[Win2k Server] ADModify 1.5 ervaringen
  • ^Stalkie^
  • Laatst online: 06-05 18:51
Hallo allemaal,
Ik ben hier bezig met wat zaken c.q. veranderingen... Allemaal bulk user changes wegens het migreren van wat profiles etc naar een SAN. _/-\o_
Nu ken ik het programma ADModify 1.5 wel. Ik heb er alleen geen ervaringen mee. Heeft iemand die wel en kan mij wellicht valkuilen of kewle dingen erover vertellen? Ik ga het volgende week testen op een testserver.
Wat nadere info:
with ADModify (a hidden treasure on MS FTP site) you can:
Modify Existing User Attributes:
Allows you to do bulk modifications based on users that you select.
Export Users from Active Directory:
Exports selected Active Directory users to an LDIF formatted file on C:\, called adexport.ldf.
Export Users from Exchange 5.5
Allows you to connect to the Exchange 5.5 directory and export mailboxes as users into an LDIF formatted file on C:\, called 55export.ldf.
Import:
Utilizes ldifde.exe to import users.
It is version 1.5.0.3, but no info of updates since 1.4 build 108
What's added in 1.4:
Added Clear altRecipient attribute
Added set altRecipient and the deliver messages to both forwarding address and mailbox
Added Test DN button to Exchange ASP tab for testing of Alternate recipients DN
Fixed add email address on contacts to use cn value instead of samAccountName
Made DClist in the tree browse automatically populate if only one DC is found
Added ability to mass change homeMDB value
Future Plans (scheduled for completion by version 2.0)
Design: Abandon using ldifde for importing. This will allow us to pass many more attributes back into the AD
Modify/Export: Allow contacts/groups to be modified
Modify/Export: Enable Notes/Streets attributes on export
Modify: Populate the country combo box to match allowed attributes by the AD
Modify: Enable Verify Caller ID settings
Help: Populate index for searching of help
  • Rolfie
  • Laatst online: 21:45
Helaas heb ik er zelf geen ervaring mee, maar op googel is er wel wat te vinden
google
google groups
[ Voor 77% gewijzigd door Rolfie op 06-03-2004 23:33 ]
