Ernstig dns/domain probleem w2k3 server
  • 74 views sinds 30-01-2008
Im mijn omgeving stonden 2 servers, w2k en w2k3. dit heeft gewerkt to de w2k de geest gaf, oude doos hardware probleem. Sindsdien kan er niet meer op de w2k3 server aangemeld worden. ik heb met netdiag /fix geprobeerd het ea te herstellen, tevergeefs. Wie kan hier iets mee?
netdiag
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
    Computer Name: BIHGLTST001
    DNS Host Name: bihgltst001.OVERIJSSEL.NL
    System info : Windows 2000 Server (Build 3790)
    Processor : x86 Family 6 Model 5 Stepping 2, GenuineIntel
    List of installed hotfixes :
        Q147222
Netcard queries test . . . . . . . : Passed
Per interface results:
    Adapter : Local Area Connection
        Netcard queries test . . . : Passed
        Host Name. . . . . . . . . : bihgltst001
        IP Address . . . . . . . . : 172.16.169.151
        Subnet Mask. . . . . . . . : 255.255.0.0
        Default Gateway. . . . . . : 172.16.169.1
        Primary WINS Server. . . . : 172.16.172.253
        Secondary WINS Server. . . : 172.16.172.254
        Dns Servers. . . . . . . . : 172.16.169.153
                                     172.16.169.10
                                     172.16.169.151
                                     172.16.125.117
        AutoConfiguration results. . . . . . : Passed
        Default gateway test . . . : Passed
        NetBT name test. . . . . . : Passed
        [WARNING] At least one of the <00> 'WorkStation Service', <03> 'Messenger Service', <20> 'WINS' names is missing.
            No remote names have been found.
        WINS service test. . . . . : Failed
            The test failed.  We were unable to query the WINS servers.
Global results:
Domain membership test . . . . . . : Failed
    [WARNING] Ths system volume has not been completely replicated to the local machine. This machine is not working properly as a DC.
NetBT transports test. . . . . . . : Passed
    List of NetBt transports currently configured:
        NetBT_Tcpip_{B3D37502-1443-4BB2-94F6-76F1E1AC8C4B}
    1 NetBt transport currently configured.
Autonet address test . . . . . . . : Passed
IP loopback ping test. . . . . . . : Passed
Default gateway test . . . . . . . : Passed
NetBT name test. . . . . . . . . . : Passed
    [WARNING] You don't have a single interface with the <00> 'WorkStation Service', <03> 'Messenger Service', <20> 'WINS' names defined.
Winsock test . . . . . . . . . . . : Passed
DNS test . . . . . . . . . . . . . : Failed
          [WARNING] Cannot find a primary authoritative DNS server for the name
            'bihgltst001.OVERIJSSEL.NL.'. [RCODE_SERVER_FAILURE]
            The name 'bihgltst001.OVERIJSSEL.NL.' may not be registered in DNS.
       [WARNING] The DNS entries for this DC cannot be verified right now on DNS server 172.16.169.153, ERROR_TIMEOUT.
    [FATAL] No DNS servers have the DNS records for this DC registered.
Redir and Browser test . . . . . . : Passed
    List of NetBt transports currently bound to the Redir
    The redir is bound to 1 NetBt transport.
    List of NetBt transports currently bound to the browser
    The browser is bound to 1 NetBt transport.
DC discovery test. . . . . . . . . : Failed
        [FATAL] Cannot find DC in domain 'OVERIJSSEL'. [ERROR_NO_SUCH_DOMAIN]
DC list test . . . . . . . . . . . : Failed
        'OVERIJSSEL': Cannot find DC to get DC list from [test skipped].
Trust relationship test. . . . . . : Skipped
Kerberos test. . . . . . . . . . . : Skipped
LDAP test. . . . . . . . . . . . . : Failed
    Cannot find DC to run LDAP tests on. The error occurred was: The specified domain either does not exist or could not be contacted.
        [WARNING] Cannot find DC in domain 'OVERIJSSEL'. [ERROR_NO_SUCH_DOMAIN]
Bindings test. . . . . . . . . . . : Passed
WAN configuration test . . . . . . : Skipped
    No active remote access connections.
