Geheugen MBM; welke is beter?
  • garp
  • Laatst online: 18:01
Dit zijn de properties van mijn MEM; 1 van de 2 gaat er uit. Welke van de 2 is sneller en beter over te klokken? IK ben niet zo'n geheugenkenner. Iemand?
SPD dump of Dimm in socket :0
SPD - Number of bytes available :128 bytes
SPD - Total bytes of memory device :256 bytes
SPD - Revision :1.2
SPD - Checksum :OK
Manufacturer - Name :Unknown ID: 0000000000000000
Manufacturer - Location :0 ($00)
Manufacturer - Part Number :
Manufacturer - Revision code :00 ($0000)
Manufacturer - Manufacturing date :$0000
Manufacturer - Assembly Serial Number :0000
Manufacturer - Manufacturer Specific Data :
Memory - Type :Sync Dram
Memory - Row Addresses :0 | 12
Memory - Column Addresses :0 | 10
Memory - Module Banks :1
Memory - Data Width :64
Memory - Voltage interface standard :LVTTL
Memory - Cycle time at Max. Supported CAS :7.5 ns.
Memory - SDRAM Access from Clock at :5.4 ns.
Memory - DIMM Configuration type :None
Memory - Refresh Rate/Type :Self Refresh, Normal (15.625 us)
Memory - Minimum Clock Delay :1
Memory - Burst Lengths Supported :Page 1 2 4 8
Memory - Banks on Each SDRAM device :4
Memory - CAS Latencies Supported :3
Memory - CS Latencies Supported :0
Memory - WE Latencies Supported :0
Memory - Min. Clock Cycle Time @ CL X-1 :0.0 ns.
Memory - Max. Data Access Time from Clock @ CL X-1 :0.0 ns.
Memory - Min. Clock Cycle Time @ CL X-2 :0.0 ns.
Memory - Max. Data Access Time from Clock @ CL X-2 :0.0 ns.
Memory - Minimum Row Precharge Time :20 ns.
Memory - Minimum Row Active to Row Active delay :15 ns.
Memory - Minimum RAS to CAS delay :20 ns.
Memory - Minimum RAS Pulse Width :45 ns.
Memory - Module Bank Density :128 MB.
Memory - Module Total Density :128 MB.
Memory - Speed :133 Mhz
SPD dump of Dimm in socket :1
SPD - Revision :1.2
SPD - Checksum :OK
Manufacturer - Name :Goldstar
Manufacturer - Location :82 ($52)
Manufacturer - Part Number :GMM26416233ENTG-75
Manufacturer - Manufacturing date :$1B64
Manufacturer - Assembly Serial Number :0011863
Memory - Column Addresses :0 | 9
Memory - Module Banks :2
Memory - CAS Latencies Supported :2 3
Memory - Min. Clock Cycle Time @ CL X-1 :10.0 ns.
Memory - Max. Data Access Time from Clock @ CL X-1 :6.0 ns.
Memory - Module Bank Density :64 MB.
SPD dump of Dimm in socket :5
SPD - Number of bytes available :78 bytes
SPD - Total bytes of memory device :0 bytes
SPD - Revision :0
SPD - Checksum :Faulty
Memory - Type :Unknown $30
Memory type not further supported
Probeer ftp://ftp.heise.de/pub/ct/ctsi/ctspd092.zip eens. Deze geeft wat begrijpelijker info. Overigens denk ik dat ze beide even snel zijn (cas3 bij 133Mhz). De 2e heeft echter ook specificaties voor cas2 @ 100Mhz. Bij 'automatisch instellen' zal de 1e ook bij 100Mhz op cas3 draaien.
  • garp
Thx, ik probeer het proggie even..
Hmmm...draait niet onder 2K. Ik probeer het zo op mijn werk ff. Da's NT.
Het draait wel onder W2k. Je moet alleen eerst rebooten voordat je het programma start.
