MGS 2 Vamp verslaan
  • 70 views sinds 30-01-2008
Ik moet in MGS 2 Substance Emma redden. maar voordat je daar kunt komen, moet je Vamp verslaan. Ik heb dit al met een stinger, m4, socom en van alles geprobeerd, maar ik krijg hem niet dood. als hij bijna dood is, gaathij steeds bewegen en dan kan ik hem niet meer krijgen.
is hier een speciaal truukje voor of zo?
ohw ja, met de search kon ik niets vinden
  • Outerspace
  • Laatst online: 15:21
Outerspace
Admin General Chat
dikke bull, dan ben je wel scheel.. nofi
zoeken is toch niet zo moeilijk :?
http://www.google.com/sea...id&btnG=Zoeken&lr=lang_nl
http://www.google.com/sea...ear+solid&btnG=Zoeken&lr=
Hint: Defeating Vamp
As soon as the fight begins, run over to Vamp and get
as close as possible to him without falling into the water. Quickly
equip the stinger missile launcher and begin to constantly bombard
him with missiles. Tap the button as fast as possible to defeat
him in about fifteen secondsUnder the extreme difficulty setting, at the beginning of the
battle when Vamp bows, shoot him with the Stinger. You might be
able to do this two or three times if you are lucky. As soon as
he goes underwater, shoot the lights out quickly before he comes
back up. When he first goes underwater, he will come back up after
about one sixth of his oxygen is used, unless of course you shoot
him while he is underwater (which will deplete his oxygen after
a few shots). If you shoot the lights, you will most likely not
have enough time to shoot him while he is underwater. Throughout
this battle, Vamp will alternate between standing above you while
throwing knives at you, and chasing you around on the catwalk
trying to slash at you. He always starts the battle by going above
you while throwing knives. When Vamp throws knives while above
you, wait until he starts throwing them in rapid succession. When
he does this, try to anticipate his movements so you will end
up directly beneath him once he finishes throwing the knives.
As soon as he stops, fire repeatedly with the Stinger. You should
be able to hit him about three or four times. When he goes underwater
after throwing knives at you from above, place a Claymore mine
on the catwalk to the right as you enter the room. Then, stand
on the southern-most catwalk in the room as you enter. Stand to
the right of the line that is in the middle. When Vamp comes up,
he will run directly into the Claymore, causing him to go back
under. When Vamp's life bar reaches about one third, he will change
his knife throwing pattern. He will throw two knives in rapid
succession, then pause for a second or two before throwing a third
knife. He will do this three times before going underwater. With
this knife throwing pattern, it will be difficult to hit him.
You may want to dodge his knives rather than try to attack him
during this time. If you do choose to attack him, do so by getting
your Stinger ready before he comes up. When he comes up, shoot
him immediately when he lands. This can be dangerous because you
will be open to attack from his knife-throw if you do not hit
him. if you do not attack him, a good strategy to avoid getting
hit is to run in circles while moving in a zig-zag pattern. Also,
do not let him get close to you with your back to him. If this
happens, you are very likely to be hit. Once Vamp's life is down
to approximately one tenth, he will change his attack pattern.
He will move around very quickly and occasionally throw five or
six knives simultaneously. The best way to hit him during this
stage is to track him with the Stinger and fire just as he is
about to throw knives at you (or any other time when you think
you can hit him). This last stage is the toughest; you will have
to be very quick not to get hit. Try to make sure you have full
rations for this battle (especially the last part).
<P>
When the battle starts, shoot Vamp. When he goes into the water,
run anywhere near an edge and plant a C4 bomb. Then, jump over
the edge directly next to the bomb. When Vamp approaches, he realizes
that he cannot hit you and jumps down. He will start to walk toward
you, and when he steps over the C4, blow him up. He will jump
back in the water. Repeat the cycle until he dies. Note: Act quickly,
because if he jumps up before you are done, you will be knifed.
en....
