[Sendmail] Rare flushes
  • WarPuppy
  • Laatst online: 23-08 21:39
WarPuppy
Electronic Technology
Leute,
Volgens mij weet ik het al wat het is, maar er wordt getracht mijn mooie sendmail voor spam te gebruiken.
Als ik met ps aux kijk wat er gebeurt zie ik dit staan:
root      9486  0.1  0.8  7152 2640 ?        S    14:59   0:18 sendmail: MTA: ./i37Jx5w6017101 7935.youonlylivethricemarketing.com.: user o
root     12752  0.1  0.8  7152 2596 ?        S    15:09   0:18 sendmail: MTA: ./i38GT5w7012100 mail.killerbeeprivates.com.: user open
root     13887  0.2  0.8  7160 2596 ?        S    15:19   0:19 sendmail: MTA: ./i37Jx5w5017101 8040.daisyinmyeye.com.: user open
root     14875  0.1  0.8  7060 2592 ?        S    15:29   0:14 sendmail: MTA: ./i38M96w5032083 4296.humptydumptymail.com.: user open
root     15618  0.1  0.7  7060 2552 ?        S    15:39   0:14 sendmail: MTA: ./i3A5T7w6002798 mail.carefulchristianconsumer.com.: user ope
root     16262  0.2  0.8  7148 2600 ?        S    15:49   0:18 sendmail: MTA: ./i37MJ5w5008084 4474.icantstophavingfunhere.com.: user open
root     17905  0.2  0.8  7164 2620 ?        S    15:59   0:18 sendmail: MTA: ./i37Fx4w5026931 6964.whoopsuoptedin.com.: user open
root     19134  0.2  0.7  7060 2548 ?        S    16:09   0:14 sendmail: MTA: ./i399T6w7001839 4826.tearyonionmarketing.com.: user open
root     20671  0.2  0.7  7052 2536 ?        S    16:19   0:14 sendmail: MTA: ./i38Jx6w5006618 3099.inboxofjoy.com.: user open
root     22015  0.2  0.7  7060 2552 ?        S    16:29   0:14 sendmail: MTA: ./i398d6w9028343 niceonecyril.com.: user open
root     24656  0.3  0.8  7048 2568 ?        S    16:39   0:15 sendmail: MTA: ./i397T6w6013556 2391.clickyclickyclick.com.: user open
root     29172  0.1  0.7  7048 2560 ?        S    16:49   0:08 sendmail: MTA: ./i3B6T8w6022365 mx3.sheck-buy.com.: user open
root     30447  0.2  0.7  7052 2484 ?        S    16:59   0:07 sendmail: MTA: ./i3AKx8w5002200 4450.funtobuydomains.com.: user open
root     31928  0.2  0.7  7052 2484 ?        S    17:09   0:07 sendmail: MTA: ./i3B7J8wB028582 mail.real-coupons.com.: user open
root      2850  0.3  0.7  7048 2500 ?        S    17:19   0:07 sendmail: MTA: ./i3B7J8wC028582 mail.real-coupons.com.: user open
root      7230  0.3  0.7  7048 2496 ?        S    17:29   0:07 sendmail: MTA: ./i3AFT7w5004317 9046.gropingnotallowedmail.com.: user open
root      8246  0.1  0.7  6952 2536 ?        S    17:39   0:02 sendmail: MTA: ./i3C5J9w6013150 6610.bestopenrates.com.: user open
root     10438  0.3  0.7  6952 2452 ?        S    17:49   0:02 sendmail: MTA: ./i3C6x9w5031396 2289.getallyouwantfrommyemail.com.: user open
Nu heb ik al wat filters eropstaan nml de RulesduJour. Ook als ik in de Sendmail queue kijk, staan er 2657!!(welke alle met een EX_TEMPFAIL error) berichten in.
Is dit normaal? en zo ja, hoe kom ik hier vanaf?
  • Zwerver
Gewoon zorgen dat je geen open relay hebt? Probeer anders eens te testen met verschillende openrelay testers of je relay dichtzit! In principe zou sendmail nl dit soort berichten niet mogen geven, want de relay zit dicht, en als deze melding wel komt dan heeft het te maken met het niet kunnen resolven van het afzender- dan wel het receipt adres.
Woonachtig Down Under. Ik negeer je insults niet, maar tegen de tijd dat ik ze lees zijn ze meestal niet relevant meer
  • WarPuppy
WarPuppy
Zwerver schreef op 12 april 2004 @ 21:07:
Ik heb het even getest @ http://www.abuse.net/cgi-bin/relaytest
en dit kwam eruit:
Relay test result
All tests performed, no relays accepted
Dus dat zit wel snor ! :7
Heb jij enig idee hoe ik ze dan kan weggooien en dit voorkomen? (en meer als 2,6k berichten weggooien met de hand is me iets teveel...)
  • igmar
  • Laatst online: 23-08 16:57
igmar
ISO20022
WarPuppy schreef op 12 april 2004 @ 18:07:
Leute,
Door in je logfiles te kijken wat de oorzaak van de TEMP_FAIL is, en die op te lossen.
