Creative Sound Blaster Live 5.1 Digital
  • 550 views sinds 30-01-2008
ik heb een vaag probleem met mijn geluidskaart, mn pc was gecrasht dus alles vrolijk opnieuw geinstalleerd, alles werkt behalve mn geluidskaart. voor meer info doe ik hieronder ff DxDiag file dr bij plakken, oh ja, voor de slimmeriken onder ons, ja ik heb al gekeken of mn boxen aanstonden, volume op pc zelf open stond, en in de kast zelf gecontroleerd voor alle draden enzo
System Information
Time of this report: 3/8/2004, 21:00:20
Machine name: 5U8-Z3R0
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 1 (2600.xpsp2.030422-1633)
Language: English (Regional Setting: English)
System Manufacturer: VIA Technologies, Inc.
System Model: VT82C694X
BIOS: Award Modular BIOS v6.00PG
Processor: Intel Pentium III, ~660MHz
Memory: 256MB RAM
Page File: 134MB used, 483MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0b (4.09.0000.0902)
DX Setup Parameters: Not found
DxDiag Version: 5.03.0001.0902 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found. DirectDraw test results: All tests were successful. Direct3D 7 test results: All tests were successful. Direct3D 8 test results: All tests were successful. Direct3D 9 test results: All tests were successful.
Sound Tab 1: DirectSound test results: Failure at step 19 (User verification of software): HRESULT = 0x00000000 (error code)
Music Tab: DirectMusic test results: All tests were successful.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce2 MX/MX 400
Manufacturer: NVIDIA
Chip type: GeForce2 MX/MX 400
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0110&SUBSYS_00000000&REV_B2
Display Memory: 64.0 MB
Current Mode: 1280 x 960 (16 bit) (60Hz)
Monitor: Philips 105S (105S2)
Monitor Max Res: 1280,960
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.5303 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 11/17/2003 10:33:00, 4323968 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 11/17/2003 10:33:00, 1618939 bytes
Device Identifier: {D7B71E3E-4250-11CF-0777-0A2013C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0110
SubSys ID: 0x00000000
Revision ID: 0x00B2
Revision ID: 0x00B2
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: All tests were successful.
D3D7 Test Result: All tests were successful.
D3D8 Test Result: All tests were successful.
D3D9 Test Result: All tests were successful.
Sound Devices
Description: SB Live! Audio [DC00]
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_1102&DEV_0002&SUBSYS_80651102&REV_0A
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ctaud2k.sys
Driver Version: 5.12.0001.0252 (English)
WHQL Logo'd: Yes
Date and Size: 7/19/2002 03:47:52, 837548 bytes
Other Files:
Driver Provider: Creative
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 4000, 191999
Static/Strm HW Mix Bufs: 32, 30
Static/Strm HW 3D Bufs: 32, 30
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Failure at step 19 (User verification of software): HRESULT = 0x00000000 (error code)
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: Enabled
Ports: SB Live! DirectMusic Synthesizer [DC00], Hardware (Kernel Mode), Output, DLS, Internal, Default Port
SB Live! Audio [DC00], Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Live! Synth A [DC00] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Live! Sw Synth [DC00] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Live! Synth B [DC00] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Live! MIDI Port [DC00] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Live! MIDI Port [DC00] [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1106, 0x3038
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 7/3/2003 17:52:58, 53120 bytes
| Driver: usbd.sys, 8/23/2001 13:00:00, 4736 bytes
Gameport Devices
+ PCI bus
| Matching Device ID: *pnp0a03
| Service: pci
| Driver: pci.sys, 8/29/2002 02:09:12, 62976 bytes
+-+ Creative Game Port
| | Matching Device ID: pci\ven_1102&dev_7002&subsys_00201102
| | Service: gameenum
| | Driver: gameenum.sys, 8/29/2002 01:32:44, 9856 bytes
PS/2 Devices
+ Easy Internet Keyboard
| Matching Device ID: *pnp0303
| Upper Filters: itchfltr
| Service: i8042prt
| Driver: i8042prt.sys, 8/29/2002 02:06:38, 51072 bytes
| Driver: kbdclass.sys, 8/29/2002 01:27:02, 23424 bytes
| Driver: itchfltr.sys, 11/8/2003 22:24:18, 12953 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/29/2002 03:46:42, 38024 bytes
+ Logitech-compatible Mouse PS/2
| Matching Device ID: *pnp0f13
| Upper Filters: L8042pr2, LMouFlt2
| Service: i8042prt
| Driver: mouclass.sys, 8/29/2002 01:27:02, 22016 bytes
