Before me there was many, after me there will be none. I'm the one!
Nooit eens in je event log gekeken?
Misschien is het handig om aan te geven welk OS je gebruikt?
In Windows 2000 / XP Professional kan je auditing van systems events aanzetten via Start -> Run -> Typ in "gpedit.msc" -> [enter]. Dan kan je zien wanneer de pc uitgeschakeld wordt. De XP Help zegt daarover:
quote: Windows XP HelpAudit system events
Computer Configuration\Windows Settings\Security Settings\Local Policies\Audit Policy
Description
Determines whether to audit when a user restarts or shuts down the computer or when an event occurs that affects either the system security or the security log.
If you define this policy setting, you can specify whether to audit successes, audit failures, or not audit the event type at all. Success audits generate an audit entry when a system event is executed successfully. Failure audits generate an audit entry when a system event is attempted unsuccessfully. To set this value to no auditing, in the Properties dialog box for this policy setting, select the Define these policy settings check box and clear the Success and Failure check boxes.
