[Pingen] Krijg een hele rare reply?
  • 34 views sinds 30-01-2008
  • Snow_King
  • Laatst online: 11-09 09:52
Snow_King
Konijn is stoer!
Hoi,
Ik probeer net mijn server in de VS te pingen maar krijg een hele rare reply
Pinging 66.79.169.215 with 32 bytes of data:
Reply from 166.63.209.18: TTL expired in transit.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Wat is dat voor een maffe reply?
Wie kan mij vertellen wat dat is?
TTL Expired in Transit: Most computers today initialize the TTL value of outgoing IP Packets 128 or higher. If you ever see a reply above with a "TTL=5" (or some other low TTL number) this tells you that the computer being pinged should most likely have its default TTL value increased. Otherwise, anyone trying to communicate with the computer that is at a hop count higher than the TTL will not be able to communicate with the computer. For example, if you are 40 hops away from www.xyz.com, and www.xyz.com sets TTL fields in IP packets that it sends out to 32, the IP Packets will not reach you. They will 'expire in transmit' before they reach you.
http://www.google.com/sea...&q=TTL+expired+in+transit
  • Korakal
  • Laatst online: 11-09 14:05
Korakal
Up up up!
Snow_King schreef op 06 maart 2004 @ 23:44:
Hoi,
Wat heb je zelf al gedaan om daarachter te komen? De policy daaromtrent had je toch inmiddels wel moeten kennen...
Zoekertje, dus dicht.