| Driver: L8042pr2.Sys, 12/17/2003 09:50:00, 51729 bytes
| Driver: LMouFlt2.Sys, 12/17/2003 09:50:00, 70801 bytes
| Driver: Logi_MwX.Exe, 12/17/2003 09:50:00, 19968 bytes
| Driver: LCoInst.Dll, 12/17/2003 09:50:00, 23375 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0000.0900)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0000.0900)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 Serial Service Provider: COM2
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay8 TCP/IP Service Provider: Alcatel Speedtouch Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 113.3 GB
Total Space: 117.2 GB
File System: NTFS
Model: Maxtor 6Y120P0
Drive: D:
Free Space: 9.4 GB
Total Space: 9.5 GB
File System: FAT32
Model: ST310211A
Drive: E:
Model: LG DVD-ROM DRD8160B
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.1106 (English), 8/29/2002 02:27:56, 47488 bytes
Drive: F:
Model: AOPEN CD-RW CRW3248
System Devices
Name: VIA Tech CPU to AGP Controller
Device ID: PCI\VEN_1106&DEV_8598&SUBSYS_00000000&REV_00\3&61AAA01&0&08
Driver: C:\WINDOWS\System32\DRIVERS\VIAAGP.SYS, 5.01.2600.0000 (English), 8/17/2001 14:58:02, 27392 bytes
Name: VIA Tech Power Management controller
Device ID: PCI\VEN_1106&DEV_3057&SUBSYS_30571106&REV_40\3&61AAA01&0&3C
Driver: n/a
Name: VIA Rev 5 or later USB Universal Host Controller
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_12340925&REV_16\3&61AAA01&0&3B
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.1243 (English), 7/3/2003 17:51:46, 19328 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.1243 (English), 7/3/2003 17:49:30, 138752 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.1243 (English), 7/3/2003 17:52:58, 53120 bytes
Driver: C:\WINDOWS\System32\usbui.dll, 5.01.2600.0000 (English), 8/17/2001 23:36:34, 67072 bytes
Device ID: PCI\VEN_1106&DEV_3038&SUBSYS_12340925&REV_16\3&61AAA01&0&3A
Name: VIA Tech CPU to PCI bridge
Device ID: PCI\VEN_1106&DEV_0691&SUBSYS_00000000&REV_C4\3&61AAA01&0&00
Driver: n/a
Name: VIA Tech PCI to ISA bridge
Device ID: PCI\VEN_1106&DEV_0686&SUBSYS_00000000&REV_40\3&61AAA01&0&38
Driver: C:\WINDOWS\System32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/23/2001 13:00:00, 35840 bytes
Name: VIA Bus Master IDE Controller
Device ID: PCI\VEN_1106&DEV_0571&SUBSYS_05711106&REV_06\3&61AAA01&0&39
Driver: C:\WINDOWS\System32\DRIVERS\viaide.sys, 1.00.0001.0000 (English), 8/29/2002 02:27:50, 4864 bytes
Driver: C:\WINDOWS\System32\DRIVERS\pciidex.sys, 5.01.2600.1106 (English), 8/29/2002 02:27:48, 23680 bytes
Driver: C:\WINDOWS\System32\DRIVERS\atapi.sys, 5.01.2600.1106 (English), 8/29/2002 02:27:50, 86912 bytes
Name: Creative Game Port
Device ID: PCI\VEN_1102&DEV_7002&SUBSYS_00201102&REV_0A\3&61AAA01&0&51
Driver: C:\WINDOWS\system32\drivers\gameenum.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:44, 9856 bytes
Name: Creative SB Live! series
Device ID: PCI\VEN_1102&DEV_0002&SUBSYS_80651102&REV_0A\3&61AAA01&0&50
Driver: C:\WINDOWS\system32\drivers\drmk.sys, 5.01.2600.1106 (English), 8/29/2002 01:32:34, 57856 bytes
Driver: C:\WINDOWS\system32\drivers\portcls.sys, 5.01.2600.1106 (English), 8/29/2002 02:01:00, 134272 bytes
Driver: C:\WINDOWS\system32\drivers\stream.sys, 5.03.0000.0900 (English), 12/12/2002 00:14:32, 45696 bytes
Driver: C:\WINDOWS\System32\wdmaud.drv, 5.01.2600.0000 (English), 8/17/2001 22:37:04, 22016 bytes
Driver: C:\WINDOWS\System32\ksuser.dll, 5.03.0000.0900 (English), 12/12/2002 00:14:32, 4096 bytes
Driver: C:\WINDOWS\system32\drivers\ctac32k.sys, 5.12.0001.0245 (English), 7/19/2002 03:46:28, 127948 bytes
Driver: C:\WINDOWS\system32\drivers\ctaud2k.sys, 5.12.0001.0252 (English), 7/19/2002 03:47:52, 837548 bytes
Driver: C:\WINDOWS\system32\drivers\ctoss2k.sys, 5.12.0001.0245 (English), 7/19/2002 03:48:04, 195432 bytes
Driver: C:\WINDOWS\system32\drivers\ctprxy2k.sys, 5.12.0001.0244 (English), 7/19/2002 03:48:08, 11068 bytes
Driver: C:\WINDOWS\system32\drivers\ctsfm2k.sys, 5.12.0001.0140 (English), 7/19/2002 03:48:22, 213860 bytes
Driver: C:\WINDOWS\system32\drivers\emupia2k.sys, 5.12.0001.0244 (English), 7/19/2002 03:48:32, 156604 bytes
Driver: C:\WINDOWS\system32\drivers\ha10kx2k.sys, 5.12.0001.0250 (English), 7/24/2002 06:52:26, 998004 bytes
Driver: C:\WINDOWS\System32\ctdlang.dat, 7/19/2002 04:07:30, 164044 bytes
Driver: C:\WINDOWS\System32\ctstatic.dat, 7/19/2002 03:59:32, 179669 bytes
Driver: C:\WINDOWS\System32\ctdaught.dat, 7/19/2002 03:56:50, 44055 bytes
Driver: C:\WINDOWS\System32\default.ecw, 9/22/1999 16:18:50, 2259067 bytes
Driver: C:\WINDOWS\System32\sfman32.dll, 5.12.0001.0130 (English), 8/17/2001 07:35:46, 36864 bytes
