[vmware] vmmon fout
ik ben vmware 4.0.5 proberen aan het installeren op linux.
Nu ben ik bij het ./vmware-config.pl aanbeland.
Omdat ik geen (goede) vmmon modules heb wil hij ze zelf gaan maken:
Dan krijg ik de volgende foutmelding om mijn oren vliegen:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
make: Entering directory `/tmp/vmware-config1/vmmon-only'
make[1]: Entering directory `/tmp/vmware-config1/vmmon-only'
make[2]: Entering directory `/tmp/vmware-config1/vmmon-only/driver-2.6.3'
In file included from /lib/modules/2.6.3/build/include/asm/smp.h:18,
                 from /lib/modules/2.6.3/build/include/linux/smp.h:17,
                 from /lib/modules/2.6.3/build/include/linux/sched.h:23,
                 from /lib/modules/2.6.3/build/include/linux/module.h:10,
                 from ../linux/driver.c:16:
/lib/modules/2.6.3/build/include/asm/mpspec.h:6:25: warning: mach_mpspec.h: No such file or directory
In file included from /lib/modules/2.6.3/build/include/linux/smp.h:17,
/lib/modules/2.6.3/build/include/asm/smp.h:72:26: warning: mach_apicdef.h: No such file or directory
                 from /lib/modules/2.6.3/build/include/linux/topology.h:33,
                 from /lib/modules/2.6.3/build/include/linux/mmzone.h:297,
                 from /lib/modules/2.6.3/build/include/linux/gfp.h:4,
                 from /lib/modules/2.6.3/build/include/linux/slab.h:15,
                 from /lib/modules/2.6.3/build/include/linux/percpu.h:4,
                 from /lib/modules/2.6.3/build/include/linux/rcupdate.h:42,
                 from /lib/modules/2.6.3/build/include/linux/dcache.h:10,
                 from /lib/modules/2.6.3/build/include/linux/fs.h:17,
                 from ../linux/hostif.c:22:
                 from ../common/vmx86.c:19:
make[2]: Leaving directory `/tmp/vmware-config1/vmmon-only/driver-2.6.3'
/lib/modules/2.6.3/build/include/asm/mpspec.h:6:25: mach_mpspec.h: No such file or directory
/lib/modules/2.6.3/build/include/asm/mpspec.h:8: `MAX_MP_BUSSES' undeclared here (not in a function)
/lib/modules/2.6.3/build/include/asm/mpspec.h:9: `MAX_MP_BUSSES' undeclared here (not in a function)
/lib/modules/2.6.3/build/include/asm/mpspec.h:10: `MAX_MP_BUSSES' undeclared here (not in a function)
/lib/modules/2.6.3/build/include/asm/mpspec.h:12: `MAX_MP_BUSSES' undeclared here (not in a function)
/lib/modules/2.6.3/build/include/asm/mpspec.h:19: `MAX_APICS' undeclared here (not in a function)
/lib/modules/2.6.3/build/include/asm/mpspec.h:20: `MAX_MP_BUSSES' undeclared here (not in a function)
/lib/modules/2.6.3/build/include/asm/mpspec.h:20: conflicting types for `mp_bus_id_to_type'
/lib/modules/2.6.3/build/include/asm/mpspec.h:8: previous declaration of `mp_bus_id_to_type'
/lib/modules/2.6.3/build/include/asm/mpspec.h:22: `MAX_IRQ_SOURCES' undeclared here (not in a function)
/lib/modules/2.6.3/build/include/asm/mpspec.h:24: `MAX_MP_BUSSES' undeclared here (not in a function)
/lib/modules/2.6.3/build/include/asm/mpspec.h:24: conflicting types for `mp_bus_id_to_pci_bus'
/lib/modules/2.6.3/build/include/asm/mpspec.h:12: previous declaration of `mp_bus_id_to_pci_bus'
/lib/modules/2.6.3/build/include/asm/mpspec.h:50: `MAX_APICS' undeclared here (not in a function)
In file included from /lib/modules/2.6.3/build/include/asm/smp.h:20,
/lib/modules/2.6.3/build/include/asm/io_apic.h:160: `MAX_IRQ_SOURCES' undeclared here (not in a function)
/lib/modules/2.6.3/build/include/asm/io_apic.h:160: conflicting types for `mp_irqs'
/lib/modules/2.6.3/build/include/asm/mpspec.h:22: previous declaration of `mp_irqs'
/lib/modules/2.6.3/build/include/asm/smp.h:72:26: mach_apicdef.h: No such file or directory
/lib/modules/2.6.3/build/include/asm/smp.h: In function `hard_smp_processor_id':
/lib/modules/2.6.3/build/include/asm/smp.h:76: warning: implicit declaration of function `GET_APIC_ID'
../linux/driver.c: At top level:
../linux/driver.c:133: warning: initialization from incompatible pointer type
../linux/driver.c: In function `init_module':
../linux/driver.c:246: structure has no member named `prev'
../linux/driver.c:247: structure has no member named `next'
../linux/driver.c: In function `Panic':
../linux/driver.c:1304: warning: implicit declaration of function `_exit'
make[2]: *** [driver.o] Error 1
make[1]: *** [driver] Error 2
make[1]: Leaving directory `/tmp/vmware-config1/vmmon-only'
make: *** [auto-build] Error 2
make: Leaving directory `/tmp/vmware-config1/vmmon-only'
Unable to build the vmmon module.
For more information on how to troubleshoot module-related problems, please
visit our Web site at "http://www.vmware.com/download/modules/modules.html" and
"http://www.vmware.com/support/reference/linux/prebuilt_modules_linux.html".
Het gaat dus duidelijk mis.
Nu mijn vraag of iemand dit al eens meer heeft gehad zoja hoe ik dit kan oplossen.
Of hoe kan ik de vmmon module vast in mijn kernel bakken (weet niet welke ik moet pakken)
Heb btw ook al de modules van de site af gehaald en proberen te compilen (source), maar pakt deze tevens ook niet...same story..
[ Voor 3% gewijzigd door Verwijderd op 26-03-2004 20:45 ]
pak eerst eens Vmware 4.5.1 en probeer opnieuw.
Kijk eens rond op deze site, VMWare installeren/draaien op een 2.6n kernel vereist blijkbaar een beetje handwerk.
Ophalen van een nieuwere versie van VMWare lijkt mij sowieso de eerste stap.
  • AlterEgo
In het kort: zorg voor een nieuwere vmware (4.5.1.7568).
Deze draait zonder aanpassingen op een 2.6. kernel.
Verder wil deze vmware patch nog wel eens helpen voor eerdere versies.
De site is een beetje schimmig, maar de patches gebruik ik al tijden met goed gevolg.
