Probleem met cd schrijver in laptop
  • Memphisto
  • Laatst online: 22:40
Ik draai hier op men laptop, debian unstable, met de 2.6.3 kernel.
Ik probeer cd's te schrijven en rw's te blanken via de "atapi" manier en dus niet via scsi emulatie. Scsci-emulatie staat ook uit in de kernelconfig.
Ik probeer te blanken met het volgende commando:
cdrecord -v dev=/dev/hdc blank=all (waarbij hdc uiteraard de goede drive is)
met als output:
Cdrecord-Clone 2.01a26 (i686-pc-linux-gnu) Copyright (C) 1995-2004 Jörg Schillin
g
NOTE: this version of cdrecord is an inofficial (modified) release of cdrecord
and thus may have bugs that are not present in the original version.
Please send bug reports and support requests to <cdrtools@packages.debian.
org>.
The original author should not be bothered with problems of this version.
TOC Type: 1 = CD-ROM
Using libscg version 'schily-0.8'.
atapi: 1
Device type : Removable CD-ROM
Version : 0
Response Format: 2
Capabilities :
Vendor_info : 'QSI '
Identifikation : 'CDRW/DVD SBW-241'
Revision : 'VU02'
Device seems to be: Generic mmc2 DVD-ROM.
Current: 0x000A
Profile: 0x0010
Profile: 0x0008
Profile: 0x0009
Profile: 0x000A (current)
Using generic SCSI-3/mmc CD-R/CD-RW driver (mmc_cdr).
Driver flags : MMC-2 SWABAUDIO BURNFREE
Supported modes: TAO PACKET SAO SAO/R96P SAO/R96R RAW/R16 RAW/R96P RAW/R96R
Drive buf size : 1605632 = 1568 KB
Current Secsize: 2048
ATIP info from disk:
Indicated writing power: 5
Reference speed: 2
Is not unrestricted
Is erasable
ATIP start of lead in: -11635 (97:26/65)
ATIP start of lead out: 359849 (79:59/74)
1T speed low: 0 (reserved val 0) 1T speed high: 4
2T speed low: 8 2T speed high: 0 (reserved val 10)
power mult factor: 4 6
recommended erase/write power: 3
A1 values: 02 4C B0
A2 values: 4A C8 36
Disk type: Phase change
Manuf. index: 3
Manufacturer: CMC Magnetics Corporation
Starting to write CD/DVD at speed 4 in real BLANK mode for single session.
Last chance to quit, starting real write in 9 seconds.^H^H^H^H^H^H^H^H^H^H^H^H^H
8 seconds.^H^H^H^H^H^H^H^H^H^H^H^H^H 7 seconds.^H^H^H^H^H^H^H^H^H^H^H^H^H
6 seconds.^H^H^H^H^H^H^H^H^H^H^H^H^H 5 seconds.^H^H^H^H^H^H^H^H^H^H^H^H^H 4
seconds.^H^H^H^H^H^H^H^H^H^H^H^H^H 3 seconds.^H^H^H^H^H^H^H^H^H^H^H^H^H 2 s
econds.^H^H^H^H^H^H^H^H^H^H^H^H^H 1 seconds.^H^H^H^H^H^H^H^H^H^H^H^H^H 0 sec
onds. Operation starts.
Performing OPC...
Blanking entire disk
scsidev: '/dev/hdc'
devname: '/dev/hdc'
scsibus: -2 target: -2 lun: -2
Warning: Open by 'devname' is unintentional and not supported.
Linux sg driver version: 3.5.27
SCSI buffer size: 64512
cdrecord: Success. blank unit: scsi sendcmd: no error
CDB: A1 00 00 00 00 00 00 00 00 00 00 00
status: 0x2 (CHECK CONDITION)
Sense Bytes: 70 00 05 00 00 00 00 0A 00 00 00 00 24 00 00 00
Sense Key: 0x5 Illegal Request, Segment 0
Sense Code: 0x24 Qual 0x00 (invalid field in cdb) Fru 0x0
Sense flags: Blk 0 (not valid)
cmd finished after 0.000s timeout 9600s
cdrecord: Cannot blank disk, aborting.
Ik heb de atapi setup voor 2.6 kernels gebruikt: (/usr/share/doc/cdrecord/README.ATAPI.setup)
cdrecord -prcap zegt dit:
g
org>.
Version : 0
Response Format: 2
Capabilities :
Revision : 'VU02'
Drive capabilities, per MMC-2 page 2A:
Does read CD-R media
Does write CD-R media
Does read CD-RW media
Does write CD-RW media
Does read DVD-ROM media
Does read DVD-R media
Does not write DVD-R media
Does not read DVD-RAM media
Does not write DVD-RAM media
Does support test writing
Does read Mode 2 Form 1 blocks
Does read Mode 2 Form 2 blocks
Does read digital audio blocks
Does restart non-streamed digital audio reads accurately
Does support Buffer-Underrun-Free recording
Does read multi-session CDs
Does read fixed-packet CD media using Method 2
Does not read CD bar code
Does read R-W subcode information
Does not return R-W subcode de-interleaved and error-corrected
Does read raw P-W subcode data from lead in
Does return CD media catalog number
Does return CD ISRC information
Does support C2 error pointers
Does not deliver composite A/V data
Does play audio CDs
Number of volume control levels: 256
Does support individual volume control setting for each channel
Does support independent mute setting for each channel
Does not support digital output on port 1
Does not support digital output on port 2
Loading mechanism type: tray
Does support ejection of CD via START/STOP command
Does not lock media on power up via prevent jumper
Does allow media to be locked in the drive via PREVENT/ALLOW command
Is not currently in a media-locked state
Does not support changing side of disk
Does not have load-empty-slot-in-changer feature
Does not support Individual Disk Present feature
Maximum read speed: 4224 kB/s (CD 24x, DVD 3x)
Current read speed: 3124 kB/s (CD 17x, DVD 2x)
Maximum write speed: 4236 kB/s (CD 24x, DVD 3x)
Current write speed: 706 kB/s (CD 4x, DVD 0x)
Buffer size in KB: 2048
Copy management revision supported: 1
Ik heb al een tijdje gegoogle'd maar kom niet tot een oplossing.... :(
Iemand hier een oplossing ??
