hoe draadloos netwerk kaart installeren
  • 53 views sinds 30-01-2008
  • justinb81
  • Laatst online: 09:54
ik heb een laptop met daarop redhat 9, het werkt perfect, maar ik wil mijn draadloze pcmciaa netwerk kaartje installeren. ik weet verder niets van linux.
ik heb de driver van realtek gedownload en hier zit een readme bij.
hoe moet ik dit doen?
< Component >
The driver is composed of several parts:
(1)source code
driver module initialization and interface between rtl8180 driver and system call.
r8180_pci_init.c driver module initialization and register/unregister network device
r8180_pci_init.h include file
r8180_if.c interface between rtl8180 driver and system call
r8180_if.h include file
r8180_type.h type definition for rtl8180 driver
r8180_export.h exported function name from rtl8180 driver
(2)object code
rtl8180 driver
priv_part.o rtl8180 driver object code
(3)Default driver
rtl8180_24x.o default driver module compiled in kernel 2.4.18.
(4)Makefile
PLEASE SPECIFY INCLUDEPATH CORRECTLY ACCORDING TO YOUR LINUX ENVIRONMENT.
FOR EXAMPLE, " INCLUDEPATH=-I /usr/src/linux-2.4.18-3/include/ " in RedHat7.3.
FOR EXAMPLE, " INCLUDEPATH=-I /usr/src/linux-2.4.18-14/include/ " in RedHat8.0.
(5)wlanup/wlandown
simple script file to activate/shut_down wireless lan.
< Installation >
Please try to load linux_24x.o first by "insmod -f rtl8180_24x.o".
If it doesn't work, you are suggested to compile loadable driver module following the steps as:
(0)Make sure the C-compile version. Run "gcc -v".
If gcc version is 2.xx, use release driver RTL8180_24x_RH73.zip.
If gcc version is 3.xx, use release driver RTL8180_24x_RH90.zip.
(1)Modify macros in Makefile.
KERNELRELEASE - represent kernel release version
IO_FLAGS - pci I/O space mapping
ENDIAN_FLAGS - big/little endian
OP_MODE_FLAGS - Operation on either AP or Client mode
DRV_FLAGS - Driver debugging messge ...etc.
(2)Check pci module initialization and system call interfaces in the provided source code,
r8180_pci_init.c ....etc.
(3)Run 'make' to generate new driver module.
(4)Run 'make install' to install new driver module.
(5)Refer to < Set wireless lan MIBs > and modify script files,
wlanup/wlandown, to set Wireless LAN specific parameters.
Run wlanup/wlandown to activate/shut_down wireless lan.
Usage:
./wlanup {ap|infra|adhoc}
./wlandown
Note:
- "./wlanup ap" works if OP_MODE_FLAGS is assigned RTL_ACT_AS_AP in Makefile.
- "./wlanup {infra|adhoc}" works if OP_MODE_FLAGS is assigned RTL_ACT_AS_AP
in Makefile.
This driver uses Wireless Extension as an interface allowing you to set
Current driver supports "iwpriv", manipulate driver private ioctls, to set MIBs.
