[ADO] Stored Proc, resultset closed
  • Nexopheus
  • Laatst online: 28-01 13:50
Ik heb een erg raar probleem nml:
Database : MSSQL
Stored procedure:
29
30
31
32
33
34
35
36
REATE PROCEDURE sp_GeoInfo
@ipNrs VARCHAR(255)
AS
DECLARE @strIP VARCHAR(100)
DECLARE @strIPLEFT VARCHAR(100)
DECLARE @ipNO FLOAT
declare @countrySHORT nvarchar(2)
declare @countryLONG nvarchar(64)
declare @region nvarchar(128)
declare @city nvarchar(128)
declare @isp nvarchar(255)
CREATE TABLE #tempResult (
    [ipNo] [float] NOT NULL PRIMARY KEY,
    [countrySHORT] [nvarchar] (2) COLLATE SQL_Latin1_General_CP1_CI_AS NULL ,
    [countryLONG] [nvarchar] (64) COLLATE SQL_Latin1_General_CP1_CI_AS NULL ,
    [region] [nvarchar] (128) COLLATE SQL_Latin1_General_CP1_CI_AS NULL ,
    [city] [nvarchar] (128) COLLATE SQL_Latin1_General_CP1_CI_AS NULL ,
    [isp] [nvarchar] (255) COLLATE SQL_Latin1_General_CP1_CI_AS NULL
while(PATINDEX('%;%', @ipNrs)<> 0)
begin
    SET @strIP = SUBSTRING(@ipNrs, 1, PATINDEX('%;%', @ipNrs) - 1)
    SET @strIPLEFT = SUBSTRING(@ipNrs, PATINDEX('%;%', @ipNrs) + 1, LEN(@ipNrs))
    SET @ipNrs = @strIPLEFT
    SET @ipNO = @strIP
    SELECT TOP 1 @countrySHORT=countrySHORT,@countryLONG=countryLONG,@region=region,@city=city,@isp=isp  FROM tbllocation where @ipNO <= ipTO
    INSERT INTO  #tempResult(ipNO,countrySHORT,countryLong,region,city,isp) VALUES (@ipNO,@countrySHORT,@countryLong,@region,@city,@isp)
end
SELECT * FROM  #tempResult
GO
cmdStoredProc.CommandText = "sp_GeoInfo"
cmdStoredProc.CommandType = adCmdStoredProc
Set paramId = cmdStoredProc.CreateParameter("@ipNrs", adVarChar, adParamInput)
paramId.Size = 255
paramId.Value = "21355324;32424234;"
cmdStoredProc.Parameters.Append paramId
set rstStoredProc = cmdStoredProc.Execute
while not rstStoredProc.EOF
    response.write rstStoredProc(0) & "<br>"
    rstStoredProc.movenext
wend
error:
ADODB.Recordset error '800a0e78'
Operation is not allowed when the object is closed.
Wanneer ik de code uitvoer in de query analyser gaat alles goed, waarom krijg ik geen resultset terug van de sp ?
Ik begrijp er niets van, moet ik mischien anders de execute doen ??
Wie o Wie ?
Wat niet kan is nog nooit gebeurd
  • whoami
  • Laatst online: 22:47
Moet je niet Open() oid doen als je een recordset wilt terugkrijgen?
https://fgheysels.github.io/
  • Nexopheus
Gebeurt ook wel :
Set cnnStoredProc = Server.CreateObject("ADODB.Connection")
cnnStoredProc.Open "Provider=SQLOLEDB;Data Source=(LOCAL);" _
    & "Initial Catalog=ip2location;User Id=******;Password=*****;"
Set cmdStoredProc = Server.CreateObject("ADODB.Command")
cmdStoredProc.ActiveConnection = cnnStoredProc
[ Voor 9% gewijzigd door Nexopheus op 16-04-2004 14:24 ]
  • bigbeng
  • Laatst online: 26-11-2021
Heb je wel een connection object ingesteld op het command object?
Je kunt hem eventueel ook met de execute meegeven.
  • Nexopheus
Ehh, ja dus :)
  • bigbeng
Dat was sneaky hoor, nog even snel de relevante code erbij plaatsen ;)
Mijn doorgaans al niet te intelligente image wordt nu nog verder de grond in geboord. :*)
  • faabman
  • Laatst online: 08-08-2024
lijkt me dat je in ieder geval in je SP ff set nocount = on (of wats het nou zonder =) moet doen...
Op zoek naar een baan als Coldfusion webdeveloper? Mail me!
  • Nexopheus
bigbeng schreef op 16 april 2004 @ 14:29:
Sorry 8)
  • Nexopheus
faabman schreef op 16 april 2004 @ 14:29:
Kun je dit toelichten ? Wat doet dit precies ?
  • bigbeng
Een stored procedure geeft in principe het resultaat door van de eerste query. In jouw geval dus de INSERT. Dit heeft geen recordset.
Als je SET NOCOUNT ON doet, dan wordt je select statement doorgegeven aan je command object.
dit doe je dus in je stored procedure...
[ Voor 12% gewijzigd door bigbeng op 16-04-2004 14:33 ]
  • faabman
Nexopheus schreef op 16 april 2004 @ 14:30:
uit booksonline
SET NOCOUNT
Stops the message indicating the number of rows affected by a Transact-SQL statement from being returned as part of the results.
Syntax
SET NOCOUNT { ON | OFF }
Remarks
When SET NOCOUNT is ON, the count (indicating the number of rows affected by a Transact-SQL statement) is not returned. When SET NOCOUNT is OFF, the count is returned.
The @@ROWCOUNT function is updated even when SET NOCOUNT is ON.
SET NOCOUNT ON eliminates the sending of DONE_IN_PROC messages to the client for each statement in a stored procedure. When using the utilities provided with Microsoft® SQL Server™ to execute queries, the results prevent "nn rows affected" from being displayed at the end Transact-SQL statements such as SELECT, INSERT, UPDATE, and DELETE.
For stored procedures that contain several statements that do not return much actual data, this can provide a significant performance boost because network traffic is greatly reduced.
The setting of SET NOCOUNT is set at execute or run time and not at parse time.
spuit 11 10 8)7
[ Voor 5% gewijzigd door faabman op 16-04-2004 14:43 ]
  • Nexopheus
_/-\o_
Werkt.
Thx
  • bigbeng
faabman schreef op 16 april 2004 @ 14:35:
uit booksonline
spuit 11 8)7
Hehe, ik moet zeggen dat jouw copy/paste uit booksonline een waarheidsgetrouwer beeld schetst van wat er onder de motorkap gebeurt. Je mag jezelf dus best spuit 10 noemen ;)
