Autoresponder script (perl)
  • 328 views sinds 30-01-2008
Geachte tweakers,
Bij deze wil ik jullie hulp inroepen.
Gezien het feit dat ik geen script request mag doen, heb ik het anders aangepakt. Ik ben gaan hobby-en met een script, wat ik heb aangepast naar eigen hand.
Natuurlijk werkt dat niet in één keer. vandaar dat ik nu hier uit kom.
Het gaat om het volgende script:
#/cgi-bin/awardmail.pl
# location of Perl (above) - check your doc or ask admin
# Script Source: CodeBrain.com
# Source URL: http://www.codebrain.com/perl
# Script Title: Award Submission E-Mailer w/ Autoresponder
# Script Name: AwardMail.pl
# Copyright: 1998,1999,2000 by OEC Corp & CodeBrain.com
# Version: 09.01.1999.C (latest)
# Status: Fully tested, release version 7, updated
# This script may not be redistributed without this header
# There are no restrictions on this script - anyone may use
# it, though we appreciate credit where due. Responsibility
# for use of the script is entirely with the user. Please
# note that CodeBrain.com does NOT support Perl scripts!
# Instructions:
# - Use WordPad.exe or any text editor to edit
# - Set your path to Perl as needed (first line at top)
# - Set ALL variables appropriately (below, see notes)
# - Take special care with the path to your sendmail (below)
# - Send the script to the server in ascii
# - Set script permissions - check your doc or ask admin
# - See e_faq.html for HTML set-ups in awardmail.zip file
# - Required html pages are also provided in awardmail.zip
##### SETTABLE VARIABLES ####################################
# URL to go to if there is a problem with form input
$ErrorPage = "http://www.lindware.nl/404.htm";
# URL to go to when form has been successfully submitted
$ThankPage = "http://www.lindware.nl/bedankt.htm";
# URL to go to if a 'foreign' referer calls the script
$EvilReferer = "http://www.networking4all.nl";
# E-mail address to send incoming form to (your address)
# If not using PERL 5, escape the @ thus: \@ instead of @
$YourEmail = 'info@lindware.nl';
# Script works only on your server(s) - ('URL1','URL2')
@referers = ('www.vahvideo.nl','www.vahvideo.nl');
# Location of mail program - check your doc or ask admin
$MailProgram = '/cgi-bin/awardmail.pl';
# Subject of the e-mail autoreply to the submitter
$Subject = "Bedankt voor het aanvragen van informatie...";
# Brief tail message for body of e-mail autoreply
$Message = "Geachte Heer/mevrouw,
Bedankt voor uw vertrouwen in ons product.
U krijgt zo spoedig mogelijk bericht.
Met vriendelijke groet,
naam
__________________________________________
Dit is een automatisch gegenereerd bericht";
# Your signature at the end of the autoreply e-mail
$Signature = "www.vahvideo.nl";
##### END OF SETTABLE VARIABLES ############################
##### MAIN PROGRAM #########################################
# ___ Do not edit below this line __________________________
&CheckReferingURL;
&ReadParse;
$Name = $in{'Name'};
$Email = $in{'Email'};
$URL = $in{'URL'};
$SiteName = $in{'SiteName'};
$Description = $in{'Description'};
&CheckEmailAddressFormat;
&CheckFields;
&SendSubmission;
&SendAutoReply;
print "Location: $ThankPage\n\n";
exit;
# _________________________________________________________
sub SendSubmission {
open (MAIL,"|$MailProgram -t");
print MAIL "To: $YourEmail\n";
print MAIL "From: $Email\n";
print MAIL "Subject: AWARD SUBMISSION\n";
print MAIL "AWARD SUBMISSION\n\n";
print MAIL "From: $Name\n";
print MAIL "Email: $Email\n";
print MAIL "Site: $SiteName\n";
print MAIL "URL: $URL\n\n";
print MAIL "Description:\n";
print MAIL "$Description\n\n";
close (MAIL);
sub SendAutoReply {
print MAIL "To: $Email\n";
print MAIL "From: $YourEmail\n";
