[Far Cry Demo] Loading halt bij het laatste stukje
  • 0xDEADBEEF
Alright, titel zegt denk ik genoeg..
Het laden duurt ~één uur.
Heb deze logs/configbestanden:
rc.ini
rc_presets_pc.ini
rc_log_errors.log
rc_log_warnings.log
gamecfg.lua
playercfg.lua
systemcfg.lua
log.txt
mapcycle.txt
*.log zijn leeg
log.txt:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
176
177
178
179
180
181
182
183
184
185
186
187
188
189
190
191
192
193
194
195
196
197
198
199
200
201
202
203
204
205
206
207
208
209
210
211
212
213
214
215
216
217
218
219
220
221
222
223
224
225
226
227
228
229
230
231
232
233
234
Log Started at Friday, April 09, 2004 18:38:38
FileVersion: 1.1.5.1120
ProductVersion: 1.1.5.1120
File System Initialization
--- CPU detection ---
Number of system processors: 2
Number of available processors: 2
Processor 0:
CPU: GenuineIntel               Intel(R) Pentium(R) 4 CPU 3.00GHz
Family: 15, Model: 2, Stepping: 9
FPU: on-chip
CPU Speed (estimated): 2993.409203 MHz
MMX: present
SSE: present
3DNow!: not present
Serial number not present or disabled
Processor 1:
FPU: on-chip
CPU Speed (estimated): 2993.428463 MHz
MMX: present
SSE: present
3DNow!: not present
Stream Engine Initialization
Script System Initialization
Network initialization
Physics initialization
MovieSystem initialization
Renderer initialization
System: INFO: DirectX 9.0b installed
System: VideoCard Detected: Intel (865G)
Direct3D9 driver is creating...
Best-match display mode: 1024x768x32 (Error=8)
Creating D3D device (Adapter format: D3DFMT_X8R8G8B8, BackBuffer format: D3DFMT_A8R8G8B8, Depth format: D3DFMT_D24S8)
D3D Adapter: Driver name: ialmrnt5.dll
D3D Adapter: Driver description: Intel(R) 82865G Graphics Controller
D3D Adapter: Driver version: 6.13.10.3510
D3D Adapter: Driver GUID: D7B78E66-6632-11CF-80EE7805A0C2CB35
D3D Adapter: VendorId = 32902
D3D Adapter: DeviceId = 9586
D3D Adapter: SubSysId = 628260998
D3D Adapter: Revision = 2
D3D Detected: Intel video card
D3D Driver: MaxTextureBlendStages   = 4
D3D Driver: MaxSimultaneousTextures = 4
  Using '8888' pixel texture format
  Using 'Alpha8' pixel texture format
  Using 'DXT1' pixel texture format
  Using 'DXT3' pixel texture format
  Using 'DXT5' pixel texture format
D3D Driver: Supports trilinear texture filtering
D3D Driver: Allowed projected textures with Env. bump mapping
D3D Driver: Supports range-based fog
D3D Driver: Supports eye-relative fog
D3D Driver: Supports anisotropic filtering
D3D Driver: Supports LOD biasing
D3D Driver: Supports D3DTOP_ADDSIGNED2X TextureOp
D3D Driver: Supports D3DTOP_DOTPRODUCT3 TextureOp
D3D Driver: Supports D3DTOP_MODULATEALPHA_ADDCOLOR TextureOp
D3D Driver: Supports D3DTOP_MODULATECOLOR_ADDALPHA TextureOp
D3D Driver: Supports D3DTOP_ADD TextureOp
D3D Driver: Supports MaxAnisotropy level 2
D3D Driver: Supports Stencil shadows
D3D Driver: Textures (0x0)-(2048x2048), Max aspect 2048
 Full stats: HAL (sw vp): Intel(R) 82865G Graphics Controller
 Hardware acceleration: Yes
 Full screen AA: Disabled
 Stencil type: Single sided
 Projective EMBM: enabled
 Detail textures: Yes
 Z Buffer Locking: Yes
 Use multitexture mode: Yes (4 texture(s))
 Use bumpmapping : Yes (DOT3)
 Use paletted textures : No
 Current Resolution: 1024x768x32 Full Screen
 Maximum Resolution: 1280x1024
 Maximum Texture size: 2048x2048 (Max Aspect: 2048)
 Texture filtering type: TRILINEAR
 Use 32 bits textures
 Gamma control: Hardware
 Vertex Shaders version 0.0
 Pixel Shaders version 0.0
 Use Hardware Shaders for NV2x GPU
 Pixel shaders usage: Replace PS.2.0 to PS.1.1
 Shadow maps type: 2D shadow maps
Init Shaders
WARNING: Error: CTexMan::ImagePreprocessing: Scaling of 'textures/defaults/palletteheat.dds' compressed texture is dangerous (only one mip)
  9 Shader files found.
  91 Shader files found.
Construct Shader '<Default>'...ok
Construct Shader 'ZBuffPass'...ok
Construct Shader 'ShadowMap'...ok
Construct Shader 'EdgePass'...ok
Compile System Shader 'StateNoCull'...ok
Compile System Shader 'SunFlares'...ok
  2 Sun flares was parsed
Compile System Shader 'LightStyles'...ok
  34 Light styles was parsed
Compile Glare Shader ...
