[PHP][HTML][JS] post interactive multiple select
  • 50 views sinds 30-01-2008
  • youngster
  • Laatst online: 22:41
Ik heb al verschillende topics hierover gelezen maar kan mijn probleem toch nog niet opgelost krijgen.
Dmv dit script moeten users aan groups kunnen worden toegevoegd en verwijderd. Na het posten wil ik alle waarden uit de tabel members hebben (niet alleen de selected) maar krijg dit niet voor elkaar. Graag enige hulp.
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
<?php
//require_once 'include.inc.php';
if(isset($_POST['submit'])){
    echo "Here should the list of members (right column) be printed!";
<SCRIPT LANGUAGE="JavaScript">
function moveOver() {
   var boxLength = document.usergroup.members.length;
   var selectedItem = document.usergroup.users.selectedIndex;
   var selectedText = document.usergroup.users.options[selectedItem].text;
   var selectedValue = document.usergroup.users.options[selectedItem].value;
   var i;
   var isNew = true;
   if (boxLength != 0) {
     for (i = 0; i < boxLength; i++) {
       thisitem = document.usergroup.members.options[i].text;
       if (thisitem == selectedText) {
         isNew = false;
         break;
   if (isNew) {
     newoption = new Option(selectedText, selectedValue, false, false);
     document.usergroup.members.options[boxLength] = newoption;
   document.usergroup.users.selectedIndex=-1;
function removeMe() {
   arrSelected = new Array();
   var count = 0;
     if (document.usergroup.members.options[i].selected) {
       arrSelected[count] = document.usergroup.members.options[i].value;
     count++;
   var x;
     for (x = 0; x < arrSelected.length; x++) {
       if (document.usergroup.members.options[i].value == arrSelected[x]) {
         document.usergroup.members.options[i] = null;
</script>
<?php
//$result1 = querydb("SELECT userID, firstName FROM user");
//$result2 = querydb('SELECT user.userID, firstName FROM user, user_group WHERE user.userID = user_group.userID and user_group.groupID = "1"');
<form name="usergroup" method="post" action="test3.php">
<table>
<tr>
    <td>Users:</td>
    <td>Groupmembers:</td>
</tr>
<tr>
    <td>
        <select name="users" size=10 onchange="moveOver();">
        <?php
        //for($i=0; $i<count($result1); $i++){
            //echo('<option value='.$result1[$i]->userID.'>'.$result1[$i]->firstName.'</option>');
        echo ('<option value="piet">Piet</option>');
        echo ('<option value="jan">Jan</option>');
        echo ('<option value="klaas">Klaas</option>');
        echo ('<option value="rene">Rene</option>');
        echo ('<option value="gerrit">Gerrit</option>');
        echo ('<option value="dirk">Dirk</option>');
        </select>
    </td>
    <td>
        <select multiple name="members" style="width:150;" size="10" onchange="removeMe();">
        <?php
        //for($i=0; $i<count($result2); $i++){
            //echo('<option value='.$result2[$i]->userID.'>'.$result2[$i]->firstName.'</option>');
        </select>
    </td>
</tr>
<tr>
    <td><input type="submit" name="submit" value="    OK    "></td>
</tr>
</form>
Real programmers don't comment their code... it was hard to write, it should be hard to read!
  • NMe
  • Laatst online: 29-09 10:17
NMe
Quia Ego Sic Dico.
Geef de selects de namen "users[]" en "members[]" in plaats van "users" en "members". Je geeft immers een array mee.
Geen optimale topic start trouwens.
[ Voor 18% gewijzigd door NMe op 03-03-2004 15:14 ]
  • youngster
Als ik dat doe werkt het javascript niet meer en krijg ik ook alleen maar de selected waardes gepost.
  • Bosmonster
  • Laatst online: 29-08 19:47
Bosmonster
*zucht*
Een selectbox is bedoeld om 1 of meerdere resultaten uit een lijst te selecteren. Een formulier post dus alleen de waarden die geselecteerd zijn. Als je de listbox ombouwt tot iets dergelijk gaat die functionaliteit verloren en die zul je dus op moeten vangen.
Het makkelijkste (zo doe ik het ook :P) is bij iedere wijziging de lijst(en) even komma-seperated in een hidden input te schrijven. Die stuurt ie mee en kun je serverside weer uitlezen.
  • NMe
NMe
Quia Ego Sic Dico.
youngster schreef op 03 maart 2004 @ 15:16:
Dan moet je wat aan je JavaScript doen zodat die ook overweg kan met die array. En je kan alleen maar de geselecteerde waardes posten, dat is juist het hele idee achter een select.
  • .oisyn
  • Laatst online: 27-10 12:56
.oisyn
Moderator Devschuur®
Demotivational Speaker
youngster schreef op 03 maart 2004 @ 15:12:
Graag enige info
Wij gaan je scripts niet debuggen, dat mag je helemaal zelf doen :), zie ook P&W FAQ - De "quickstart"
