[2003] Backup Failure SBS2003*
  • 103 views sinds 30-01-2008
Ik om er echt niet uit; ik krijg constant foutmeldingen bij het maken van een backup in sbs2003. Voor het gemak zal ik de log even plaatsen;
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
28-4-2004 23:00
Date: 28-4-2004
Time: 23:00
User: SYSTEM
Backup Runner started.
NTMS session started successfully.
EnumerateNtmsObject(NTMS_LIBRARY) succeeded.
Will enumerate on 3 media libraries found.
GetNtmsObjectInformation(NtmsLibraryInfo) succeeded.
Found an enabled library.
InventoryNtmsLibrary(NtmsInventoryOmid) succeeded.
Identify Media completed
EnumerateNtmsObject(NTMS_MEDIA_TYPE) succeeded.
Will enumerate on 2 media types found.
GetNtmsObjectInformation(NtmsMediaTypeInfo) succeeded.
Will enumerate on 1 media types found.
Found a tape media type in the library (8mm AIT1).
Launching NTBackup: ntbackup.exe backup "@C:\Program Files\Microsoft
 Windows Small Business Server\Backup\Small Business Backup Script.bks"
/d "SBS Backup created on 28-4-2004 at 23:00" /v:yes /r:no /rs:no /hc:on /m
normal /j "Small Business Server Backup Job" /l:s /p "8mm AIT1" /UM
NTBACKUP LOG FILE: C:\Documents and
Settings\SBS Backup User\Local
Settings\Application Data\Microsoft\Windows NT\
NTBackup\data\backup10.log
=====================<BEGIN NTBACKUP LOG FILE>=====================
Backup Status
Operation: Backup
Active backup destination: 8mm AIT1
Media name: "Media created 28-4-2004 at 23:00"
Backup (via shadow copy) of "C: C-DRIVE"
Backup set #1 on media #1
Backup description: "SBS Backup created on 28-4-2004 at 23:00"
Backup Type: Normal
Backup started on 28-4-2004 at 23:04.
Backup completed on 28-4-2004 at 23:11.
Directories: 2183
Files: 18113
Bytes: 2.851.139.616
Time:  7 minutes and  2 seconds
Backup (via shadow copy) of "D: Data"
Backup set #2 on media #1
Backup Type: Normal
Backup started on 28-4-2004 at 23:11.
Backup completed on 29-4-2004 at 0:13.
Directories: 6228
Files: 61656
Bytes: 22.992.446.276
Time:  1 hour,  1 minute, and  55 seconds
Backup (via shadow copy) of "System State"
Backup set #3 on media #1
Backup Type: Copy
Backup started on 29-4-2004 at 0:13.
Backup completed on 29-4-2004 at 0:14.
Directories: 234
Files: 2621
Bytes: 488.045.041
Time:  55 seconds
Verify Status
Operation: Verify After Backup
Verify of "C:"
Verify started on 29-4-2004 at 0:15.
Verify completed on 29-4-2004 at 0:19.
Directories: 2183
Files: 18113
Different: 0
Time:  4 minutes and  47 seconds
Verify of "D:"
Verify started on 29-4-2004 at 0:19.
Verify completed on 29-4-2004 at 1:17.
Directories: 6228
Files: 61656
Different: 0
Time:  57 minutes and  15 seconds
Verify of "System State"
Verify started on 29-4-2004 at 1:17.
Directories: 234
Files: 2621
Different: 0
Bytes: 488.045.041
Time:  44 seconds
=======================<END NTBACKUP LOG FILE>=====================
NTBackup finished the backup with errors.
For more information about failed backups,
see the article on troubleshooting your backup at the following Web page:
http://go.microsoft.com/fwlink/?LinkId=18414
Backup ended at donderdag 29 april 2004 1:17
Backup Runner finished.
Er wordt dus gesuggereerd dat de backup met errors is voltooid. Maar ik die deze nergens. Iemand die mij kan helpen?
[ Voor 6% gewijzigd door elevator op 30-04-2004 15:09 ]
  • Zwelgje
  • Laatst online: 17-08 09:02
staan er ook nog relevante dingen in je eventlog?
  • elevator
elevator
Officieel moto fan :)
Ik heb even je logfile aangepast - zou je dit soort dingen voortaan zelf kunnen doen? :)
zwelgje schreef op 30 april 2004 @ 08:30:
Nee. slechts de error en een verwijzing naar de eerder geplaatste logfile.
Niemand?
*kick*.
  • alt-92
alt-92
ye olde farte
Afbeeldingslocatie: http://home.wanadoo.nl/blofnet/helpdesk/log.jpg
Die al eens geprobeerd?
Ow, waar te vinden?
  • alt-92
alt-92
ye olde farte
Is dat een serieuze vraag?
Tis gelukt.
  • elevator
elevator
Wat is er gelukt? Die log file op dat detail te zetten? Leverde dat nog niets op? :)