Compile System HW Shader 'CGVProgramms'...ok
Compile System HW Shader 'CGPShaders'...ok
Compile System Shader 'TemplFog'...
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCFog' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCFog' (D3DERR_INVALIDCALL)ok
Compile System Shader 'TemplVFog'...Fail.
Compile System Shader 'TemplFog_FP'...ok
Compile System Shader 'TemplFogCaustics'...
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCCaust' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCCaust' (D3DERR_INVALIDCALL)ok
Compile System Shader 'TemplVFogCaustics'...Fail.
Compile System Shader 'TemplFogCaustics_FP'...ok
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCAlpha' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCAmbient' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCShadowGenDiffuseAlpha_Depth' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCShadowGen_Depth_Alpha' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCShadowGen_Depth' (D3DERR_INVALIDCALL)
WARNING: Shader 'whiteshadow' has opaque maps defined after pass 0!!!
WARNING: Shader 'whiteshadow' has depthwrite enabled after pass 0!!!
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCHeat_Alpha' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCLight_InvProjSingleLight' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCLight_InvSingleLight' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCDetailAtten' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCHeat_TreesSprites' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCTreeSprites_FV' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCTreeSprites' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCSun' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCBlur' (D3DERR_INVALIDCALL)
Console initialization
Time initialization
Input initialization
Initializing Direct Input
Direct Input initialized (CryInputDLL)
Initializing Keyboard
Keyboard initialized
Initializing mouse
Mouse initialized
Found 16 joystick devices
Joystick 0 not plugged in!
Joystick 1 not plugged in!
Joystick 2 not plugged in!
Joystick 3 not plugged in!
Joystick 4 not plugged in!
Joystick 5 not plugged in!
Joystick 6 not plugged in!
Joystick 7 not plugged in!
Joystick 8 not plugged in!
Joystick 9 not plugged in!
Joystick 10 not plugged in!
Joystick 11 not plugged in!
Joystick 12 not plugged in!
Joystick 13 not plugged in!
Joystick 14 not plugged in!
Joystick 15 not plugged in!
Joystick initialized
initializing Key/name Mapping
Sound initialization
------------------------------------------CRYSOUND VERSION=3.610000
CRYSOUND Driver: Primair geluidsstuurprogramma
Total number of channels available: 286
Total number of hardware channels available: 0
Set speaker mode stereo
Font initialization
AI initialization
Entity system initialization
Initializing Animation System
CPU capabilities:  FPU VME DE PSE TSC MSR PAE MCE CX8 APIC SEP MTRR PGE MCA CMOV PAT PSE-36 CLFSH DS ACPI MMX FXSR SSE SSE2 SS HTT TM PBE ok
Initializing 3D Engine
WARNING: Texture format '.tga' is deprecated ('textures/spot_shadow.tga') (use .dds instead)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCMotion' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCMotionAmount' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCGlareMap' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCGlareAmount' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCGlare' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCRenderModeCold' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCColorTransfer' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCBluryScreen' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCNightVisionGlare' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCHeatSourcePass' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCHeatSourceDecode' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCFlashBang' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCCartoon' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCCartoonSilhouete' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGRCRGBToAlpha' (D3DERR_INVALIDCALL)
WARNING: CCGPShader_D3D::mfLoad: Could not create pixel shader 'CGPSScreen' (D3DERR_INVALIDCALL)
Removing lights ...
Deleting visareas ...
Deleting terrain ...
ObjManager shutdown ...
Initializing Script Bindings
Cpu speed is 2993,sys spec is set to 3
Zou het helpen om de patch/upgrade naar v1.1 eroverheen gooien ?
[ Voor 7% gewijzigd door 0xDEADBEEF op 10-04-2004 12:42 ]
"Religion is an insult to human dignity. With or without it you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg
  • Jellabie
  • Laatst online: 10:25
Jellabie
wie laatst lacht..... is dom
Misschien iets doms, maar:
kreeg ik ook... ik heb mijn pc laten scannen op virussen, hij had 791 besmette files gevonden, die laten maken en ik kon far cry spelen.
edit: die patch kan je er altijd opgooien, is altijd beter.
[ Voor 10% gewijzigd door Jellabie op 09-04-2004 22:25 ]
De Nederbelg !
  • 0xDEADBEEF
Patchen lukt niet, t ding wil n script van internet halen; maar de pc waarop die Demo draait kan daar niet bij --> heb daar geen internet beschikbaar :/
  • 0xDEADBEEF
Conclusie: de demo kan niet gepatched worden :(
Afbeeldingslocatie: http://www.vollering.cistron.nl/far%20cry/fc-demo-warning2.png
[ Voor 48% gewijzigd door 0xDEADBEEF op 11-04-2004 19:54 . Reden: added png ]
0xDEADBEEF schreef op 11 april 2004 @ 10:42:
Inderdaad, demo's kunnen ook bijna niet gepatcht worden met patches die voor de full-version bedoeld zijn.
