Geheugen 133 ?
  • 107 views sinds 30-01-2008
  • Dezjay
  • Laatst online: 11:33
SPD dump of Dimm in socket :0
SPD - Number of bytes available :128 bytes
SPD - Total bytes of memory device :256 bytes
SPD - Revision :1,2
SPD - Checksum :OK
Manufacturer - Name :Unknown ID: 0000000000000000
Manufacturer - Location :0 ($00)
Manufacturer - Part Number :
Manufacturer - Revision code :00 ($0000)
Manufacturer - Manufacturing date :$0062
Manufacturer - Assembly Serial Number :0000
Manufacturer - Manufacturer Specific Data :
Memory - Type :Sync Dram
Memory - Row Addresses :0 | 12
Memory - Column Addresses :0 | 8
Memory - Module Banks :2
Memory - Data Width :64
Memory - Voltage interface standard :LVTTL
Memory - Cycle time at Max. Supported CAS :10.0 ns.
Memory - SDRAM Access from Clock at :6.0 ns.
Memory - DIMM Configuration type :None
Memory - Refresh Rate/Type :Self Refresh, Normal (15.625 us)
Memory - Minimum Clock Delay :1
Memory - Burst Lengths Supported :Page 1 2 4 8
Memory - Banks on Each SDRAM device :4
Memory - CAS Latencies Supported :3
Memory - CS Latencies Supported :0
Memory - WE Latencies Supported :0
Memory - Min. Clock Cycle Time @ CL X-1 :0.0 ns.
Memory - Max. Data Access Time from Clock @ CL X-1 :0.0 ns.
Memory - Min. Clock Cycle Time @ CL X-2 :0.0 ns.
Memory - Max. Data Access Time from Clock @ CL X-2 :0.0 ns.
Memory - Minimum Row Precharge Time :20 ns.
Memory - Minimum Row Active to Row Active delay :20 ns.
Memory - Minimum RAS to CAS delay :20 ns.
Memory - Minimum RAS Pulse Width :50 ns.
Memory - Module Bank Density :32 MB.
Memory - Module Total Density :64 MB.
Memory - Speed :100 Mhz
SPD dump of Dimm in socket :1
SPD - Revision :1,2
SPD - Checksum :OK
Manufacturer - Manufacturing date :$0000
Memory - Column Addresses :0 | 9
Memory - Burst Lengths Supported :1 2 4
Memory - CAS Latencies Supported :2 3
Memory - Min. Clock Cycle Time @ CL X-1 :10.0 ns.
Memory - Max. Data Access Time from Clock @ CL X-1 :6.0 ns.
Memory - Module Bank Density :64 MB.
Memory - Module Total Density :128 MB.
Dit zegt ie ken het op 133 Mhz ? rekken
(kweet dat dit al eens langs is gekomen maar ik kan het niet vinden
Hmm... Die tweede gaat wellicht nog lukken op CAS 3, maar die eerste ondersteunt alleen CAS 3 op 100 MHz. Dat gaat-ie dus niet leuk vinden...
Maar ik heb ooit 's gelezen dat CAS 2 + 100 MHz beter is dan CAS 3 + 133 MHz, maar weet niet precies meer waarom dat was... Iemand?
  • Dezjay
Gaat me alleen om die 133 Mhz
Ja, dat begrijp ik...
Maar: 100 MHz CAS 2 kun je op 133 MHz CAS 3 laten lopen. 100 MHz CAS 3 kun je i.h.a. niet op 100 MHz CAS 3 laten lopen.
CAS 2 is beter dan CAS 3, dat zijn nl. het aantal waitstates, hoe lang het geheugen wacht voordat-ie weer wat nieuws kan doen (of zo)
gewoon proberen toch...