Driver: C:\WINDOWS\System32\a3d.dll, 80.00.0000.0003 (English), 7/19/2002 03:43:06, 65536 bytes
Driver: C:\WINDOWS\System32\ctbasicw.dat, 7/19/2002 04:02:24, 113373 bytes
Driver: C:\WINDOWS\System32\SBLive.ico, 10/22/2001 02:10:28, 4398 bytes
Driver: C:\WINDOWS\System32\Live.bmp, 10/22/2001 02:10:28, 3126 bytes
Name: NVIDIA GeForce2 MX/MX 400
Device ID: PCI\VEN_10DE&DEV_0110&SUBSYS_00000000&REV_B2\4&9FD38EF&0&0008
Driver: C:\WINDOWS\System32\DRIVERS\nv4_mini.sys, 6.14.0010.5303 (English), 11/17/2003 10:33:00, 1618939 bytes
Driver: C:\WINDOWS\System32\nvinstnt.dll, 6.14.0010.5303 (English), 11/17/2003 10:33:00, 131072 bytes
Driver: C:\WINDOWS\System32\nvsvc32.exe, 6.14.0010.5303 (English), 11/17/2003 10:33:00, 77824 bytes
Driver: C:\WINDOWS\System32\nvcod.dll, 1.00.0000.0009 (English), 11/17/2003 10:33:00, 30720 bytes
Driver: C:\WINDOWS\System32\nvcodins.dll, 1.00.0000.0009 (English), 11/17/2003 10:33:00, 30720 bytes
Driver: C:\WINDOWS\System32\nv4_disp.dll, 6.14.0010.5303 (English), 11/17/2003 10:33:00, 4323968 bytes
Driver: C:\WINDOWS\System32\nvoglnt.dll, 6.14.0010.5303 (English), 11/17/2003 10:33:00, 3551232 bytes
Driver: C:\WINDOWS\System32\nvcpl.dll, 6.14.0010.5303 (English), 11/17/2003 10:33:00, 3022848 bytes
Driver: C:\WINDOWS\System32\nvmctray.dll, 6.14.0010.5303 (English), 11/17/2003 10:33:00, 49152 bytes
Driver: C:\WINDOWS\System32\nvwddi.dll, 6.14.0010.5303 (English), 11/17/2003 10:33:00, 35840 bytes
Driver: C:\WINDOWS\System32\nvwdmcpl.dll, 6.14.0010.5303 (English), 11/17/2003 10:33:00, 1474633 bytes
Driver: C:\WINDOWS\System32\nvnt4cpl.dll, 6.14.0010.5303 (English), 11/17/2003 10:33:00, 233472 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 11/17/2003 10:33:00, 83101 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 11/17/2003 10:33:00, 35981 bytes
Name: 3Com EtherLink XL 10/100 PCI TX NIC (3C905B-TX)
Device ID: PCI\VEN_10B7&DEV_9055&SUBSYS_905510B7&REV_64\3&61AAA01&0&60
Driver: C:\WINDOWS\System32\DRIVERS\el90xbc5.sys, 4.05.0000.0000 (English), 8/17/2001 13:11:06, 66591 bytes
DirectX Components
ddraw.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 257536 bytes
ddrawex.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 24064 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 10496 bytes
d3d8.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 1156608 bytes
d3d8thk.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 8192 bytes
d3d9.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 1613312 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 436224 bytes
d3dim700.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 797184 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 13:00:00 33040 bytes
dplayx.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 217600 bytes
dpmodemx.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 22016 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 13:00:00 42768 bytes
dpwsockx.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 54272 bytes
dplaysvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 28160 bytes
dpnsvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 16896 bytes
dpnet.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 377856 bytes
dpnlobby.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes
dpnaddr.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes
dpvoice.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 203264 bytes
dpvsetup.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 80896 bytes
dpvvox.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 112128 bytes
dpvacm.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 19968 bytes
dpnhpast.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02 32768 bytes
dpnhupnp.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02 68096 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 13:00:00 53520 bytes
dinput.dll: 5.01.2600.1106 English Final Retail 8/29/2002 04:40:50 151552 bytes
dinput8.dll: 5.01.2600.1106 English Final Retail 8/29/2002 04:40:50 168960 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 394240 bytes
joy.cpl: 5.01.2600.1106 English Final Retail 8/29/2002 04:41:28 65536 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 76800 bytes
pid.dll: 5.01.2600.1106 English Final Retail 8/29/2002 04:50:10 31744 bytes
gameenum.sys: 5.01.2600.1106 English Final Retail 8/29/2002 01:32:44 9856 bytes
dsound.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 336384 bytes
dsound3d.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 1294336 bytes
dswave.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18432 bytes
