[php] nieuwe versie
  • 47 views sinds 30-01-2008
  • Ankh
  • Registratie: Mei 2001
  • Laatst online: 17:29
Ik vond daarnet op de mirror van trueserver een nieuwe versie van php -> 4.3.6
ftp://apache.mirror.trues...ibutions/php-4.3.6.tar.gz
als ik de NEWS lees, staat er dan ook dat hij nog maar net uit is :)
ik ga hem in ieder geval meteen testen :)
PHP 4 NEWS
15 Apr 2004, Version 4.3.6
- Updated bundled PDFLib library to version 5.0.3p1 in Windows distribution.
(Edin)
- Fixed a crash in multi-threaded environments when a thread is shutdown by
the web server. (Stas)
- Fixed a bug that prevented building of the GD extension against external GD
lib 1.X. (Ilia, Edin, Nick Talbott).
- Synchronized bundled GD library with GD 2.0.22. (Ilia)
- Fixed bug #27963 (Session lifetime setting may leak between requests). (Ilia)
- Fixed bug #27849 (configure craps out on trivial syntax error). (Derick)
- Fixed bug #27822 (is_resource() returns TRUE for closed resources). (Derick)
- Fixed bug #27819 (problems returning reference to a reference parameter).
(Ilia)
- Fixed bug #27809 (ftp_systype returns null on some ftp servers). (Ilia)
- Fixed bug #27802 (default number of children to 8 when PHP_FCGI_CHILDREN is
not defined). (Ilia)
- Fixed bug #27780 (strtotime(+1 xxx) returns a wrong date/time). (Derick)
- Fixed bug #27769 (domxml_xmltree crashes). (Rob)
- Fixed bug #27764 (Get return value from a stored procedure not returning any
result sets). (Frank)
- Fixed bug #27762 (SCO Openserver doesn't have S_ISSOCK). (Wez)
- Fixed bug #27743 (Make sure Money types are converted and returned
correctly). (Frank)
- Fixed bug #27732 (Fixed compilation bug inside php_sab_info.h). (Ilia)
- Fixed bug #27731 (error_reporting() inside @ block fails to set
error_reporting level). (Ilia)
- Fixed bug #27719 (mktime issues on and around DST changeover). (Rasmus)
- Fixed bug #27717 (Test Failures when compiled on 64-bit mode). (Ard, Derick)
- Fixed bug #27687 (Bug Adding Default Charset to 'text/*' Content-Type
Header). (Marcus)
- Fixed bug #27663 (compile failure with cURL 7.11.1). (Ilia)
- Fixed bug #27646 (Cannot serialize/unserialize non-finite numeric values).
(Marcus)
- Fixed bug #26757 (session.save_path default is bogus for win32). (Wez)
- Fixed bug #26589 (Crash inside mssql extension when selecting many columns
of type money). (Frank)
- Fixed bug #25547 (error_handler and array index with function call).
(cschneid at cschneid dot com)
  • blaataaps
Dit lijkt me meer iets voor de meuktracker eerlijk gezegd :)
