Lite-On 811S Generating DVD high compatibility borders
Ik heb een lite-on 811s en begin steeds vaker de melding:
"Generating DVD high compatibility borders"
Is mijn fikker nu stuk? Ik gebruik Platinum 8X schijfjes die ik met 4X beschrijf
Onderstaand het hele log
Neo
1A23-0043-9030-1634-4431-8295
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 11-11-2003 15:49:52
Nero version: 6.3.0.0
Recorder: <LITE-ON DVDRW LDW-811S> Version: HS0P - HA 0 TA 0 - 6.3.0.0
Adapter driver: <atapi> HA 0
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <JLMS XJ-HD166S >Version: DS1A - HA 1 TA 0 - 6.3.0.0
Adapter driver: <atapi> HA 1
=== Scsi-Device-Map ===
CdRomPeripheral : LITE-ON DVDRW LDW-811S atapi Port 0 ID 0 DMA: On
CdRomPeripheral : JLMS XJ-HD166S atapi Port 1 ID 0 DMA: On
DiskPeripheral : Maxtor 6Y120L0 atapi Port 1 ID 1 DMA: On
DiskPeripheral : Promise 1+0 Stripe/RAID01.10 fasttx2k Port 2 ID 0 DMA: Off
CdRomPeripheral : Daemon D-Tools 1.0 d346prt Port 3 ID 0 DMA: Off
=== CDRom-Device-Map ===
LITE-ON DVDRW LDW-811S F: CDRom0
JLMS XJ-HD166S G: CDRom1
Daemon D-Tools I: CDRom2
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 1023MB (1048036kB)
Free physical memory: 634MB (649236kB)
Memory in use : 38 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
7.5.2004
DVD-Copy on the fly
21:22:56 #1 Text 0 File Reader.cpp, Line 118
Reader running
21:22:56 #2 Text 0 File Writer.cpp, Line 124
Writer LITE-ON DVDRW LDW-811S running
21:22:56 #3 Text 0 File DVDCopy.cpp, Line 241
DVD Track-Information from source disc
S01 T01 Con 0x14 Start 0 Len 2076702 (gap 0) Blank 0 Res 0 Mode TRM_DATA_MODE1 (0)
21:22:56 #4 Text 0 File DVDCopy.cpp, Line 334
Max -1 tracks of 1 allowed to copy
1: 0 - 2076702 = 2076702, TRM_DATA_MODE1, block size 2048, read opt 0 (no read options)
21:22:56 #5 Text 0 File Burncd.cpp, Line 3094
Turn on Disc-at-once, using DVD media
21:22:57 #6 Text 0 File DlgWaitCD.cpp, Line 239
Last possible write address on media: 2295103 (510:01.28)
Last address to be written: 2076701 (461:29.26)
21:22:57 #7 Text 0 File DlgWaitCD.cpp, Line 244
Write in overburning mode: FALSE
21:22:57 #8 Text 0 File DlgWaitCD.cpp, Line 2068
Recorder: LITE-ON DVDRW LDW-811S, Media type: DVD+R
Disc Manufacturer ID: CMC MAG, Media Type ID: E01, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 3
21:22:57 #9 Text 0 File DlgWaitCD.cpp, Line 405
>>> Protocol of DlgWaitCD activities: <<<
21:22:57 #10 Text 0 File ThreadedTransferInterface.cpp, Line 779
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (1 - Data (mode 1))
2 indices, index0 (150) not provided
original disc pos #0 + 2076702 (2076702) = #2076702/461:29.27
not relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2076702 blocks [LITE-ON DVDRW LDW-811S ]
21:22:57 #11 Text 0 File ThreadedTransferInterface.cpp, Line 948
Prepare recorder [LITE-ON DVDRW LDW-811S ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x40; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4253085696, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2076702 | lead-out | 1 | 0x00 | 0x41
21:22:57 #12 Phase 36 File dlgbrnst.cpp, Line 1800
Burn process started at 4x (5.520 KB/s)
21:22:57 #13 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
21:22:57 #14 Text 0 File Cdrdrv.cpp, Line 7912
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 03 43 4D 43 20 4D 41 - 47 00 45 30 31 00 38 23 ..CMC.MAG.E01.8#
54 37 10 02 38 6A 02 88 - 67 15 15 0B 0B 08 08 01 T7..8j..g.......
19 1B 0C 0C 0C 0D 01 00 - 00 00 00 00 00 00 00 01 ................