iwpriv wlan0 wlan_para [parameters]=[val]
where
parameter explaination [parameters] [val] constraints
Set beacon interval bcnint {20~1000} msec
Set channel number channel {1~14}
Set basic rates basicrates {bit0 = 1Mbps, bit1 = 2Mbps, bit2 = 5.5Mbps, bit3 = 11 Mbps}
Set operational rates oprates {bit0 = 1Mbps, bit1 = 2Mbps, bit2 = 5.5Mbps, bit3 = 11 Mbps}
Set authentication type authtype {opensystem, sharedkey, both<only AP mode>}
Set desired ssid to scan ssid2scan {0~z, less than 32 characters}
Set RTS threshold rtsthres {256~2304}
Set fragment threshold fragthres {256~2304}
Set preamble mode preamble {short,long,auto}
Set network type networktype {infra,adhoc,auto}
Set WEP mode wepmode {off,wep40,wep104}
Set WEP default key ID wepdkeyid {0~3}
Set 1st WEP40 key value wepkey40_1 {0~f, total 10 characters}
Set 2st WEP40 key value wepkey40_2 {0~f, total 10 characters}
Set 3st WEP40 key value wepkey40_3 {0~f, total 10 characters}
Set 4st WEP40 key value wepkey40_4 {0~f, total 10 characters}
Set 1st WEP104 key value wepkey104_1 {0~f, total 26 characters}
Set 2st WEP104 key value wepkey104_2 {0~f, total 26 characters}
Set 3st WEP104 key value wepkey104_3 {0~f, total 26 characters}
Set 4st WEP104 key value wepkey104_4 {0~f, total 26 characters}
Set AP ssid ssid {0~z, less than 32 characters}
Set Mac address macaddr {0~f, total 6 characters}
Set DTIM period dtimperiod {1~255}
Set hidden AP hiddenAP {true,false}
Set mac filter policy addmac {0~f, total 6 characters}
Delete mac filter policy delmac {0~f, total 6 characters}
Set deny mac filter policy denymacaddr {0~f, total 6 characters}
Delete deny mac filter deldenymacaddr {0~f, total 6 characters}
Set sta expired time expired_time {1~100000} *10 msec
Set rate adaptive autorate {true,false}
Print help message help
For example:
iwpriv wlan0 wlan_para bcnint=100
iwpriv wlan0 wlan_para channel=1
iwpriv wlan0 wlan_para basicrates=0xf
iwpriv wlan0 wlan_para oprates=0xf
iwpriv wlan0 wlan_para authtype=opensystem
iwpriv wlan0 wlan_para ssid2scan=testssid
iwpriv wlan0 wlan_para fragthres=512
iwpriv wlan0 wlan_para preamble=long
iwpriv wlan0 wlan_para wepmode=off
iwpriv wlan0 wlan_para wepdkeyid=0
iwpriv wlan0 wlan_para wepkey40_1=0123456789
iwpriv wlan0 wlan_para wepkey104_1=01234567890123456789012345
iwpriv wlan0 wlan_para networktype=infra
iwpriv wlan0 wlan_para ssid=apssid
iwpriv wlan0 wlan_para macaddr=00e04c8180ff
iwpriv wlan0 wlan_para hiddenAP=true
iwpriv wlan0 wlan_para addmac=00e04c8180ff
iwpriv wlan0 wlan_para denymacaddr=00e04c8180ff
iwpriv wlan0 wlan_para help;
Also, you could set parameters as follow:
iwpriv wlan0 wlan_para bcnint=100,channel=1,basicrates=0xf,authtype=opensystem,ssid2scan=testssid
Alvast bedankt voor het helpen van een beginnende linux gebruiker die windows zat is.
Blah, die realtek drivers werken echt helemaal niet. Probeer het over een paar weken met ndiswrapper. Daarvan zijn de helpfiles ook iets duidelijker :)
Het probleem is dat de nieuwste stable versie hiervan niet met deze kaart werkt (heb zelf deze #8#@*$& kaart ook ;( ) en de CVS versie werkt er al wel mee :D, maar laat de comp soms vastlopen :( Dus ik zou nog ff w8ten ;)
  • Tomaat
  • Laatst online: 13-05 13:50
Die Realtek drivers werken dus echt wel!
'k heb zelf ook draaiend met mijn Sweex WLAN NIC'je waar dus ook een RTL8180 chip opzit (onder Debian) :)
  • justinb81
Tomaat schreef op 27 maart 2004 @ 23:09:
Ik heb ook die sweex kaart. Hoe krijg je dat voor elkaar dan?
  • blaataaps
justinb81 schreef op 28 maart 2004 @ 00:30:
In je startpost pleur je een heel verhaal uit een of andere readme lijkt het, misschien eerst die eens volgen? En anders op internet eens kijken of iemand anders toevallig ook zo een kaart heeft, misschien zelfs wel op dit forum. Volgens NOS policy - updated 01/04/03 verwachten we hier het een en ander, namelijk dat je zelf ook wat probeert en uitzoekt en dat vertelt, in plaats van alles voor laten kauwen. Daarom doe ik deze dicht, succes!
