[Ervaringen] Elitegroup DeskNote A535 1GHz
  • 55 views sinds 30-01-2008
Afbeeldingslocatie: http://www.promarkt.de/online/catalog/pics/7011950002_org.jpg
Afbeeldingslocatie: http://www.kcn-computer.de/shopping/catalog/images/a535_animation.gif
Processor
- On board 462pin CPGA mobile AMD® processor with PowerNow! TM technology
- Dual-ported 128-Kbyte split L1 cache, 64kbyte L2 cache on die, FSB 200MHz
Core Logic
- SiS 740+ SiS 962L
Memory
- On board 128MB DDR RAM
- Expansion 1 slot of 200pin DDR SO-DIMM, up to 640MB system memory
- Supports 2.5V / 1.25V 200pin DDR200 / DDR266 SO-DIMM module
LCD Display & Graphic
- 15.0"/14.1" XGA TFT LCD with 1024 x 768 resolution, 16.7M colors
- High performance 256bit 3D graphic engine, up to 143MHz 3D engine clock
- Shared memory 16/32/64MB DDR (user adjustable in BIOS, 16MB as default)
Audio
- AC’97 2.2 supports 5.1 channel decoder through SPDIF cable
- Built-in two stereo speakers with chamber
Communication
- Internal LAN, modem(option) and Wireless LAN(option)
- Integrated WiFi™ -compliant wireless LAN available as configurable option, 802.11b:11Mbps or 802.11g:54Mbps
- On-board 1Gb/100M/10M Base-T LAN Ethernet, up to 1 Gbps
- 56K V.90 modem supported by miniPCI modem card as option
Hard Disk Drive
- Easily upgradeable, 2.5” 9.5mm height, ATA 100/66/33 supported
Optical Device Drive
- Factory Option : Slim CD-ROM,DVD-ROM,
Combo Drive (DVD-ROM+CD-RW), DVD+RW
Pointing Device & Keyboard
- Synaptics touchpad w/ 4-way scrolling button
- 3.0mm key travel, 19mm key pitch, inverted-T
- Two Quick Launch Keys : WWW & E-mail
I/O Interface
- 4 X USB 2.0, 1 X RJ-11 (Modem), 1 X RJ-45 jack for Ethernet
- 1 X Headphone jack with SPDIF output for 5.1 channel decoder, 1 X MIC-in
- 1 X external VGA port, 1 X parallel port, 1 X S-Video TV-Out connector
- 1 X DC- in jack for AC adaptor
AC Adapter
- Auto-sensing dual voltage support, AC100-240V
- 60W,3pin, DC 19V,3.16A
Battery Capacity
- 4-cell Li-Ion battery pack : 32.56Whr/1800mAhr
- 8-cell Li-Ion battery pack : 53.28Whr/1800mAhr (Optional)
Battery Charge
- Approximately 2 hours charging time to 100% capacity
by 4-cell battery pack (system off)
- Approximately 3.5 hours charging time to 100% capacity
by 8-cell battery pack (system off)
Battery Life
- Provide approximately 40min of battery life by 4-cell battery pack
- Provide approximately 80min of battery life by 8-cell battery pack
Dimensions & Weight
- 334x274x34 mm , 13.14"x10.78"x1.33"
- 2.7kg, 6.0 lbs (With 14.1" panel, 8-cell battery pack and CD-ROM drive installed)
BIOS
- Plug & Play, ACPI and DMI supported
- Bootable from USB FDD and CD-ROM
Security
- Kensington Lock and BIOS password protection
System Compliance
- Windows XP/ Windows 2000 / Windows ME/ Windows 98SE
Windows Logo
- WLP 2.1a
Optional Accessory
- 802.11b or 802.11g Wireless LAN module
- Battery Pack : 8-cell battery pack and Dummy battery
Factory option
- ODD: CD-ROM, DVD-ROM, Combo Drive, DVD+RW and Dummy ODD
Wat vinden we van deze laptop voor een prijs van net 700 euro inclusief????
De accu pack van 8 cellen is wel nodig.. dan heb je 80 min (das wel net even minder maarja 1,5 uur op niet batterij is opzich ook lang zat eigelijk je kan um bijna overal wel ff laden)
Ik wil een laptop als dit, niet te zwaar, niet te nieuwe config, wlan kaartje erin en redelijke garantie..
Is dit een bekend merk? wie weet waar te koop in nederland?
[bron info: http://www.promarkt.de/on...rtner_sub=&partner_image= ]
[ Voor 71% gewijzigd door Verwijderd op 09-03-2004 01:03 ]
NIemand met ervaringen met het merk dan wellicht??
Ik zou graag horen dat het een beetje een goed merk is. als instap model gewoon voor school en voor me webdesign on the road.
Als ik jou was had ik nog ff door gespaard en dan voor een Acer Travelmate TM 243LCe gaan.
Je hebt dan meer :
Accu tijd (2.5 uur)
cpu performance (2500 mhz)
kwaliteit (acer.. tja goed genoeg)
En dat voor een kleine 200 euro meer, lijkt mij het zeker wel waard.
[url] pricewatch: Acer TravelMate 243LCe (Cel 2.5GHz; 256MB; 30GB; combo; 15" TFT; WXP Home) [/url]
[url] [rml][ Laptop]HP NX9005 vs TravelMate 244LCe[/rml] [/url]
[ Voor 23% gewijzigd door Verwijderd op 09-03-2004 14:31 ]
  • netblade
  • Laatst online: 17-10 20:47
netblade
Sunrise
Verwijderd schreef op 09 maart 2004 @ 14:27:
Je hebt dan meer :
Accu tijd (2.5 uur)
150 ;) beatit heeft hem voor 850
There's no limit to the human brain, the only barrier is the way we think
netblade schreef op 09 maart 2004 @ 15:25:
kan je nagaan :)
Bedankt jonges.. ik had al gezien dat de accu heeel erg korte tijd had dus dit is zowiezo geen echte goeie optie. Topic mag wel dicht, denk ook niet dat er verder veel interesse is voor deze laptop.
  • Laurent
Aangezien dit topic ook een vrij magere topicstart heeft, al helemaal voor een ervaringen-topic, zou deze al sowieso dicht gaan. ;) Maar goed, bij deze.
