Nieuwe ati drivers installeren
  • 103 views sinds 30-01-2008
  • maikel7
  • Laatst online: 27-07 18:46
Hallo
ik wil de nieuwe ati drivers installeren (4.3) en heb dit ook al wel een aantal keren gedaan. Echter naar mijn mening is het niet goed gelukt, omdat ik nog wat problemen ondervind in Far Cry en Battlefield Vietnam. Ik lees dat meer mensen problemen hebben met bijv. Far cry, maar toch wil ik eerst de nieuwe drivers op de juiste manier installeren en dan kijken of ik nog steeds problemen heb.
Ik wil het op de volgende manier gaan doen:
Uninstallation procedure:
Before you begin to uninstall, disconnect your computer from your internet or network! If you are connected to the internet, Windows, always impertinently thinking that it knows best, may try and install whatever Radeon driver is on Windows Update. We don't want to let it do this. So, either a) turn off your modem, or b) take out your phone jack (if you're on dial-up).
Go to the Windows Control Panel, and then to Add/Remove Programs. Select for removal any ATI entries. When asked, opt not to reboot.
Get the abovementioned ATI Uninstall Utility. It is not necessary to run this program in safe mode. Double-click on it, and then press “Ok” when a popup asks you if you wish to continue.
Reboot and install the new drivers (see below).
Note: If you have any ATI demos or ATI screensavers installed, the ATI Uninstaller will ask you if you want to remove them as well in a cryptic message, “Are you sure you want to uninstall this product?” You will get as many of those messages as you have non-driver related ATI products installed. Selecting “No” will NOT have an adverse effect on the driver removal process.
Installation:
After you remove your drivers and finish rebooting, Windows will popup the Found New Hardware "Wizard." Cancel out of it; it's useless and most unhelpful. It will popup twice in total, the first for your card and the second for its secondary (TV Out). Cancel out of both – we don’t need the help of Windows to install drivers. From here, it’s very simple. Go to wherever you downloaded the ATI drivers and double click the installer package. Follow the onscreen prompts; let it do its thing, and then reboot when asked.
Mijn probleem is nu dat ik bij het rebooten niet snel genoeg kan de popup found new hardware kan cancellen, waardoor windows toch drivers installeert. Hoe kan ik dit verhelpen?????????????????
  • Puppetmaster
  • Laatst online: 21:38
zoek ff de drivercleaner op http://www.driverheaven.net/cleaner/
die verwijdert net wat meer waardoor win de hardware niet zo makkelijk meer installeert :+
(das tenminste mijn ervaring)
[ Voor 28% gewijzigd door Puppetmaster op 06-04-2004 12:44 ]
It seems that males are allowed to exist after all, because they help females get rid of deleterious mutations...
  • Janao
  • Laatst online: 16-06 20:19
Janao
Dog Clubbing Cat
een maat van mij (screamer) heeft ook een ATI en die heeft na installatie van de nieuwste drivers (op de goede manier) ook nog steeds texture corruption in BFVietnam.
ik denk eerder dat het meer een probleem is van BFV/FarCry <-> ATI. 't zal vast wel opgelost worden in een volgende driverupdate/gameupdate. suc6
I am not responsible for any harm or damage to you or your computer caused by the above message
  • maikel7
Puppetmaster schreef op 06 april 2004 @ 12:42:
Beste Puppetmaster kan ik in plaats van de drivercleaner ook de ATI Uninstaller gebruiken of is deze minder goed??