dsdmo.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 186880 bytes
dsdmoprp.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 68096 bytes
dmusic.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 97280 bytes
dmband.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 27136 bytes
dmcompos.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 58368 bytes
dmime.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 171520 bytes
dmloader.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 33280 bytes
dmstyle.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 98816 bytes
dmsynth.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 100864 bytes
dmscript.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 76800 bytes
system.dll: 1.01.4322.0573 English Final Retail 3/8/2004 18:55:58 1216512 bytes
dx7vb.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 602624 bytes
dx8vb.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 1189888 bytes
dxdiagn.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 1675264 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 13:00:00 924432 bytes
mfc42.dll: 6.00.8665.0000 English Beta Retail 8/23/2001 13:00:00 995383 bytes
wsock32.dll: 5.01.2600.0000 English Final Retail 8/23/2001 13:00:00 21504 bytes
amstream.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 64512 bytes
devenum.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02 53248 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 8/29/2002 04:40:52 498205 bytes
mciqtz32.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 34304 bytes
mpg2splt.ax: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 136192 bytes
msdmo.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 13312 bytes
encapi.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18944 bytes
qasf.dll: 9.00.0000.2980 English Final Retail 12/11/2002 17:34:40 241664 bytes
qcap.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 177152 bytes
qdv.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 268800 bytes
qdvd.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02 355840 bytes
qedit.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 524800 bytes
qedwipes.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 733184 bytes
quartz.dll: 6.05.0001.0902 English Final Retail 5/30/2003 09:00:02 1246208 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 8/29/2002 04:41:18 251904 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 11/14/2002 12:58:00 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 11/14/2002 12:58:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 11/14/2002 12:58:02 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 11/14/2002 12:58:02 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 11/14/2002 12:58:02 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 11/14/2002 12:58:04 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 11/14/2002 12:58:04 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 11/14/2002 12:58:06 154624 bytes
mswebdvd.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 194560 bytes
ks.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 130304 bytes
ksproxy.ax: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 117248 bytes
ksuser.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 4096 bytes
stream.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 45696 bytes
mspclock.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 5248 bytes
mspqm.sys: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 4608 bytes
mskssrv.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 7424 bytes
swenum.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 4096 bytes
mstee.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 5504 bytes
bdaplgin.ax: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:26 16896 bytes
bdasup.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:26 11392 bytes
msdvbnp.ax: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:26 52224 bytes
psisdecd.dll: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:28 354816 bytes
psisrndr.ax: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:28 30208 bytes
ipsink.ax: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:26 14848 bytes
mpeg2data.ax: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:26 57856 bytes
ndisip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 10112 bytes
mpe.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:26 15104 bytes
streamip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 14976 bytes
msvidctl.dll: 6.05.0001.0900 English Final Retail 2/17/2003 10:16:28 1230336 bytes
