Yamaha - Chario - MJ Acoustics - Squeezebox - Trends Audio - Beresford
*schop*
Je kan proberen om outlook express even opnieuw te instaleren ,
dit kan je op de volgende manier doen,
( hiervoor is wel de installatie cd van windows nodig )
1. Open the Start menu and select Run.
2. Type %SystemRoot%\Inf in the prompt and press Enter.
3. Locate and right-click the Msoe50.inf file.
4. Select Install.
5. Close the folder window after the copy process is complete.
6. Run OE.
4. Select Install.
6. Run OE.