Deep into that darkness peering, long I stood there, wondering, fearing, doubting, dreaming dreams no mortal ever dreamed before.
  • ajvdvegt
  • Laatst online: 28-09 20:25
Als ik cdrecord -prcap doe krijg ik bijna dezelfde output. Ik krijg helemaal boven aan chter eerst dit:
scsidev: '/dev/hdc'
devname: '/dev/hdc'
Ik krijg dus expliciet een melding dat ik hdc gebruik. Ik heb versie 2.0+a26pre27-1 9 (verder ook Debian unstable en 2.6.3)
I don't kill flies, but I like to mess with their minds. I hold them above globes. They freak out and yell "Whooa, I'm *way* too high." -- Bruce Baum
  • Memphisto
Ik heb net /etc/default/cdrecord aangepast zodat "cdrecord -prcap" dezelfde output geeft als bij ajvdvegt (uiteraard zijn dit wel de goede in stellingen ook bij mij :P )
Maar het probleem blijft...
  • ajvdvegt
Misschien wel zo handig om te vermelden dat mijn brander wel prima werkt met deze config... sorry dat dat niet in mijn eerste post stond :)
  • Memphisto
Ook cdrecord -checkdrive ziet dat ding gelijk goed:
scsidev: '/dev/hdc'
devname: '/dev/hdc'
Version : 0
Response Format: 2
Capabilities :
Revision : 'VU02'
zal het nog even gaan proberen met een 2.4.25 kernel. ;)
  • Memphisto
In de manpage van cdrecord staat mijn probleem ook. Hierin staat alleen uit gelegd wat de verschillende regels van de error betekenen... maar verder geen oplossing...
Uit de manpage:
A typical error message for a SCSI command looks like:
cdrecord: I/O error. test unit ready: scsi sendcmd: no error
CDB: 00 20 00 00 00 00
Sense Bytes: 70 00 05 00 00 00 00 0A 00 00 00 00 25 00 00 00 00 00
Sense Code: 0x25 Qual 0x00 (logical unit not supported) Fru 0x0
cmd finished after 0.002s timeout 40s
The first line gives information about the transport of
the command. The text after the first colon gives the
error text for the system call from the view of the ker-
nel. It usually is: I/O error unless other problems hap-
pen. The next words contain a short description for the
SCSI command that fails. The rest of the line tells you if
there were any problems for the transport of the command
over the SCSI bus. fatal error means that it was not pos-
available, followed by the segment number that is only
valid if the command was a copy command. If the error mes-
sage is not directly related to the current command, the
text deferred error is appended.
The sixth line is the error text for the sense code and
the sense qualifier if available. If the type of the
device is known, the sense data is decoded from tables in
scsierrs.c . The text is followed by the error value for
a field replaceable unit.
The seventh line prints the block number that is related
to the failed command and text for several error flags.
The block number may not be valid.
The eight line reports the timeout set up for this command
and the time that the command really needed to complete.
kan hier iemand misschien iets mee want ik wordt er niet veel wijzer van :(
  • deepbass909
deepbass909
Even een oude }:O uit de de drek trekken.
Ik zit tegen precies hetzelfde probleem aan te hikken.
Ik heb van de week een CDRW gebrand in m'n laptop, en die is 100% goed gelukt. Dus de brander werkt. Nu wil ik hem wissen met cdrecord, en krijg ik dezelfde fout:
29
30
nomad linux # cdrecord blank=all dev=/dev/hdc
Cdrecord-Clone 2.01.01a06 (i686-pc-linux-gnu) Copyright (C) 1995-2006 Jörg Schilling
scsidev: '/dev/hdc'
devname: '/dev/hdc'
Version        : 0
Response Format: 2
Capabilities   :
Revision       : 'VU02'
Starting to write CD/DVD at speed 10 in real BLANK mode for single session.
Last chance to quit, starting real write    0 seconds. Operation starts.
Het opvallende is dat m'n cd brander helemaal niet lijkt te reageren (led gaat niet branden, spint niet op). Het lijkt dus een aansturings probleem te zijn.
Ik heb nu native IDE support voor de cdbrander in gebruik en wil nog even SCSI emulatie proberen, maar anders weet ik het eigenlijk niet... En om nou speciaal windows te moeten starten om alleen een cdrw te wissen is ook wat overbodig...
  • igmar
  • Laatst online: 26-09 18:37
igmar
ISO20022
Memphisto schreef op woensdag 10 maart 2004 @ 08:34:
Ik moet hier aansturen met dev=ATAPI:0,0,0, waarbij ik 0,0,0 uit
cdrecord dev=ATAPI -scanbus
heb.
  • deepbass909
deepbass909
Dat werkt bij mij al helemaal niet
Cdrecord-Clone 2.01.01a06 (i686-pc-linux-gnu) Copyright (C) 1995-2006 J&#65533;g Schilling
scsidev: 'ATAPI'
devname: 'ATAPI'
Warning: Using ATA Packet interface.
Warning: The related Linux kernel interface code seems to be unmaintained.
Warning: There is absolutely NO DMA, operations thus are slow.
cdrecord: No such file or directory. Cannot open SCSI driver.
cdrecord: For possible targets try 'cdrecord -scanbus'.
cdrecord: For possible transport specifiers try 'cdrecord dev=help'.