slip.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 10880 bytes
nabtsfec.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 83968 bytes
ccdecode.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:26 16384 bytes
vbisurf.ax: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:30 27648 bytes
msyuv.dll: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:28 16896 bytes
kstvtune.ax: 5.03.0001.0902 English Final Retail 6/4/2003 10:30:32 274432 bytes
ksxbar.ax: 5.03.0001.0902 English Final Retail 6/4/2003 09:18:28 39424 bytes
kswdmcap.ax: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:32 226304 bytes
wstcodec.sys: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:32 18688 bytes
wstdecod.dll: 5.03.0000.0900 English Final Retail 2/17/2003 10:16:32 47104 bytes
msdv.sys: 5.01.2600.0000 English Final Retail 2/17/2003 10:21:50 52096 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.00.3312.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.0001.0902
Creative EAX Dream,0x001fffff,2,0,CTDream.ax,1.00.0005.0000
DV Muxer,0x00400000,0,0,qdv.dll,6.05.0001.0900
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.0001.0902
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.2980
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.0001.0902
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.0001.0902
Indeo® video 5.10 Compression Filter,0x00200000,1,1,,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.04.2600.1142
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.00.3312.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.0001.0902
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
MP3 Encoder Filter,0x00200000,1,0,MP3FileSink.ax,
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.0001.0900
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
WMS Filter,0x00400000,0,1,CTWmSFlt.dll,1.12.0001.0000
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0902
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.0001.0902
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.2980
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.00.3312.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.0001.0900
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.0001.0902
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
Record Queue,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
Noise Reduction,0x00100000,1,1,DSNOISER.AX,1.00.0000.0001
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.2980
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.0001.0902
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.2980
Video Renderer,0x00800001,1,0,quartz.dll,6.05.0001.0902
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.04.2600.1142
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.0001.0902
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.0001.0902
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.0000.0900
Video Renderer,0x00400000,1,0,quartz.dll,6.05.0001.0902
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.2980
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.0000.0900
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
File writer,0x00200000,1,0,qcap.dll,6.05.0001.0900
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.00.3312.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.0001.0902
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.0001.0902
AVI Draw,0x00600064,9,1,quartz.dll,6.05.0001.0902
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.2980
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.0001.0900
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.0001.0900
Creative MP3 Source Filter,0x00400000,0,1,CTMp3SFt.dll,1.00.0010.0000
Indeo® audio software,0x00500000,1,1,,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.2980
AC3 Source Filter,0x00400000,0,1,AC3Filt.dll,1.12.0000.0000
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.2980
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.0001.0900
Null Renderer,0x00200000,1,0,qedit.dll,6.05.0001.0900
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.00.3312.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,6.05.0001.0900
IVF source filter,0x00600000,0,1,,5.10.0002.0051
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
StreamBufferSource,0x00200000,0,0,sbe.dll,6.04.2600.1142
Smart Tee,0x00200000,1,2,qcap.dll,6.05.0001.0900
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.0001.0902
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.0001.0902
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.0001.0902