print MAIL "Subject: $Subject\n";
print MAIL "$Subject\n\n";
print MAIL "You sent the following information:\n\n";
print MAIL "Name: $Name\n";
print MAIL "URL: $URL\n";
print MAIL "$Message\n\n";
print MAIL "Best regards,\n\n\n";
print MAIL "$Signature\n\n";
close (MAIL);
sub ReadParse { local (*in) = @_ if @_;
local ($i, $key, $val); if ( $ENV{'REQUEST_METHOD'} eq "GET" )
{$in = $ENV{'QUERY_STRING'};}
elsif ($ENV{'REQUEST_METHOD'} eq "POST")
{read(STDIN,$in,$ENV{'CONTENT_LENGTH'});}
else {
$in = ( grep( !/^-/, @ARGV )) [0];
$in =~ s/\\&/&/g; } @in = split(/&/,$in);
foreach $i (0 .. $#in) {
$in[$i] =~ s/\+/ /g;
($key, $val) = split(/=/,$in[$i],2);
$key =~ s/%(..)/pack("c",hex($1))/ge;
$val =~ s/%(..)/pack("c",hex($1))/ge;
$in{$key} .= "\0" if (defined($in{$key}));
$in{$key} .= $val; } return length($in); }
sub CheckEmailAddressFormat {
if (index($Email, "@") < 1) {&DoEmailError;}
if (index($Email, ".") < 1) {&DoEmailError;}
if (index($Email, " ") > -1) {&DoEmailError;}
sub CheckFields {
if (!$Name || $Name eq ' ') {&DoEmailError;}
if (!$Email || $Email eq ' ') {&DoEmailError;}
if (!$SiteName || $SiteName eq ' ') {&DoEmailError;}
if (!$URL || $URL eq ' ') {&DoEmailError;}
if (!$Description || $Description eq ' ') {&DoEmailError;}
sub DoEmailError {
print "Location: $ErrorPage\n\n";
exit;
sub CheckReferingURL {
if ($ENV{'HTTP_REFERER'}) {
foreach $referer (@referers) {
if ($ENV{'HTTP_REFERER'} =~ /$referer/i) {
$check_referer = '1';
last;
else {$check_referer = '1';}
if ($check_referer != 1) {
print "Location: $EvilReferer\n\n";
exit;
exit;
##### End of Script ########################################
Nu heb ik het script op op deze locatie gezet:
http://www.lindware.nl/cgi-bin/awardmail.pl
het formulier wat ik heb geconfigureerd draait op http://www.lindware.nl/kcontact.html (als test)
als je op verzenden drukt krijg ik de volgende foutmelding:
Server fout!
Foutbericht: :'(
Premature end of script headers: awardmail.pl
Platform van de server is linux (red-hat) en ondersteund perl.
verder is het gehost bij www.networking4all.com
Zelf denk ik dat er iets rammeld in het script maar ik heb daar te wienig verstand van om daarover te oordelen.
Iemand een idee? :?
  • Juup
Weet je het pad naar perl op de server? Iets van /usr/bin/perl ofzo. Die moet je bovenaan in het script zetten.
Platform van de server is linux (red-hat) en ondersteunt perl.
Zelf denk ik dat er iets rammelt in ...
[ Voor 47% gewijzigd door Juup op 28-04-2004 15:06 ]
Een wappie is iemand die gevallen is voor de (jarenlange) Russische desinformatiecampagnes.
Wantrouwen en confirmation bias doen de rest.
op mijn server staan de map in de map pub een map cgi-bin. daar moet hij toch in?
chmodd staat op 777 (alles aan) om er zeker van te zijn dat het werkt.
  • Juup
Verwijderd schreef op 28 april 2004 @ 15:06:
Is dit een reply op mijn post? Lees mijn post dan nog eens. Waar is de Perl executable?
  • Juup
Dit script is trouwens erg oud en slecht. Kijk eens op http://nms-cgi.sourceforge.net/ voor goede Perl scripts.
waar kan ik dat dan weer vinden :? ik heb echt geen idee.
Zal een printscreen maken van wsftp.
(ik denk dat een cursus Nederlands wel op zijn plaats is voor mij, Rammelt van alles aan mijn taalgebruik) :P
kijk of het bestand begint met #!/usr/bin/perl
  • Janoz
  • Laatst online: 28-08 12:00
Janoz
Moderator Devschuur®
!litemod
Zoals je ook wel in de faq zou kunnen lezen leveren we ook geen support op scripts van derden. Je kunt beter de eigenaar mailen. Programming & Webscripting is gericht op het zelf programmeren. Het dumpen van een enorme lap code met een foutmelding valt hier niet onder.
Verder heeft dit weinig meer met programmeren te maken...