Vamp
De beste strategie om Vamp te verslaan is door gebruik te maken van verschillende wapens. Zijn tegenaanvallen vormen niet echt een bedreiging, omdat ze eenvoudig te ontwijken zijn. Vamp moet het vooral hebben van zijn beweeglijkheid, waardoor het lastig kan zijn om hem te kunnen raken. De wapens die je moet gebruiken zijn de M-9, de Nikita, de RGB-6 en de Stinger. Meteen bij aanvang van de strijd schiet je met je M-9 op de wonden die Vamp op zijn borst en buik heeft. Bij een voltreffer op deze wonden loopt Vamp meer schade op dan anders. Als hij onder water duikt schiet je snel de lamp aan de rechterkant en de lamp aan de linkerkant stuk met je Socom pistool. Dit is absoluut noodzakelijk! Doordat je beide lampen stuk schiet, ontstaat er geen schaduw naast je. De messen die Vamp werpt binden je namelijk vast aan je schaduw, zodat je niet meer weg kunt komen. Blijf dus steeds op het gedeelte bij de deur tijdens dit gevecht. Nadat je de twee lampen hebt stukgeschoten richt je met je M-9 op Vamp die naar de hoek op de bovenste richel zal lopen. In de hoek zal hij even stilstaan en dit is een goed moment om hem te raken met je M-9. Ga snel gehurkt zitten om zijn mes te ontwijken. Hierna zal Vamp weer het water induiken. Nu is het tijd om de RGB-6 tevoorschijn te halen. Schiet snel twee granaten in het water om ervoor te zorgen dat Vamp weer snel naar boven moet om adem te halen. De twee ontploffingen zorgen ook voor schade aan zijn bewustzijnsbalk. Pak snel je Nikita en ga in het midden van het pad staan, met je gezicht naar het Oosten gericht. Vamp zal via het rechterpad naar je toe rennen en op het moment dat hij springt, druk je op de cirkel button. Hierdoor geef je hem een enorme dreun met je Nikita waardoor hij terug in het water wordt gesmeten. Ren na deze dreun naar de rechterhoek, want Vamp zal meteen weer omhoog springen om in de aanval te gaan. In deze fase zal hij steeds drie messen werpen. Ren naar de linkerhoek om zijn eerste mes te ontwijken. Vamp zal naar de andere richel springen. Ren weer terug naar de rechterhoek. Bij zijn derde mes ren je weer terug naar links. Na deze drie messen zal Vamp vanuit het Noorden een hele serie messen tegelijk werpen. Ren naar het rechterpad en blijf halverwege staan. Richt alvast omhoog met je M-9 op de plek waar Vamp zal stoppen en schiet op zijn borst. Ren weer snel terug naar het pad bij de deur en schiet weer twee granaten in het water. Het patroon is in deze fase steeds hetzelfde. Als de bewustzijnsbalk van Vamp voor de helft leeg is, zal hij steeds op het linkerhek bij de deur springen. Ook hier kun je hem eenvoudig met je Nikita vanaf slaan. Let er wel op dat Vamp twee keer naar je toe zal rennen als deze fase begint. Je richt je alvast met je Nikita naar het Zuiden en als Vamp naar het hek springt, sla je hem eraf door op de cirkel button te drukken. In deze tweede fase zal hij eerst twee messen werpen, gevolgd door een derde mes. Ren eenvoudig van de rechterhoek naar de linkerhoek en terug om deze messen te ontwijken. Na drie van deze aanvallen zal hij weer het water induiken en het bekende patroon herhalen. Als je door je RGB-6 granaten heen bent, schiet je met je Stinger twee raketten in het water. Als de bewustzijnsbalk van Vamp bij de letter “M” staat, zal hij van tactiek veranderen. In deze derde fase zal hij als een razende heel snel rondspringen en drie messen tegelijk werpen. Pak je M-9 en ga voor het kastje bij de linkerhoek staan. Op het juiste moment schieten en gehurkt zitten is nu van levensbelang voor Raiden. Door je positie bij het kastje kun je beter zien of je staat of gehurkt zit. Op een andere plek is dit lastiger te zien. Je moet in deze laatste fase Vamp volgen met de automatische lock van je M-9. Houd daarom steeds de L1 knop ingedrukt in combinatie met de R1 knop (FPV) en de wapenknop. Vamp is alleen te raken op het moment dat hij de drie messen gaat gooien. Maar dan moet je wel de L1 knop loslaten. Als je schiet terwijl je de L1 knop ingedrukt hebt, zal zijn schild hem blijven beschermen. Zorg er dus voor dat je even de L1 knop loslaat, meteen schiet en dan snel gehurkt achter het kastje gaat zitten. Want Vamp slaagt er wel in om zijn drie messen te werpen. Na het ontwijken van de messen kom je snel weer overeind, druk je op L1 om weer een lock te krijgen en probeer je Vamp opnieuw te raken als hij stilstaat om zijn messen te werpen. De R1 knop (FPV) kun je in deze laatste fase steeds ingedrukt blijven houden. Na vijf van deze voltreffers zal hij terug in het water gesmeten worden en ben je verlost van Vamp.
en......
Neem snel je laatste Pentazemin, zoom in op zijn hoofd en geef hem met je PSG1-T de volle laag. Pas wel op voor de arm van Emma die af en toe voor zijn hoofd langs slingert. Je kunt het beste schieten op het moment dat haar arm voor zijn hoofd is, omdat Vamp meteen daarna haar arm zal wegdraaien. Probeer te richten op de bovenkant van zijn hoofd. Na 13 voltreffers op zijn hoofd zal Vamp in het water geslingerd worden en zal een filmpje het overnemen.
[ Voor 7% gewijzigd door Outerspace op 13-04-2004 20:16 . Reden: verbeteren topic ]
Wauw, een sig!
  • NvE
NvE
kijkt
Eerst hem aan flarden schieten met je M4/AK-74-u, daarna krijgt hij vaak een rode rook om hem heen waardoor je hem niet kan raken, dan moet je de RGB6 gebruiken. Verder kun je grenades in het water gooien als ie aan het zwemmen om, werkt ook wel lekker :) .
Wat een kul hierboven, zo moeilijk heb ik het nog nooit gezien. :X
Gewoon rustig mikken, als ie dan een mes gooit schiet je die ook uit de lucht, mocht ie naast je staan gewoon weglopen :)
[ Voor 29% gewijzigd door NvE op 13-04-2004 20:41 ]
Ja doe maar.
outerspace: Ietsjes vriendelijker tegen een nieuwkomer mag ook wel hoor :/
In ieder geval, de oplossing is voorhande. Met Google en GameFAQs kun je een hoop 'walktrough' kwesties beantwoorden, zeker als het om zo'n populair spel gaat :)
