[SOFII] OpenGl error
  • l-burna
  • Laatst online: 10-10 21:30
l-burna
2nd place, is the 1st loser
Ik krijg een opengl error bij het laden van solder of fortune 2.
ik heb alles had ik kon bedenken al geprobeerd.
ik heb de laatste drivers (catalyst 4.3) en directx 9
heb een club 3d 9700 pro video kaart
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
SOF2MP GOLD V1.03 win-x86 Nov  5 2002
Initialising zone memory .....
----- FS_Startup -----
Current search path:
D:\SOLDIE~1/base/MP
D:\SOLDIE~1\base\update103.pk3 (55 files)
D:\SOLDIE~1\base\update102.pk3 (213 files)
D:\SOLDIE~1\base\update101.pk3 (298 files)
D:\SOLDIE~1\base\therest.pk3 (7125 files)
D:\SOLDIE~1\base\textures1234.pk3 (10843 files)
D:\SOLDIE~1\base\textures0.pk3 (2816 files)
D:\SOLDIE~1\base\skins.pk3 (4117 files)
D:\SOLDIE~1\base\musicandsound.pk3 (3055 files)
D:\SOLDIE~1\base\mp.pk3 (338 files)
D:\SOLDIE~1\base\models.pk3 (3643 files)
D:\SOLDIE~1\base\maps.pk3 (466 files)
D:\SOLDIE~1/base
32969 files in pk3 files
execing sof2mp_default.cfg
execing sof2mp.cfg
execing autoexec.cfg
Hunk_Clear: reset the hunk ok
OS: Microsoft WinXP Service Pack 1 (NT)
CPU Detected: Athlon/Duron
Athlon/Duron
---------- Input Initialization ----------
Skipping check for DirectInput
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
WARNING: tess.xyz not 16 byte aligned
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\System32\opengl32.dll' ): succeeded
...setting mode 8: 1280 1024 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (1280x1024)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (8)
...setting mode 3: 640 480 FS
...using colorsbits of 16
...calling CDS: ok
...created window@0,0 (640x480)
...GLW_ChoosePFD( 16, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD( 16, 24, 0 )
...35 PFDs found
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
----- CL_Shutdown -----
RE_Shutdown( 1 )
R_Terrain: Shutting down RENDERER terrain.....
GLW_StartOpenGL() - could not load OpenGL subsystem
------------- Input Shutdown -------------
iemand enige idee hoe ik het kan oplossen?
The older I get, the better I was. -=]No Fear[=-
draai eens dxdiag, ik heb het probleem gehad, en bleek dat netmeeting nog in me taakbalk stond, deze gebruikte dus direct3d en spellen met opengl deden nix meer.
dxdiag gaf bij mij aan dat het in gebruik was,
misschien heb je hetzelfde probleem....
Start --> Programma's --> Bureau-accessoires --> systeem werkset --> systeeminfo
Nu start Systeem info op.
Je moet nu naar "hulpprogramma's" gaan en kiezen uit de lijst voor:
Diagnostisch hulpprogramma voor DirextX..... deze wordt geopend..
Klik op het tabblad beeldscherm... Hier geeft hij onderaan in of er ook problemen zijn.
Ik weet niet of je er wat aan hebt, maar ik hoop het wel. :?
Heb je dit probleem wel vaker gehad? Ook met andere spellen?
[ Voor 10% gewijzigd door Verwijderd op 06-04-2004 09:34 ]
  • Pubbert
  • Laatst online: 18-10 09:00
Pubbert
random gestoord
Zo opstarten:
X:\Sof2\Sof2MP.exe -safe
(zelf snelkoppeling maken of via Uitvoeren/Run)
Dan werkt het wel als het goed is :)
Waar X == Jouw HD waar Sof2 opstaat, en \Sof2\ == jouw installdir ;)
[ Voor 49% gewijzigd door Pubbert op 06-04-2004 10:02 ]
  • l-burna
l-burna
Verwijderd schreef op 06 april 2004 @ 09:31:
ik heb het alleen bij SOFII
ik heb diagnotisch directx ding gedraait en onderin staat dit.
The file ati2dvag.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs. You may be able to get a signed driver from the manufacturer of the hardware device.
weet niet wat ik ermee moet 8)7
dat is niet van belang, dat wil niet zeggen dat het niet werkt,
weet je zeker dat je andere allerlei losse progsels hebt afgesloten?!
  • Pubbert
Pubbert
random gestoord
l-burna schreef op 06 april 2004 @ 10:10:
Probeer mijn oplossing nu eens :)
  • l-burna
l-burna
Thund3r schreef op 06 april 2004 @ 15:04:
heb ik gedaan, werkt ook niet.
ik kom er niet meer uit :O
het heeft het voorheen wel gedaan, raar dat het plotseling niet meer werkt :Z
@djredmar
ja dat weet ik zeker
[ Voor 6% gewijzigd door l-burna op 06-04-2004 15:41 ]
dan heb ik ook geen id...
je zou kunnen kijken voor een patch / update van sof2?!
Heb ik gehad met mohaa is iets met die q3 engine maar bij mij was het opgelost na nieuwe drivers voor men videokaart. :)
  • l-burna
l-burna
Verwijderd schreef op 06 april 2004 @ 22:25:
ik heb de laatste drivers, dus daaraan ligt het niet.
ik weet het nu ook echt niet meer :(
Ik had ook zelfde fout gehad, met een Gforce videokaart, en heb toen na tips de drivers geupdate op de site van Nvidia, en toen is het probleem verholpen! 8) Try It.. ;)
l-burna schreef op 07 april 2004 @ 08:03:
Probeer anders een wat oudere driver, bv die je gebruikte toen het nog wel werkte.
zeg je desktop kleuren eens op 16bit ipv 32bit, ATi drivers hebben meestal ruzie met 32bit OpenGL
  • Pubbert
Pubbert
random gestoord
weet je zeker dat je mijn oplossing goed uitgevoerd hebt ( dat met -safe)
want wat hij dan doet is gewoon alle settings op off/low. Hij laad het opengl dan ook niet, en dus kán hij de foutmeldingen in feite niet weergeven.
  • l-burna
l-burna
edit: ik heb het aan de praat gekregen.!
thnx voor de hulp iig
[ Voor 106% gewijzigd door l-burna op 08-04-2004 19:37 ]
Hoe dan? 8)7 Misschien effe handig om te melden voor de toekomst etc.
  • l-burna
l-burna
Verwijderd schreef op 08 april 2004 @ 23:50:
sorry, ik werd gewoon zat en heb het voor een 3e keer geinstalleerd en toen werkte het in eens wel 8)7
