Kweek 3 wilt niet starten...
  • 120 views sinds 30-01-2008
  • Blue-eagle
Q3 1.11 win-x86 Nov 24 1999
----- FS_Startup -----
Current search path:
F:\Quake3\baseq3\pak1.pk3 (7 files)
F:\Quake3\baseq3\pak0.pk3 (2964 files)
F:\Quake3/baseq3
execing default.cfg
execing q3config.cfg
couldn't exec autoexec.cfg
...detecting CPU, found x86 (P5/Pentium2, MMX)
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
--- Common Initialization Complete ---
Winsock Initialized
Opening IP socket: localhost:27960
Hostname: cc28211-a.mshome.net
IP: 192.168.0.1
IP: 212.204.149.71
Working directory: F:\Quake3
----- R_Init -----
Initializing OpenGL subsystem
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
...shutting down QGL
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\SYSTEM\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using desktop display depth of 16
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 16, 16, 0 )
...23 PFDs found
...GLW_ChoosePFD failed
...23 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...using colorsbits of 16
...calling CDS: ok
...23 PFDs found
...23 PFDs found
...unloading OpenGL DLL
----- CL_Shutdown -----
RE_Shutdown( 1 )
GLW_StartOpenGL() - could not load OpenGL subsystem
Wat is dit? Hij deed het altijd wel! ;(
  • Warbringer
  • Laatst online: 21:40
reinstall?
hebbie van DirectX versie gewisself misschien?
I want to live forever, so far.. so good.
  • Blue-eagle
fok! dat kan... ff restart. tnx!
he jij moet opengl noch instaleeren www.glsetup.com ofzo
Of meer geheugen of nieuwe drivers downloaden
  • Glorix Jim
  • Laatst online: 30-06 14:30
Hou het maar op nieuwe drivers :)
Wat voor videokaart heb je?
  • Twilight Burn
  • Laatst online: 02-07 07:58
Als je een Dual monitor setup hebt moet je je 2e monitor uitschakelen en dan het spel opstarten (kreeg de zelfde foutmelding bij Elite Force, das ook de Q3 Engine)
  • digifun
digifun
Quake moet kunnen lopen op een dual monitor opstelling.Weet iemand hier de commando's voor ??? Ik heb hier een twinview met twee monitoren en het lijkt me wel eens mooi om dat te gebruiken.
u can fool all people some time and fool some people alltime
  • Blue-eagle
Ik heb laatst moeten wisselen van 3d kaartje. Er zat een goede in (vraag geen details aub... weet ik nixx van) met 16 mb erop. Nu zit er een op met óók 16 mb, mét DVD ondersteuning...
Alleen, kan het zijn dat deze geen openGL ondersteund??:??
Help?!
