
Opgelost in de dit weekend uitgebrachte samba versies.
Als je je foutmelding in Google had gegooid, was je zelf ook wel tot die conclusie gekomen ;)
[ Voor 14% gewijzigd door Verwijderd op 10-05-2004 03:25 ]
  • Tomaat
Hmm..enig ID wanneer die nieuwe versie in de backports zit?
  • Tomaat
*schopt*
  • Tomaat
Dankje usr-local-dick!
Ik heb Samba 3.0.4 nu draaien maar helaas...kan nog steeds het wachtwoord niet wijzigen. Nu had ik zo'n vermoede, aangezien het ook al niet lukte op een NT4 machine..
Dit komt er nu dus weer in de syslog te staan:
May 16 16:57:07 spisvr02 smbd[8687]: [2004/05/16 16:57:07, 0] lib/util_sock.c:read_socket_with_timeout(304)
May 16 16:57:07 spisvr02 smbd[8687]:   read_socket_with_timeout: timeout read. read error = Input/output error.
May 16 16:57:08 spisvr02 smbd[8687]: [2004/05/16 16:57:08, 0] lib/util_sock.c:read_socket_with_timeout(304)
May 16 16:57:08 spisvr02 smbd[8687]:   read_socket_with_timeout: timeout read. read error = Input/output error.
May 16 16:57:09 spisvr02 smbd[8687]: [2004/05/16 16:57:09, 0] lib/util_sock.c:read_socket_with_timeout(304)
May 16 16:57:09 spisvr02 smbd[8687]:   read_socket_with_timeout: timeout read. read error = Input/output error.
spisvr02:/etc#
Ik krijg btw nu ook elke keer een melding over dat het profiel niet gevonden kan worden :? Zoals je in m'n begin post kunt lezen, laat ik de roaming profiles lokaal staan d.m.v. ze naar C:\Documents and Settings te schrijven i.p.v. \\servernaam\sharenaam. Dit werkte bij Samba 2.2.8a dus perfect! Waarom nu niet meer?
Heb het op de XP machines al opgelost door in de Group Policy de optie Use Roaming Profiles o.i.d. uit te zetten... Het is een workaround, maar zou het liever op server niveau regellen zoals dat bij 2.2.8a dus wel lukte. Iemand enig ID?
  • Tomaat
Ok het profile verhaal is opgelost!
Moet zijn:
    logon path = c:\Documents and Settings\%u.spindent
Helaas nog niet het probleem met het wijzigen van het wachtwoord.. :/
[ Voor 98% gewijzigd door Tomaat op 17-05-2004 21:09 ]
  • usr-local-dick
Tomaat schreef op 16 mei 2004 @ 17:01:
you're welcome ;)
Maar dit klopt toch met mijn verhaal? Dus of je downgrade naar 3.0.2 of je patcht je 3.0.4 met het (miniscule) patchje op hun bugzilla site...
  • Tomaat
Ik HAD 3.0.2 draaien en daarbij werkte het wijzigen van het wachtwoord niet. Nu draai ik 3.0.4 en eveneens werkt het wijzigen van het wachtwoord niet...
Aan de foutmelding te zien die ik in m'n syslog krijg, gaat er iets mis met het gesprek tussen de Windows machine en Samba machine (RPC). Het rare is dat ik ook bar weinig op Google kan vinden. Kun je anders een jouw smb.conf opline flapsen?
P.s. Wat doet die patch precies?
  • Tomaat
pomtidom...
  • Tomaat
*zucht* Er moet toch IETS zijn wat iemand bekend voorkomt of weet ik welke richting ik het moet zoeken?
Het zit 'm niet in de .deb files want ik heb al van 3 verschillende mirror's geapt-get dus.
Die error die ik onder Windows XP krijg, heeft het over een RPC error. Is het mogelijk aan de RPC server iets in te stellen o.id.? Wellicht zit daar iets fout...
Begin een beetje radeloos te worden nu :/ De gebruikers MOETEN gewoon hun wachtwoord kunnen wijzigen.
  • Tomaat
*schop*
  • Bas!
  • Laatst online: 26-07 22:06
Er bestaat zoiets als een samba mailinglist en daar worden dommere vragen gesteld dan deze, weest dus niet bevreesd en post daar gewoon
To subscribe or unsubscribe via the World Wide Web, visit
http://lists.samba.org/mailman/listinfo/samba
or, via email, send a message with subject or body 'help' to
samba-request@lists.samba.org
En je kunt ze doorzoeken op gmame.org of gewoon via google
  • Tomaat
hmm..ik vind mijn vraag helemaal niet dom..
maar ik kan het juist niet met google vinden, anders had ik het hier ook niet gepost, of wel soms
  • blaataaps
Tomaat schreef op 12 juni 2004 @ 14:27:
Dat beweert hij volgens mij ook helemaal niet, hij probeert aan te geven dat je wat niveau betreft niet hoeft te schromen je vraag te stellen op die mailinglist. Soms is de drempel voor mensen hoog om het geluk te beproeven op een mailinglist, in dit geval hoef je niet bang te zijn dat je vraag van te laag niveau is dus.
Hij zegt volgens mij ook niet dat je niet gezocht hebt, maar geeft 2 manieren om eventueel de archives van die mailinglist door te snuffelen en te kijken hoe het daar aan toe gaat.
Kortom, volgens mij interpreteer je zijn post te negatief en valt het allemaal reuze mee (of ik interpreteer hem te positief..) :)
Dit is mijn password chat selectie uit smb.conf misschien helpt dit....
 ; Authoristation settings...
                ; passdb backend = smbpasswd
                passdb backend = tdbsam
                unix password sync = Yes
                passwd chat = *New*password* %n\n *Retype*new*password* %n\n*password:*all*authentication*tokens*updated*successfully
                Pam password change = yes
Ik doe het trucje via pam...
