modem hangt bij ATI3
  • it0
  • Laatst online: 27-12-2025
it0
Mijn mening is een feit.
Ik heb een isapnp davicom 336pnp onder linux geïnstaleerd
die het prima doet, echter nu wil ik vgetty instaleren en deze voert o.a. het ATI3 commando uit om de modem te identificeren echter de modem hangt dan?
Ik hoop dat het iets triviaals is
Wat info
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
03/15 21:26:54 yS2  send: ATZ[0d]
03/15 21:26:54 yS2  waiting for ``OK''
03/15 21:26:54 yS2   got: ATZ[0d]
03/15 21:26:54 yS2    CND: ATZ[0d][0a]OK ** found **
03/15 21:26:54 yS2  send: AT&F&C1&D2W0S6=5S7=60S10=15[0d]
03/15 21:26:54 yS2   got: [0d]
03/15 21:26:54 yS2    CND: OK[0a]AT&F&C1&D2W0S6=5S7=60S10=15[0d]
03/15 21:26:54 yS2    CND: AT&F&C1&D2W0S6=5S7=60S10=15[0d][0a]OK ** found **
03/15 21:26:54 yS2  mdm_send: 'AT+FCLASS=2'
03/15 21:26:54 yS2    got:[0d][0a]AT+FCLASS=2[0d]
03/15 21:26:54 yS2   mdm_command: string 'AT+FCLASS=2'
03/15 21:26:54 yS2    got:[0d][0a]OK[0d]
03/15 21:26:54 yS2   mdm_command: string 'OK' -> OK
03/15 21:26:55 yS2  mdm_send: 'AT+FCLASS=0'
03/15 21:26:55 yS2    got:[0a]AT+FCLASS=0[0d]
03/15 21:26:55 yS2   mdm_command: string 'AT+FCLASS=0'
03/15 21:26:55 yS2    got:[0d][0a]OK[0d]
03/15 21:26:55 yS2   mdm_command: string 'OK' -> OK
03/15 21:26:55 yS2  mdm_send: 'AT+FAA=1;+FCR=1'
03/15 21:26:55 yS2    got:[0a]AT+FAA=1;+FCR=1[0d]
03/15 21:26:55 yS2   mdm_command: string 'AT+FAA=1;+FCR=1'
03/15 21:26:55 yS2  mdm_send: 'AT+FBOR=0'
03/15 21:26:55 yS2    got:[0a]AT+FBOR=0[0d]
03/15 21:26:55 yS2   mdm_command: string 'AT+FBOR=0'
03/15 21:26:55 yS2  mdm_send: 'AT+FLID=""'
03/15 21:26:55 yS2    got:[0a]AT+FLID=""[0d]
03/15 21:26:55 yS2   mdm_command: string 'AT+FLID=""'
03/15 21:26:56 yS2   mdm_command: string 'OK' -> OK
03/15 21:26:56 yS2  mdm_send: 'AT+FDCC=1,5,0,2,0,0,0,0'
03/15 21:26:56 yS2    got:[0a]AT+FDCC=1,5,0,2,0,0,0,0[0d]
03/15 21:26:56 yS2   mdm_command: string 'AT+FDCC=1,5,0,2,0,0,0,0'
03/15 21:26:56 yS2    got:[0d][0a]OK[0d]
03/15 21:26:56 yS2   tss: set speed to 115200 (10002)
03/15 21:26:56 yS2   tio_set_flow_control( HARD )
03/15 21:26:56 yS2  detecting voice modem type
03/15 21:26:56 yS2    vgetty: ATE0
03/15 21:26:56 yS2    serial port: ATE0
03/15 21:26:56 yS2    serial port: OK
03/15 21:26:57 yS2   voice command: 'ATI9' -> ''
03/15 21:26:57 yS2    vgetty: ATI9
03/15 21:26:57 yS2    serial port: OK
03/15 21:26:57 yS2   voice command: 'ATI3' -> ''
03/15 21:26:57 yS2    vgetty: ATI3
03/15 21:26:57 yS2    serial port: DAVICOM DATA/F
03/15 21:27:19 yS2  vgetty: timeout while reading character from voice modem
03/15 21:27:19 yS2  modem detection failed
cat /proc/tty/driver/serial
serinfo:1.0 driver:5.05c revision:2001-07-08
0: uart:16550A port:3F8 irq:4 baud:1200 tx:0 rx:114 RTS|DTR|DSR
1: uart:16550A port:2F8 irq:3 baud:9600 tx:0 rx:0
2: uart:16550A port:200 irq:0 baud:115200 tx:1239 rx:1705 oe:13 CTS|DSR
irq=0 want het is polling, instellen op de irq zelf laat hem gebruik maken van interrupts wat hem langzaam maakt. In minicom krijg ik overigens dezelfde problemen als ik ATI3 in tik.
  • it0
it0
nou blijkt dat als ik de baudrate op 9600 zet alles wel koek en ei is, maar waarom kan ik dit niet doen op een hogere snelheid?
Heb verschillende instellingen met rts/cts xon/xoff geprobeerd maar dat maakte niet uit..
