PHP Versie 5.0.0a3 MySql support
  • 262 views sinds 30-01-2008
  • Appel-Banaan
  • Laatst online: 15:20
Appel-Banaan
Het leven is wat je gebeurt
Hoi allemaal.
Ik heb net mijn server gesloopt door php eraf te halen. Niet zo slim natuurlijk :). Maar nu heb ik PHP Version 5.0.0a3 erop ge knald. Alleen nu staat (wat ook wel klopt) de MySql support niet aan.
Voor phpinfo() http://213.10.80.245.
Het draait allemaal op een FreeBSD machiene. MySqu versie 4.0 ofzo.
Meer weet ik ook niet dat nuttig is om te weten. Vraag het anders maar.
pkg_info:
senna# pkg_info
ORBit2-2.8.2 High-performance CORBA ORB with support for the C language
XFree86-clients-4.3.0_5 XFree86-4 client programs and related files
XFree86-fontEncodings-4.3.0 XFree86-4 font encoding files
XFree86-fontScalable-4.3.0 XFree86-4 scalable fonts
XFree86-libraries-4.3.0_6 XFree86-4 libraries and headers
Xft-2.1.2 A client-sided font API for X applications
apache-2.0.48_1 Version 2 of the extremely popular Apache http server
atk-1.4.1_1 A GNOME accessibility toolkit (ATK)
bison-1.75_1 A parser generator from FSF, (mostly) compatible with Yacc
cclient-2002d,1 Mark Crispin's C-client mail access routines
docbook-sk-4.1.2_1 XML version of the DocBook DTD version controlled for Scrol
docbook-xml-4.2_1 XML version of the DocBook DTD
docbook-xsl-1.62.4 XSL DocBook stylesheets
esound-0.2.32_1 A sound library for enlightenment package
expat-1.95.6_1 XML 1.0 parser written in C
fontconfig-2.2.90_3 An XML-based font configuration API for X Windows
freetype2-2.1.5_1 A free and portable TrueType font rendering engine
gconf2-2.4.0.1 A configuration database system for GNOME
gdm2-2.4.4.5 GNOME 2 version of xdm display manager
gettext-0.12.1 GNU gettext package
glib-2.2.3 Some useful routines of C programming (current stable versi
gmake-3.80_1 GNU version of 'make' utility
gnome-icon-theme-1.0.9 A collection of icons for the GNOME 2 desktop
gnomehier-1.0_10 An utility port, installing hierarchy of common GNOME direc
gnomemimedata-2.4.0 A MIME and Application database for GNOME
gnomevfs2-2.4.1_1 GNOME Virtual File System
gtk-2.2.4_1 Gimp Toolkit for X11 GUI (current stable version)
gtk-engines2-2.2.0 Theme engine for the gtk+-2.0 toolkit
imake-4.3.0_1 Imake and other utilities from XFree86
intltool-0.27.2_1 Xml internationalization support for GNOME, and others
jpeg-6b_1 IJG's jpeg compression utilities
libIDL-0.8.2 A library for creating trees of CORBA Interface Definition
libart_lgpl2-2.3.16 Library for high-performance 2D graphics
libaudiofile-0.2.4 A sound library for SGI audio file
libbonobo-2.4.2 A component and compound document system for GNOME2
libbonoboui-2.4.1 GUI frontend to the libbonobo component of GNOME 2
libglade2-2.0.1_1 GNOME glade library
libgnome-2.4.0_1 Libraries for GNOME, a GNU desktop environment
libgnomecanvas-2.4.0 A graphics library for GNOME
libgnomeui-2.4.0.1_1 Libraries for the GNOME GUI, a GNU desktop environment
libgsf-1.8.2 An extensible i/o abstraction for dealing with structured f
libiconv-1.9.1_3 A character set conversion library
librsvg2-2.4.0_1 Library for parsing and rendering SVG vector-graphic files
libtool-1.3.5_1 Generic shared library support script
libxml2-2.6.2_1 Xml parser library for GNOME
libxslt-1.1.0_1 The XSLT C library for GNOME
linc-1.0.3 A library for writing networked servers & clients