21:22:57 #15 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 13:02,067 (782067ms) -> OK
21:22:57 #16 Text 0 File DVDPlusRW.cpp, Line 603
Start write address at LBA 0
DVD high compatibility mode: Yes
21:23:41 #17 SCSI -1128 File Cdrdrv.cpp, Line 1430
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x0CEE9000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x11
Sense Qual: 0x06
CDB Data: 0x28 0x00 0x00 0x01 0x1D 0x80 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x11 0x06
21:23:42 #18 SCSI -1128 File Cdrdrv.cpp, Line 1430
Sense Code: 0x11
Sense Qual: 0x06
21:23:42 #19 TRANSFER -25 File Reader.cpp, Line 371
Error reading data
21:23:51 #20 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
21:23:55 #21 Phase 127 File dlgbrnst.cpp, Line 1800
21:25:22 #22 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 0:00,000 (0ms) -> OK
21:25:22 #23 Phase 129 File dlgbrnst.cpp, Line 1800
Generating DVD borders completed successfully
21:25:22 #24 Text 0 File dlgbrnst.cpp, Line 1658
21:25:22 #25 Phase 38 File dlgbrnst.cpp, Line 1800
Burn process failed at 4x (5.520 KB/s)
Existing drivers:
File 'Drivers\atapi.sys': Ver=?.?.?.?, size=86912 bytes, created 29-8-2002 2:27:50 (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
  • koraks
Error reading data
Dit duidt meer op een leesfout in je bronbestanden. Treedt het probleem op bij alles wat je probeert te branden?(*) Het kan overigens ook zijn dat je Nero-install corrupt is geworden, heb je al geprobeerd een verse Windows+Nero install uit te voeren (eventueel op een andere hdd zodat je je originele disk niet hoeft te wijzigen)?
(*) Ok, blijkbaar niet, ff overheen gelezen :)
Hoe dan ook zou ik toch in eerste instantie je probleem in de software zoeken in plaats van in de hardware.
[ Voor 23% gewijzigd door koraks op 07-05-2004 22:13 ]
  • BalusC
BalusC
Carpe diem
Titel verduidelijkt. Het was een nietszeggende "Brander stuk???? Lite-on811s" namelijk.
Lees voortaan de hele tekst bovenaan in [New Topic] door. Daarin staat het ook duidelijk gevraagd.
[ Voor 49% gewijzigd door BalusC op 07-05-2004 23:05 ]
  • JeanLeGrand
  • Laatst online: 31-07-2024
Ik gebruikte 3 spindels a 25 stuks Platinum 4 speed zonder problemen.
Met DVDinfoPro zag ik de medianaam van die DVD's: RITEK02 meen ik
Nu krijg ik met Platinum 8 speed (media CMC MAG R01) niets dan problemen; brandfouten zoals jij beschrijft, leesfouten in Liteon 163 reader en stotterende, vastlopende films in Vestel 2216 Standalone DVD. Ook vrienden klagen hierover, als ze een film voor me testen thuis.
Zit ik met 2 spindels onbruikbare Platinum 8 speed DVD's :(
Heb nu een spindel Fuji 4 speed en een spindel Traxdata 8 speeds (medianaam Ricoh02 oid) gehaald en brand ik weer ZONDER problemen!!
P.S. of ik die 8 speed platinums nou 8speed of 4speed brand, maakt qua problemen niets uit.
[ Voor 9% gewijzigd door JeanLeGrand op 08-05-2004 00:50 ]
Denon AVR-X3600H
  • DJSmiley
  • Laatst online: 19:20
JeanLeGrand schreef op 08 mei 2004 @ 00:48:
Da's dus de reden dat ik geen platinum meer gebruik: Teveel verschillende coatings. En idd, sommige coatings zijn gewoon kut, kan ze nietees inlezen aan het eind (nero cdspeed zie je ook wegvallen rond de 4Gb als je ze test)
  • JeanLeGrand
Nadat ik mezelf nog eens flink heb opgewonden over m'n Platinum 8x miskoop, ben ik nog eens even bij liteonit.com gaan neuzen en jawel, een nieuwe firmware-update voor de 811s. Deze HS0Q geblazen en verhip, op Platinum 8 speed gebrande film speelt nu wel hapervrij en probleemloos _/-\o_ . Als ik meer resultaten heb zal ik deze posten (8> .
Denon AVR-X3600H
JeanLeGrand schreef op 08 mei 2004 @ 13:04:
Ik heb net mijn Liteon 166 en mijn Liteon 811S voorzien van de laatste fw.
Ook Nero(6) is weer helemaal up to date >> nu es effe proberen :>
  • nFo
  • Laatst online: 19:24
nFo
Waarom komen voor de 165H géén updates meer ? :/ :'(
  • Sayko
  • Laatst online: 03-07 11:20
Sayko
Knowledge Is Power
CMC MAG R01 brandt zelfs een sony dru 530a niet dus het zal echt niet aan je brander liggen. Je mag die spindels wel hierheen sturen want mijn Ricoh mp5240a brandt ze heel graag
