Outlook XP - Script Error printen van HTML mail
  • The.Terminator
  • Laatst online: 23:12
The.Terminator
Un boer met bier
Als ik HTML mail (dat ik ontvangen heb) wil printen dan krijg ik de volgende error
message.
Afbeeldingslocatie: http://www.rip-productions.ws/speedtest/errormessage.jpg
Win2000 SP4
Internet Explorer 5.5 SP2
Onderstaande stappen uitgevoerd.
- Internet Explorer opnieuw geinstalleerd
- Script Engine opnieuw geinstalleerd
- Outlook XP (Office XP) opnieuw geinstalleerd
Er is op google genoeg info te vinden over dit probleem, al1 geen oplossing ! :|
  • Fire69
  • Laatst online: 20:06
Quote uit onze Knowledge Database:
Internet Explorer Script Error when printing a HTML mail
Oplossing:
Error message generated when printing a HTML mail in Outlook 2000:
"Internet Explorer Script Error:
An error has occurred in the script on this page Line: 1189 Char: 1
Error: Unspecified error. Code: 0
URL: res://C:\Winnt\System32\shdoclc.dll /preview.dlg
Do you want to continue running scripts on this page? Yes No."
The solution for this particular case was to restore the default settings in Internet Explorer 5.5 SP-2. Start IE and select the menu Tools, Internet Options, tab Advanced, button "Restore Defaults".
There was no information about this specific error message in the Knowledge base of Microsoft. There were similar cases but with different solutions.
of
Can't print mail in Outlook - Script Error: An error has occurred in the script on this page.
Oplossing:
You should register some DLL files again.
How can you do that ?
1. Click on START - RUN
2. Type : regsvr32 C:\WinNT\System32\MLANG.DLL and click on "OK"
A window will appear confirming that this DLL is registered.
Execute step 1 and 2 anew, but now for the following DLL:
(Replace the blue text by the following)
RegSvr32.exe C:\WinNT\System32\MLANG.DLL
RegSvr32.exe C:\WinNT\System32\RPCRT4.DLL
RegSvr32.exe C:\WinNT\System32\OLE32.DLL
RegSvr32.exe C:\WinNT\System32\OLEAUT32.DLL
RegSvr32.exe C:\WinNT\System32\OLEPRO.DLL
[ Voor 33% gewijzigd door Fire69 op 11-03-2004 12:01 ]
