Ik wil graag van de cUrl library gebruik maken binnen PHP, ik heb de laatste versie van zowel cUrl als PHP, maar ook met vroegere versies krijg ik de volgende compilatiefouten
[atimmer@k7 php-4.3.4]$ ./configure --with-curl
Alles ok.
[atimmer@k7 php-4.3.4]$ make
gcc -Iext/curl/ -I/home/atimmer/lib/php-4.3.4/ext/curl/ -DPHP_ATOM_INC -I/home/atimmer/lib/php-4.3.4/include -I/home/atimmer/lib/php-4.3.4/main -I/home/atimmer/lib/php-4.3.4 -I/home/atimmer/lib/php-4.3.4/Zend -I/usr/local/include -I/home/atimmer/lib/php-4.3.4/ext/xml/expat -I/home/atimmer/lib/php-4.3.4/TSRM -g -O2 -c /home/atimmer/lib/php-4.3.4/ext/curl/curl.c -o ext/curl/curl.o && echo > ext/curl/curl.lo
/home/atimmer/lib/php-4.3.4/ext/curl/curl.c: In function `curl_free_post':
/home/atimmer/lib/php-4.3.4/ext/curl/curl.c:563: warning: passing arg 1 of `curl_formfree' from incompatible pointer type
/home/atimmer/lib/php-4.3.4/ext/curl/curl.c: In function `alloc_curl_handle':
/home/atimmer/lib/php-4.3.4/ext/curl/curl.c:603: error: invalid application of `sizeof' to an incomplete type
/home/atimmer/lib/php-4.3.4/ext/curl/curl.c: In function `zif_curl_setopt':
/home/atimmer/lib/php-4.3.4/ext/curl/curl.c:838: error: duplicate case value
/home/atimmer/lib/php-4.3.4/ext/curl/curl.c:695: error: previously used here
/home/atimmer/lib/php-4.3.4/ext/curl/curl.c:883: warning: passing arg 1 of `curl_formadd' from incompatible pointer type
/home/atimmer/lib/php-4.3.4/ext/curl/curl.c:883: warning: passing arg 2 of `curl_formadd' from incompatible pointer type
/home/atimmer/lib/php-4.3.4/ext/curl/curl.c:891: warning: passing arg 1 of `curl_formadd' from incompatible pointer type
/home/atimmer/lib/php-4.3.4/ext/curl/curl.c:891: warning: passing arg 2 of `curl_formadd' from incompatible pointer type
make: *** [ext/curl/curl.lo] Error 1
Weten jullie misschien wat ik nog kan proberen ?
Alles ok.