Modem diagnostics test . . . . . . : Passed
IP Security test . . . . . . . . . : Skipped
    Note: run "netsh ipsec dynamic show /?" for more detailed information
The command completed successfully
  • Garfield_1
  • Laatst online: 10-03 07:37
Is de w2k3 bak wel als domain controller ingesteld & heb je active directory samen met DNS wel geconfigureerd op die bak
[ Voor 41% gewijzigd door Garfield_1 op 28-04-2004 10:09 ]
Nou, die gecrashede server was dus duidelijk je DNS server. (en WINS trouwens)
En die doet t niet meer. Misschien was t ook nog wel je Global Catalog Server, weten wij veel...
8)7
je zou het bij die ene w2k3 kunnen houden, maar dan zul je opnieuw DNS moeten installeren en configgen. (en de rest)a
Als je een ghost image had van die gecrashede bak, zou dat leuk zijn natuurlijk... ;)
[ Voor 62% gewijzigd door Verwijderd op 28-04-2004 10:11 ]
Nou beide servers hadden DNS en AD geinstalleerd (blijkbaar niet goed dus) ik heb met het seize commando alle server rollen naar dezer node verplaatst. Maar hij snapt het niet :'( oh en er staat ook exchange 2003 op voor, mocht dat van enig belang zijn, geinstallerd na het runnen van domainprep.
als ik het goed begrijp heb je geen backup?
probeer dcpromo eens te draaien.
[ Voor 30% gewijzigd door Verwijderd op 28-04-2004 10:28 ]
Verwijderd schreef op 28 april 2004 @ 10:27:
dat heb je goed, betreft een testomgeving.
Maar wel MIJN testomgeving en ik heb hem nodig.
dcpromo draaien met als doel?
met als doel het weer een volwaardige DC te maken, want:
Weet niet zeker of dcpromo in dit stadium nog werkt, maar je kunt t eens proberen.
Dan gaat i het ad eraf gooien, dat wil ik niet, ben bezig met het testen van ad extracts via ldap.
  • elevator
elevator
Officieel moto fan :)
Als je zeker weet dat je oude DC niet terug op kan komen en dat de rest van je domain in orde is (je nieuwe DC is GC, al je roles zijn van de enig overgebleven server e.d.) zou je de info in dit artikel eens kunnen opvolgen: http://support.microsoft....spx?scid=kb;EN-US;q315457
Overigens - ik zie dat je bv. een aantal DNS servers e.d. opgegeven hebt - heb je die ook allemaal opgeschoond en de oude servers verwijderd? :)
[ Voor 21% gewijzigd door elevator op 28-04-2004 11:45 ]
  • Brahiewahiewa
  • Laatst online: 30-09-2022
Brahiewahiewa
boelkloedig
Je moet gewoon effe z'n eigen IP-adres 172.16.169.151 bovenaan in het lijstje DNS servers zetten en het IP-adres van de oude W2k server (.10 of .153) weghalen. Daarna
IPCONFIG /REGISTERDNS
uitvoeren en na een kwartiertje het System Eventlog doorkijken op eventuele foutmeldingen. Misschien moet je je er voordat je dit gaat doen, nog even van overtuigen dat de DNS Service gestart is op je server.
Overigens is je DNS configuratie fout; althans ik vermoed dat 172.16.125.117 een DNS server verderop in je netwerk is die je gebruikt voor internet toegang. Beter is het om deze als forwarder op je DNS server in te stellen
[ Voor 23% gewijzigd door Brahiewahiewa op 28-04-2004 13:13 ]
QnJhaGlld2FoaWV3YQ==
  • Koffie
  • Laatst online: 07-09 17:04
Koffie
Koffiebierbrouwer
Braaimeneer
Het posten van een lap info van een of andere tool, met verder amper info, vind ik nou niet echt een PNS topic als ik eerlijk ben.
Move PNS > NT
Braaikamer - Smoke&BBQ
Koffie schreef op 28 april 2004 @ 14:09:
Move PNS > NT
JiJ kan me wat met je vinden :r het is me al eerder opgevallen dat je posting locked ed van mensen die meer prof. zjin dan de gemiddelde poster hier omdat je je stoort aan hun schrijfstijl of vraag.
Als je het probleem eerder had gezien was dat voldoende info voor je geweest ipv een negatieve bijdrage te leveren, probeer eens te helpen :(
  • Koffie
Koffie
Koffiebierbrouwer
Braaimeneer
Op deze manier iig helemaal niet.
Succes he :w
