[Cnet Switch] Ervaring ?
  • 51 views sinds 30-01-2008
  • Dutchie!
  • Laatst online: 07-12-2023
hallo, ik wil dus deze switch gaan kopen. De CNSH2400 Switch 24 port 19" 10/100
Specificaties:
24 Independent Bandwidths with 10Mbps - 200Mbps Capability
All Ports Support Auto-negotiation Capability to Intelligently Detect and Determine between 10/100Mbps and Half-/Full-duplex
All Ports Support Auto-MDI/MDI-X to Facilitate Installation and Troubleshooting
Full Wire Speed Store-and-Forward Technology Instantly Eliminates Bad Packets
Support IEEE 802.3x Flow-control for Full-duplex and Back Pressure Flow-control for Half-duplex to Prevent the Overflow of Data Frame
Bridging Capability for 100Mbps and 10Mbps Segments
Easy-to-Understand LEDs Display Real-time Traffic Status to Monitor and Diagnose the Network
Model CNSH-2400:
Standards:
- IEEE 802.3: 10BASE-T
- IEEE 802.3u: 100BASE-TX
Advanced Features: IEEE 802.3x: Flow-control
Ports: 24 Copper ports: 100BASE-TX
Media Support:
- 10BASE-T: Category 3, 4 or 5 TP
- 100BASE-TX: Category 5 TP
Bandwidth:
- 10BASE-T: 10/20Mbps
- 100BASE-TX: 100/200Mbps
Forwarding/Filtering Rate:
- 14881 packets/second per port @ 10Mbps maximum
- 148810 packets/second per port @ 100Mbps maximum
Duplex Modes: All ports support Auto-negotiation and Auto-MDI/MDI-X functions
LED Indicators
- One LED displays Power Status
- One LED per port displays Link/ACT status
- One LED per port displays Full-duplex/Collision (Half-duplex) status
Power Supply: Input voltage: 100 ~ 240 +/-10% VAC/ 50 ~ 60 Hz
Power Consumption: 16.5 watt maximum
Environment:
- Operating Temperature: -20° ~ 70° C (-4° ~ 158° F)
- Storage Temperature:-40° ~80° C (-40° ~ 176° F)
- Humidity: 10% ~ 90% Non-condensing
Certifications: FCC , CE
Dimensions: 442 x 184 x 44mm
wel leuk en aardig natuurlijk, maar het zegt mij niet zo heel veel. ik zoek dus een goede swicht, voornamelijk om mee te gamen (kleine LANs dus --> vrienen LAN zegmaar). en ook dus voor thuis :) heeft iemand ervaring met deze Switchs ? of is het merk Cnet slecht ? wie kan mij iets meer vertellen, want ik heb liever geen miskoop.
- wat houd dit in: 100BASE-TX: 100/200Mbps ? (kan het dus op 200Mbps ?)
EDIT: als ik de vraag niet hier mogt stellen, excuus ervoor. :X
[ Voor 6% gewijzigd door Dutchie! op 05-03-2004 11:50 ]
Living in Australia! - Ja, ik heb dyslectie
  • Koffie
Koffie
Koffiebierbrouwer
Braaimeneer
Zie hiervoor de FAQ : FAQ Network Troubleshooting
Braaikamer - Smoke&BBQ
