Hoe configureer ik een src.rpm kernel?
nou?
ik heb Mandrake 7.2 (uiterst gelikte distro b.t.w.) en wil deze http://rpmfind.net/linux/RPM/rawhide/1.0/i386/RedHat/RPMS/kernel-2.4.0-0.43.4.i586.html kernel gaan installeren...
rpm -U kernel.src.rpm ???
Hoe moet ik em configgen dan?
Ok, ik heb bovenstaande gedaan en toen kwam ik hier:
[root@www rpm]# cd /usr/src
[root@www src]# ls
RPM/ linux/ linux-2.2.18.tar.gz linux-2.3.99-pre9.tar.gz
[root@www src]# cd RPM
[root@www RPM]# ls
BUILD/ RPMS/ SOURCES/ SPECS/ SRPMS/ core
[root@www RPM]# cd SOURCES
[root@www SOURCES]# ls
README.kernel-sources linux-2.4.0-nohighmemdebug.patch
linux-2.4.0-starfire-ia64.patch
linux-2.4.0-sym53-64bit.patch
linux-2.4.0-test10-vfat.patch
linux-2.4.0-test11-ia64-001206-2.diff
linux-2.4.0-test11-ia64-ksyms.patch
linux-2.4.0-test11-ia64-unwind.patch
linux-2.4.0-test11.tar.bz2
linux-2.4.0-test5-compile.patch
installkernel linux-2.4.0-test6-apic.patch
kernel-2.4-BuildASM.sh* linux-2.4.0-test7-pre4-emu10k1.patch
kernel-2.4-string.patch linux-2.4.0-test7-pre4-overflow.patch
kernel-2.4.0-alpha-BOOT.config linux-2.4.0-test8-qla1280-3.17b.patch
kernel-2.4.0-alpha-smp.config linux-2.4.0-test9-ia64-shutup.patch
kernel-2.4.0-alpha.config linux-2.4.0-test9-qla1280-3.19beta.patch
kernel-2.4.0-i386-BOOT.config linux-merge-config.awk
kernel-2.4.0-i386-smp.config linux-merge-modules.awk
kernel-2.4.0-i386.config linux-rhconfig.h
kernel-2.4.0-i586-smp.config kernel-2.4.0-i586.config module-info
kernel-2.4.0-i686-enterprise.config kernel-2.4.0-i686-smp.config kernel-2.4.0-i686.config kernel-2.4.0-ia64-smp.config kernel-2.4.0-ia64.config kernel-2.4.0-sparc-BOOT.config kernel-2.4.0-sparc-smp.config kernel-2.4.0-sparc.config kernel-2.4.0-sparc64-BOOT.config kernel-2.4.0-sparc64-smp.config kernel-2.4.0-sparc64.config linux-2.2.16-useio.patch linux-2.3.99-alpha.patch linux-2.3.99p3p6-sparc.patch linux-2.4-pcmcia-cp.patch linux-2.4.0-alpha.patch linux-2.4.0-changeloop.patch linux-2.4.0-cipe-symbols.patch linux-2.4.0-cipe.patch linux-2.4.0-ia64-agpgart.patch linux-2.4.0-ia64-getpagesize.patch linux-2.4.0-intelethernet.patch linux-2.4.0-netfilter-cpp.patch [root@www SOURCES]# ./kernel-2.4-BuildASM.sh
You must create /usr/include/asm-sparc* symlinks first.
[root@www SOURCES]# cd /usr/include
[root@www include]# ls
  • Myrdhin
  • Laatst online: 11:59
Met een src.rpm is het configureren erg lastig. Je moet dan alle build stappen met de hand gaan doen... Je bent veel sneller als je de tar.gz van www.kernel.org download en die installeert.
ik heb 't al ! :)
(tnx voor lezen anywayzz)
je moet gewoon geen src package pakken... maar zoiets bijvoorbeeld (2.4.0 voor Mandrake) en dan rpm -Uhv --nodeps kernel-x.x.x.rpm en dan werkt 't prima! :)
Yes, alles werkt nu!!! Lekker weer muziek enzo... :) :)
