[PHP]Foto uploaden
  • GewoonNico
  • Laatst online: 20:27
Ik heb problemen met het uploaden van een foto en die foto vervolgens in een database te plaatsen.
het script:
PHP:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
        $maxX = "250";
        $maxY = "250";
        $imgsize = getimagesize($_FILES['pic']['tmp_name']);
        switch($imgsize[2])
            case 1:
               # GIF image
                $timg = imageCreateFromGIF($_FILES['pic']['tmp_name']);
                $type = "gif";
                break;
            case 2:
               # JPEG image
                $timg = imageCreateFromJPEG($_FILES['pic']['tmp_name']); //Regel 40
                $type = "jpg";
                break;
            case 3:
               # PNG image
                $timg = imageCreateFromPNG($_FILES['pic']['tmp_name']);
                $type = "png";
                break;
        $imgX = $imgsize[0];
        $imgY = $imgsize[1];
        // Zoomfactor Berekenen
        $_X = $imgX/$maxX * 100;
        $_Y = $imgY/$maxY * 100;
        // Zoomfactor selecteren
        if((100-$_X) < (100-$_Y))
            $_K = $_X;
        else
            $_K = $_Y;
        // Nieuwe grootte berekenen
        $newX = floor($imgX/$_K * 100);
        $newY = floor($imgY/$_K * 100);
        //Nieuw plaatje maken
        $imgh = imageCreateTrueColor($newX, $newY);
        imagecopyresized($imgh, $timg, 0,0,0,0,$newX,$newY,$imgX,$imgY);
        $copyright = imagecreatefromjpeg("images/copyright.jpg");
        $white = imagecolorallocate($copyright, 255, 255, 255);
        imagecolortransparent($copyright,$white);
        //imagecopy($imgh,$copyright,0,0,0,0,$newX,$newY);
        ImageJPEG($imgh, "temp/temp1.jpg");
        $file = "temp/temp1.jpg";
        $fullfile = fread(fopen($file,"r"),filesize($file));
        $coded = chunk_split(base64_encode($fullfile));
        $query = mysql_query("SELECT id FROM user_photo WHERE id_user ='".$_USER['id']."'");
        if (mysql_num_rows($query))
            mysql_query("UPDATE user_photo SET photo='".$coded."',date='".$_SET['dateu']."' WHERE id_user='".$_USER['id']."'");
        else
            mysql_query("INSERT INTO user_photo (id_user,date,photo) VALUES('".$_USER['id']."','".$_SET['dateu']."','".$coded."')");
        echo("De foto is succesvol geplaatst!");
De error
Fatal error: Allowed memory size of 16777216 bytes exhausted (tried to allocate 11328 bytes) in /home/www/web2/web/sites/setup/photo.php on line 40
Ik heb de standaard memory_size van 8 MB naar 16 Mb verandert. Schijnt dat 16 MB nu ook niet genoeg is. De foto is maar 500 KB
Hoe kan ik dit probleem anders oplossen?
Nico
  • curry684
  • Laatst online: 04-09 14:38
curry684
left part of the evil twins
sqrt(16777216 / 3) = 2364
Oftewel een plaatje van 2364 * 2364 pas net in 16Mb. Hoe groot is het plaatje dat je probeert?
Professionele website nodig?
  • intermusic
  • Laatst online: 25-03-2025
intermusic
Marc Hoekstra
Ik weet het niet precies maar het zou kunnen dat het PHP-script zelf het plaatje groter maakt.
Welke regel is trouwens regel 40 in het script wat hierboven staat?
[ Voor 27% gewijzigd door intermusic op 19-04-2004 13:26 ]
  • TeeDee
  • Laatst online: 19:58
TeeDee
CQB 241
curry684 schreef op 19 april 2004 @ 13:21:
500 kb.
Verder: je zet het plaatje in je db? Of het pad?
Heart..pumps blood.Has nothing to do with emotion! Bored
  • MatHack
MatHack
Dev by day, Gamer by night
TeeDee schreef op 19 april 2004 @ 13:24:
500 kb.
Ik denk dat curry684 naar de afmetingen vroeg en niet naar de bestandsgrootte.
There's no place like 127.0.0.1
  • curry684
curry684
MatHack schreef op 19 april 2004 @ 13:25:
Idd, hij pakt het plaatje uit in het geheugen om er true color beeldbewerking op te doen, en dan heb je dus width*height*colordepth/8 bytes nodig aan geheugen.
  • GewoonNico
Regel 40 =
(na Case 2, in het begin)
Het plaatje is 500KB groot.
Kan ik dit probleem ok op een andere manier oplossen in plaats van het geheugen te vergroten ?
  • intermusic
intermusic
Marc Hoekstra
Ik vind het plaatje toch een beetje aan de grote kant.
Probeer het eens met een ander 'kleiner' plaatje.
Misschien dat het plaatje niet helemaal goed is, of toch echt te groot is.
  • GewoonNico
Het plaatje is groter dan 2364 * 2364
Wanneer ik een kleiner plaatje pak, dan werkt het wel gewoon.
  • curry684
curry684
partypas schreef op 19 april 2004 @ 16:30:
Wat ik dus 3 uur geleden al zei :z
Als je een image true color wil 'processen' moet je width*height*3 bytes geheugen beschikbaar hebben. Zet dus gewoon je memory size op 64Mb of bouw een beveiliging op dat width*height niet groter mag zijn dan 5 miljoen oid.
  • GewoonNico
Oke, bedankt.
Ikpas het geheugen aan naar 25 Mb, dat meot volgens mij voorlopig wel genoeg zijn.
Groet,
Nico
