[Exchange server 2003] Krijg niet geinstalleerd
  • 47 views sinds 30-01-2008
  • dannyvanderaa
  • Laatst online: 03-03-2023
Ik ben bezig geweest met de exchange server 2003 (enterprise edition)
Zit een mooi stappenplan in, ik probeer netje te volgen, alles gaat goed tot het moment dat ik forestprep wil uitvoeren. Dan krijg ik steeds een error. Zegt ie dat hij een fatale error heeft veroorzaakt en dat je in het eventlog.txt bestand moet kijken:
Onderstaande staat daar in:
[03/12/04,14:56:23] Setup.exe: GetGlobalCustomProperty(B51015E7-26A5-4c8f-B871-26ABA9BEFB65)
[03/12/04,14:56:23] Setup.exe: LoadSetupDatabase()
[03/12/04,14:56:23] Setup.exe: in InternalRegisterSetupService()
[03/12/04,14:56:23] Setup.exe: IsRunningUnattended
[03/12/04,14:56:23] Setup.exe: AddGlobalCustomProperty
[03/12/04,14:56:23] Setup.exe: inside ISetupManager::LoadHelpManager()
[03/12/04,14:56:23] Setup.exe: ISetupManager::LoadCommandLineMgr() completed
[03/12/04,14:56:23] Setup.exe: ISetupManager::LoadSetupLog() completed
[03/12/04,14:56:23] Setup.exe: ISetupManager::RunIntro() starting
[03/12/04,14:56:24] Setup.exe: inside ISetupManager::LoadDependencyMgr()
[03/12/04,14:56:24] Setup.exe: in InternalRegisterSetupService()
[03/12/04,14:56:24] Setup.exe: inside ISetupManager::LoadCDInfoMgr()
[03/12/04,14:56:24] Setup.exe: GetCustomProperties()
[03/12/04,14:56:24] Setup.exe: get_CustomProperties()
[03/12/04,14:56:24] Setup.exe: inside ISetupManager::LoadTemplMgr()
[03/12/04,14:56:25] Setup.exe: inside ISetupManager::LoadDiskInfoMgr()
[03/12/04,14:56:25] Setup.exe: in InternalRegisterSetupService()
[03/12/04,14:56:25] Setup.exe: inside ISetupManager::LoadUIManager()
[03/12/04,14:56:25] Setup.exe: in RegisterSetupService()
[03/12/04,14:56:25] Setup.exe: GetGlobalCustomProperty({0DC70217-9545-11D2-ACD4-00C04F8EEBA1})
[03/12/04,14:56:25] Setup.exe: IsRunningUnattended
[03/12/04,14:56:25] Setup.exe: GetGlobalCustomProperty({AA62DF98-3F2C-11D3-887B-00C04F8ECDD6})
[03/12/04,14:56:25] Setup.exe: inside ISetupManager::LoadAccountManager()
[03/12/04,14:56:25] Setup.exe: inside ISetupManager::LoadValidationManager()
[03/12/04,14:56:26] Setup.exe: in InternalRegisterSetupService()
[03/12/04,14:56:26] Setup.exe: inside ISetupManager::LoadDependencyManagerUI()
[03/12/04,14:56:26] Setup.exe: inside ISetupManager::LoadServerGroupManager()
[03/12/04,14:56:26] Setup.exe: inside ISetupManager::LoadChangeFolder()
[03/12/04,14:56:28] setup.exe: ***ERRORLOG EVENT*** : Run() : RunLoadSetup(), an exception has occured.
[03/12/04,14:56:28] Setup.exe: IsRunningUnattended
Maar vervolgens kom ik er niet uit.
Iemand een idee voor mij?
  • Yoeri
Yoeri
O+ Joyce O+
(overleden)
zegt je gewone event viewer iets nuttigs ivm de uitzondering?
Kijkje in de redactiekeuken van Tweakers.net
22 dec: Onze reputatie hooghouden
20 dec: Acht fouten
is je domain en DNS server al correct geconfigureerd?
  • dannyvanderaa
Daar wordt toch nog niet naar gekeken op het moment, dat de installatiecomponenten geladen worden??
  • Dennis
  • Laatst online: 13:25
Tot het moment dat je forestprep wilt uitvoeren?
Daarvoor zit vrijwel niks volgens mij, dus, behalve dan van die stappen die niet persé noodzakelijk zijn.
DNS zal er inderdaad weinig mee te maken hebben, dat klopt. Maar op welk operating system draai je en heb je die versie vers geïnstalleerd of er al wat rotzooi mee gemaakt?
  • dannyvanderaa
Op win 2003 server enterprise edition.
Alleen dns en dhcp geinstalleerd
Plus wat accounts gemaakt, niet echt liggen rotzooien,
Deze server is:
Domain controller
Print server
File server
en moet dus ook mail server worden
  • dannyvanderaa
Net aan mijn leraar gevraagd,
denkt dat er een fout zit in het programma, moet dus even een andere versie proberen.
/slotje :P
  • leon1e
  • Laatst online: 11:09
Wat een geweldige kick na 2 maanden. :(