Wave Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.0001.0902
File stream renderer,0x00400000,1,1,quartz.dll,6.05.0001.0902
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.2980
NVF Filter,0x00400000,0,1,CTNvfFlt.dll,1.00.0000.0000
AVI Mux,0x00200000,1,0,qcap.dll,6.05.0001.0900
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.0001.0902
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.0001.0902
File Source (URL),0x00400000,0,1,quartz.dll,6.05.0001.0902
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
PVTimeScale Plugin,0x00200000,1,1,Amsdspvt.dll,1.00.0000.0001
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.00.3312.0000
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0001
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.0001.0900
BDA MPEG2 Transport Information Filter,0x00200000,1,0,psisrndr.ax,6.05.0001.0900
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.0001.0902
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.0001.0902
Indeo® video 4.4 Decompression Filter,0x0009c400,1,1,,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00030d40,1,1,,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.0000.0900
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.0000.0900
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.0000.0900
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.0001.0900
Indeo® video 5.10 Compression Filter,0x00100000,1,1,,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.0001.0902
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.0001.0900
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.0001.0900
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.0001.0900
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.0001.0900
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.0001.0902
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0902
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.0001.0902
ACELP.net,0x00200000,1,1,quartz.dll,6.05.0001.0902
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.0001.0902
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.0001.0902
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.0001.0902
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.0001.0902
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.0001.0902
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.0001.0902
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.0001.0902
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.0001.0902
Audio Capture Sources:
SB Live! Audio [DC00],0x00200000,0,0,qcap.dll,6.05.0001.0900
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.0001.0902
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.0001.0902
SB Live! MIDI Port [DC00],0x00200000,1,0,quartz.dll,6.05.0001.0902
SB Live! Sw Synth [DC00],0x00200000,1,0,quartz.dll,6.05.0001.0902
SB Live! Synth A [DC00],0x00200000,1,0,quartz.dll,6.05.0001.0902
SB Live! Synth B [DC00],0x00200000,1,0,quartz.dll,6.05.0001.0902
WDM Streaming Capture Devices:
SB Live! MIDI Port [DC00],0x00200000,2,2,,5.03.0000.0900
SB Live! Audio [DC00],0x00200000,3,2,,5.03.0000.0900
WDM Streaming Rendering Devices:
SB Live! DirectMusic Synthesizer [DC00],0x00200000,1,1,,5.03.0000.0900
SB Live! Sw Synth [DC00],0x00200000,1,1,,5.03.0000.0900
SB Live! Synth A [DC00],0x00200000,1,1,,5.03.0000.0900
SB Live! Synth B [DC00],0x00200000,1,1,,5.03.0000.0900
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.0001.0900
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,psisrndr.ax,6.05.0001.0900
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,6.05.0001.0900
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.04.2600.1142
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.04.2600.1142
XDS Codec,0x00200000,0,0,encdec.dll,6.04.2600.1142
Audio Renderers:
SB Live! Audio [DC00],0x00200000,1,0,quartz.dll,6.05.0001.0902
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.0001.0902
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.0001.0902
DirectSound: SB Live! Audio [DC00],0x00200000,1,0,quartz.dll,6.05.0001.0902
WDM Streaming System Devices:
SB Live! Synth A [DC00],0x00200000,11,2,,5.03.0000.0900
SB Live! Audio [DC00],0x00200000,13,2,,5.03.0000.0900
nou ondanks dat niemand gereageert heeft, heb ik het toch gefixt (oh wat ben ik toch goed :P 8) )
Ik snap niet wat je probleem was en ook niet hoe je het opgelost hebt.
Ben je soms dronken?
  • JvS
  • Laatst online: 11:02
JvS
Ik heb hem zelf ook
nou harstikke goed,met zo'n lap tekst had toch niemand wat gekund, je vertelt niet eens hoe-ie in apparaat beheer stat ofzo...
