Ik wil mischien deze mp3 speler kopen maar kan er op got en google weinig over vinden.
Afbeeldingslocatie: http://www.kieskeurig.nl/nl/product.nsf/0/A9FD4E2D1A3EB1D5C1256DDC0033DF2C/$file/MP3_Flash_Stick_300x300.jpg
Iemand ervaring hiermee? geluidskwalieit, batterij duur enz?
Ik twijfel tussen deze en de MSI Mega stick :)
kent niemand deze speler? :(
  • aryan
  • Laatst online: 31-07 16:38
www.acer.nl
Acer USB 2.0 Flash Stick
USB 2.0 Flash Stick
Full Compliance with the Universal Serial Bus Specification v2.0 and v1.1.
Offers 128MB, 256MB, 512MB, and 1GB capacities.
Bootable funktion with Password and Data Write-Protect Switch.
High performance write over 7Mbyte/s and read over 8Mbyte/s.
Windows Mass Storage Device class compatible so no driver needed in Windows ME, 2000, XP or above. Only requires USB2.0 device driver in advance.
Bus Powered – no separate power supply or battery required.
Shock resistant, noise-free and longer data retention.
Acer USB 2.0 Flash Stick works as a friendly and lightweight removable mass storage device disk. It plugs thru the USB port so your computer will immediately detect and configure the disk without needing to restart the computer. You read, write, copy and delete files just the same way as you use a disk drive. You can even play MP3 files, run applications or play videos directly from it. This Acer USB 2.0 Flash Stick is so light and compact that you can carry it with you anywhere. It comes in various storage capacities starting at 128MByte up to 1GByte. It is easy to install that you can actually use the Acer USB 2.0 Flash Stick to replace your floppy diskettes, ZIP drives, and even CD-RW discs. And because it uses durable solid-state storage flash memory, there are no moving parts inside making it shock resistant and longer to use.
dit is een andere neem ik aan :)
usb 2.0 en videobeelden bekijken :P nee ik bedoel de mp3 flash stick..
btw ik zoek meer ervaringen van mensen want specs heb ik al :)
  • Hercul3s
  • Laatst online: 11:12
Misschien handig als je de specs ff kan posten, kunnen ervaren mensen commentaar geven of het een goeie speler is.
Voor welke prijs is ie trouwens te koop?
Oh, je zei op google kan je niks vinden?
1) Klik!
2) Prijzen + specs
Ik wil niks zeggen, maar ietsje beter zoeken mag misschien ook wel...
Over het algemeen had ie een 8,0 bij 2 sites die ik snel zag, zou als ik jou was nog even reviewtjes lezen en dan besluiten.
ja alleen die site van kieskeurig had ik gevonden, verder niks.
en verder is het alleen maar prijzen en specs op google..
  • Hercul3s
Klik. De bovenste 2 links zijn 2 kleine reviewtjes, kijk maar eens.