linux_base-7.1_5 The base set of packages needed in Linux mode
m4-1.4_1 GNU m4
mod_php5-5.0.0.a3_2,1 PHP Apache Module
mysql-client-4.0.16 Multithreaded SQL database (client)
mysql-server-4.0.16 Multithreaded SQL database (server)
p5-DBD-mysql-2.9003 MySQL driver for the Perl5 Database Interface (DBI)
p5-DBI-1.38 The perl5 Database Interface. Required for DBD::* modules
p5-XML-Parser-2.34 Perl extension interface to James Clark's XML parser, expat
pango-1.2.5 An open-source framework for the layout and rendering of i1
perl-5.6.1_15 Practical Extraction and Report Language
pkgconfig-0.15.0 A utility used to retrieve information about installed libr
png-1.2.5_2 Library for manipulating PNG images
popt-1.6.4_1 A getopt(3) like library with a number of enhancements, fro
proftpd-1.2.9 Highly configurable ftp daemon
python-2.3.2_3 An interpreted object-oriented programming language
rc_subr-1.16 Common startup and shutdown subroutines used by scripts
scrollkeeper-0.3.12_4,1 An Open Document Cataloging Project
sdocbook-xml-4.1.2.5_1 "Simplified" DocBook XML DTD
startup-notification-0.5_1 Library that supports startup notification spec from freede
tiff-3.6.0 Tools and library routines for working with TIFF images
unzip-5.50_2 List, test and extract compressed files in a ZIP archive
xmlcatmgr-1.1 SGML/XML catalog manager
Als iemand een oplossing voor mij heeft gaarne even doorgeven. Alvast bedankt
Terwijl je andere plannen maakt
  • moto-moi
  • Laatst online: 09-06-2011
moto-moi
Ja, ik haat jou ook :w
'./configure' '--enable-versioning' '--enable-memory-limit' '--with-layout=GNU' '--disable-all'
'--with-regex=php' '--disable-cli' '--enable-bcmath' '--enable-ctype' '--enable-dom'
'--enable-ftp' '--with-gd' '--enable-gd-native-ttf' '--enable-gd-jis-conv'
'--with-freetype-dir=/usr/local' '--with-jpeg-dir=/usr/local' '--with-png-dir=/usr/local'
'--with-xpm-dir=/usr/local' '--with-mime-magic=/usr/share/misc/magic.mime'
'--with-pcre-regex' '--enable-posix' '--enable-session' '--enable-simplexml' '--with-sqlite'
'--enable-tokenizer' '--enable-libxml' '--with-libxml-dir=/usr/local' '--enable-xml'
'--with-zlib-dir=/usr' '--with-apxs2=/usr/local/sbin/apxs' '--prefix=/usr/local'
'i386-portbld-freebsd5.2'
ik mis een '--enable-mysql' o.i.d. daartussen ?
[ Voor 3% gewijzigd door moto-moi op 12-03-2004 16:36 ]
God, root, what is difference? | Talga Vassternich | IBM zuigt
  • Appel-Banaan
Appel-Banaan
moto-moi schreef op 12 maart 2004 @ 16:36:
Klopt. Maar dat wil ik juist hebben. Weet alleen niet hoe
  • Appel-Banaan
Appel-Banaan
Vriend van mij zegt dat ik php5 opnieuw moet instaleren via ports met de optie MySQL enabled aan. Hij zegt dat dat de enige optie is
Klopt dat?
-Sorry ;) -
[ Voor 5% gewijzigd door Appel-Banaan op 12-03-2004 16:54 . Reden: FF excus aan bieden aan mod ]
  • moto-moi
moto-moi
Dat is wel een optie ja.
Verder, we hebben op GoT een edit-knopje -> 'Afbeeldingslocatie: http://gathering.tweakers.net/global/templates/got/images/icons/edit.gif ' ;)
  • igmar
  • Laatst online: 19:53
igmar
ISO20022
moto-moi schreef op 12 maart 2004 @ 16:47:
Verder, we hebben op GoT een edit-knopje -> '[afbeelding] ' ;)
Hou d'r verder rekening mee dat de MySQL client lib niet meer gebundled is vanwege problemen met de nieuwe MySQL licentie. Je moet dus iets gebruiken als --with-mysql=/usr
